  3. Wirsbo/Uponor thermostat replacement
hardwarethermostatdevelopment
11 Posts 4 Posters 14.3k Views 6 Watching
  • D
    D
    Denke
    Hi all
    Here is my first mysensors HW that i developed and also my first post. Not all functions are tested at the moment.
    I started by analyzing the current thermostat on size and function. Then i took all the info and started working with it in designspark.
    My plan is to use this with Openhab
    Spec
    -Should be able to open/close valve in Uponor system
    -Should in the future be able to open the valve from 0-100% (Think i need to change valves for this)
    -Should fit in the Wirsbo thermostat mechanics
    -The system shall fall back to "old thermostat" function if the home automation stops working by using the knob setting
    -The system shall be built as much as possible on cheap components that could be bought on for example ebay
    Old System
    New system
    If only on/off function is requested then the MOC 3023 could be replaced by a a new one with zero crossing detection and then also the zero crossing detector can be omitted (IL250 in the schematic)
    Schematic
    upload-150a1152-6fed-4abf-b197-75042bb49eb0
    Result
    The HW fits in the old casing
    Not all components are mounted at the moment as i have not received them yet, but the board have partial functions
    RaspberryPi-Openhab
    • HoffanH
      HoffanH
      Hoffan
      This was a nice project.
      I have a lot of these wirsbo in my home. I hope this will work well
      • D
        D
        Denke
        I hope so to.
        At the moment i struggling with the best way to present this sensor to my openhab and also what is the best way to set it up.
        Parameters in
        -remote requested temp //temp requested by the home automation system/user (mandatory)
        -hysteresis low, hysteresis high //where to open and close from requested temp point (Setting for the Tech user) 0.5 will be default
        -Update time //how often shall i regulate/change and measure (Setting for tech user) 1min will be default
        Parameters out
        -Temperature
        -valve state
        -Info field:
        --Direct requested temp (knob reading)
        --Remote requested temp (See above)
        --Running mode internal/external (fall back if no communication is reaching the thermostat, but thermostat info is visible in system)
        --hysteresis set in thermostat
        --Update time
        Anyone got any thoughts on what is the best way to present this.
        RaspberryPi-Openhab
        • bjornhallbergB
          bjornhallbergB
          bjornhallberg
          Fantastic project! I also have a ton of these Wirsbo thermostats (from circa 1999) at home. Some of them have failed and have been bypassed. Remarkably expensive to replace and remarkably dull design wise. I always wanted to build something like this, possibly with the addition of a small oled display and a 3d printed or cnc machined (wood) enclosure.
          • D
            D
            Denke
            New boards ordered. Took the oportunity to add an extra connector for SPI. So this in combination with the SDA/SCA will make it possible to add an OLED.
            RaspberryPi-Openhab
            • D
              D
              Denke
              Finally my new boards have arrived, made some mistakes on the first one.
              RaspberryPi-Openhab
              • clio75C
                clio75C
                clio75
                wrote on last edited by clio75
                Nice project. I have started similar "upgrade".
                But my plan is to have separate temp/humidity sensors that reports to the VERA.
                And then have a separate controller that open/close the valves/attenuators.
                Now I have some sensors connected. My next step is to create one arduino/MySensor PID controller.
                This should get actual temp and setpoint from VERA.
                For a fallback I have some Ideas.
                • Use some Pre Programmed settings.
                • Last PID settings
                • Get information directly from each sensor. (setup from VERA)
                Looking forward to follow your project :)
                • D
                  D
                  Denke
                  Now the code is tested against openhab2.0 after some work adding HVAC in the binding. Will make a pull request for the binding part soon
                  0_1458674411278_upload-75e8cbec-c0dc-4aa4-91e2-1361eadfe771
                  RaspberryPi-Openhab
                  • D
                    D
                    Denke
                    2 boards completely assembled and working as expected. 3 more to go after ordering the missing components. Now some last fixes to the code so that memory can be wiped by pressing a button and also the check if connected to the home automation system if not a fallback should be initiated
                    RaspberryPi-Openhab
                    • bjornhallbergB
                      bjornhallbergB
                      bjornhallberg
                      @Denke Any updates to this project? Did you deploy the sensors? Any issues or has it been smooth sailing for the last couple of years?
                      D 1 Reply Last reply
                        D
                        D
                        Denke
                        @bjornhallberg The sensors are working fine and have been installed in my home for the last couple of years. Some optimisation needs to be done to the code, that i have not done. This is more connected to understanding when the mysensors network is in "range" as i want to fallback on the manual knob if the mysensor network is inactive for some reason or if i sell the house and the controller goes with me.
                        RaspberryPi-Openhab
