  3. 💬 Easy/Newbie PCB for MySensors
mysensorsbatteryeasynewbiepcbmysx
716 Posts 111 Posters 681.9k Views 93 Watching
  • EfflonE
    EfflonE
    Efflon
    Gah! I ordered through the https://www.openhardware.io/order/4/PCB10X link from Itead but got the rev8 boards. Thought the "I always update the gerber files for sale" meant it was safe to order...
    • EfflonE Efflon
      #262
      @Efflon did the order say version m5 when you ordered? Which date did you place the order?
      EfflonE 1 Reply Last reply
        EfflonE
        EfflonE
        Efflon
        @mfalkvidd I ordered January 2 and can't remember what version was stated. I'm quite sure I picked Itead because it had a higher version numer (and a slightly higher price), honestly don't remember. All I know is that I didn't read this thread but rather just browsed through the page and clicked order. Afterwards I realized it wasn't clear if it was the 5V or 3.3V version but the order said 5x5cm. I also missed to choose color but "grönt är skönt".
        Guess what confused me most was the statement "It may say another rev. at the orderpage but this is not EasyPCB rev but the rev for manufacturer." causing me to be trigger happy :smile:
        • EfflonE Efflon
          @Efflon - sorry to hear you got rev 8 if you wanted rev 9.
          I wrote this notice just because itead was so slow updating to the right revision! I also spoke to hek about this a month ago according to my chat log.
            Sorry to hear... Checked the log. The order was for manufacturer revision 4 (which is what @sundberg84 call rev 8 ).
            The system automatically increments the revision number each time an author makes a new release. Each manufacturer must set price on each revision(which in some cases may take a while if they do this manually). Until they've done that, any older revision where they've set a price is still available for purchase.
            The revision is stated below the big order-button.
            • AmputA
              AmputA
              Amput
              wrote on last edited by Amput
              #266
              Could anyone explain me, why position (polarity) of condensers 4.7uF on REV 8(blue) and REV 9 (red) are different?
              ferroF 1 Reply Last reply
              • AmputA Amput
                ferroF
                ferroF
                ferro
                @Amput said in 💬 Easy/Newbie PCB for MySensors:
                It's a bug in v8 fixed in v9, so v9 is correct, see link this post
                AmputA 1 Reply Last reply
                • martinsM
                  martinsM
                  martins
                  @SUNDBERG84 - Do you have a board/design for the RFM69 radio ?
                  Rergards,
                  Martin
                  ferroF sundberg84S 2 Replies Last reply
                  • martinsM martins
                    Rergards,
                    Martin
                    ferroF
                    ferroF
                    ferro
                    @martins - you can use NRF2RFM69 if you want to use RFM69 with Newbie PCB board. I'm using it too, works fine with 3.3V arduino. For 5V arduino you will need to add level logic converter too.
                    martinsM 1 Reply Last reply
                    • ferroF ferro
                      martinsM
                      martinsM
                      martins
                      @ferro
                      Pity because that would double the cost of the sensor board:
                      Order PCBs for Easy/Newbie PCB for MySensors : $15
                      Order PCBs for NRF2RFM69 : $15
                      Thanks,
                      Martin
                      • ferroF ferro
                        AmputA
                        AmputA
                        Amput
                        @ferro said in 💬 Easy/Newbie PCB for MySensors:
                        Thx for answer :-).
                        • martinsM martins
                          Rergards,
                          Martin
                          @martins - No, not at the moment. It has been asked before but I have never got my head around it.
                          As i told before, you are happy to develop it yourself. I have some other things in my list but in the future maybe :)
                          • meanmrgreenM
                            meanmrgreenM
                            meanmrgreen
                            wrote on last edited by meanmrgreen
                            #273
                            This post is deleted!
                            • meanmrgreenM
                              meanmrgreenM
                              meanmrgreen
                              • N
                                N
                                N00phi
                                Hi
                                I've tried to order the capaciter and voltage regulator from our local electronics supplier. The choice is too big. Could anyone please help a "newbie" to select the right parts for a raw powered 5V version
                                • 4.7uF capacitor
                                • voltage regulator
                                • 0.1 and 10uF cap
                                  http://www.distrelec.ch/ can't select the parts because of missing size and especially for the voltage regulator the exact type.
                                • N N00phi
                                  Hi
                                  • 4.7uF capacitor
                                  • voltage regulator
                                  • 0.1 and 10uF cap
                                  @N00phi - I usually just select the ones at www.mysensors.org/store but if you have a specific site you wish to order from I can choose for you.
                                  N 1 Reply Last reply
                                  • sundberg84S sundberg84
                                    N
                                    N
                                    N00phi
                                    @sundberg84 It would be absolutely great if you could do so! I would order at http://www.distrelec.ch ...
                                    • N N00phi
                                      @N00phi for the capacitors: http://www.distrelec.ch/search?q=electrolytic+capacitor&filter_Rated+voltage~~VDC=50&filter_Diameter+housing~~mm=4&filter_Diameter+housing~~mm=5 (choose the axial types which is the one with two legs).
                                      As for the voltage regulator I use LE33ACZ 5V-3.3V which i cant find on that site.
                                      dbemowskD N 2 Replies Last reply
                                        dbemowskD
                                        dbemowskD
                                        @sundberg84 said in 💬 Easy/Newbie PCB for MySensors:
                                        Just for clarification, there is axial lead and radial lead components. The axial leads have both wires coming out of one side (as @sundberg84 mentions it looks like two legs). Radial leads have one wire coming out each side. I almost never use radial lead capacitors.
                                          N
                                          N
                                          N00phi
                                          wrote on last edited by N00phi
                                          #280
                                          @sundberg84 Thank you! One more question.. on the photo, there is a flat broun capacitor, what are the specifications for that one? Is it 0,1uF? But thats not an aluminium electrolytic capacitor, is it?
                                          Oh, and the voltage regulator is available on aliexpress, found that one.
                                          Nca78N 1 Reply Last reply
