  3. delay for LDR sensor
13 Posts 2 Posters 3.4k Views 2 Watching
  • DickD
    DickD
    Dick
    wrote on last edited by Dick
    I am a newbi and I have a working sensor build. A 4 button, 4 Relay and Pir. I added an LDR and that works only it keep on logging. How to stop this, perhaps a delay or something like that and where to place in the script?
    The Serial.println(lightLevel);
    delay(2500); //just here to slow down the output for easier reading does not work
    #include "Bounce2.h"
    #define USE_MOTION_SENSOR
    #define MOTION_SENSOR_PIN    3
    #define LIGHT_SENSOR_ANALOG_PIN A0
    #define CHILD_ID_LIGHT 6
    #define RELAY_ON 0                      // switch around for realy HIGH/LOW state
    #define RELAY_OFF 1
    Bounce motionsDebouncer = Bounce();
    #define RADIO_ID 11                    // radio Id, whatever channel you assigned to
    #define noRelays 4
    const int relayPin[] = {A1, A2, A3, A4}; //  switch around pins to your desire
    const int buttonPin[] = {A5, 6, 7, 8}; //  switch around pins to your desire
    class Relay             // relay class, store all relevant data (equivalent to struct)
    public:
      int buttonPin;                    // physical pin number of button
      int relayPin;                     // physical pin number of relay
      byte oldValue;                    // last Values for key (debounce)
      boolean relayState;               // relay status (also stored in EEPROM)
    Relay Relays[noRelays];
    Bounce debouncer[noRelays];
    MyMessage msg[noRelays];
    MyMessage msgLDR(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    int lastLightLevel;
    unsigned long SLEEP_TIME = 6000; // Sleep time between reads (in milliseconds)
      gw.begin(incomingMessage, RADIO_ID, true);
      delay(250);
      gw.sendSketchInfo("Multy-Relay&Pulsanti", "0.2");
      delay(250);
      gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
      pinMode( MOTION_SENSOR_PIN, INPUT_PULLUP );
      motionsDebouncer.attach(MOTION_SENSOR_PIN);
      motionsDebouncer.interval(50);
      // Initialize Relays with corresponding buttons
      for (int i = 0; i < noRelays; i++)
        Relays[i].buttonPin = buttonPin[i];              // assign physical pins
        Relays[i].relayPin = relayPin[i];
        msg[i].sensor = i;                                   // initialize messages
        msg[i].type = V_LIGHT;
        debouncer[i] = Bounce();                        // initialize debouncer
        debouncer[i].attach(buttonPin[i]);
        debouncer[i].interval(5);
        pinMode(Relays[i].buttonPin, INPUT_PULLUP);
        Relays[i].relayState = gw.loadState(i);                               // retrieve last values from EEPROM
        digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
        gw.send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
        gw.present(i, S_LIGHT);                               // present sensor to gateway
        delay(250);
      if ( motionsDebouncer.update()) {
        int value = motionsDebouncer.read();
        Serial.println( "Motion sensor is " + (String)value );
      gw.process();
      for (byte i = 0; i < noRelays; i++)
        debouncer[i].update();
        byte value = debouncer[i].read();
        if (value != Relays[i].oldValue && value == 0)
          gw.saveState( i, Relays[i].relayState );
        }                 // save sensor state in EEPROM (location == sensor number)
        Relays[i].oldValue = value;
       int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
           gw.send(msgLDR.set(lightLevel));
          lastLightLevel = lightLevel;
          Serial.print("Lightlevel =");
    // process incoming message
      if (message.type == V_LIGHT)
        if (message.sensor < noRelays)            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
          digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
          gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
     // delay( 50 ); // give the input pins some rest. Incomming messages are still being processed.
    gw.wait(50);
    • DickD Dick
      #define RELAY_OFF 1
      #define noRelays 4
      public:
      int lastLightLevel;
        delay(250);
        delay(250);
          delay(250);
        gw.process();
      gw.wait(50);
      @Dick my guess is that the light level changes slightly each time. Is that correct?
      If so, try changing
      to
      if ((lightLevel > 1.05 * lastLightLevel)||(lightLevel < 0.95 * lastLightLevel))
      This will prevent the light level from being reported unless it has changed more than 5%.
      You can then remove the delay(2500). It might prevent the sensor from receiving incoming messages.
      • DickD
        DickD
        Dick
        thanks for the advise. I changed the If into you sugested (what is much better that 5% difference) but the ldr is still logging (10 per second or so).
        any Idea?
        • DickD Dick
          any Idea?
          @Dick what numbers is it logging?
          DickD 1 Reply Last reply
            DickD
            DickD
            Dick
            1 to 100 depends on the light intencity and it changes the value with more and less light.
            • DickD Dick
              @Dick Isn't that what you want?
                DickD
                DickD
                Dick
                that is what I want but it continue with logging (> 1000 per minute).So the sensor is very busy with the LDR only. a delay should be the best or your solution of 5% difference.
                • DickD Dick
                  @Dick does the number vary wildly even if the same amout of light is shining on the ldr?
                    DickD
                    DickD
                    Dick
                    no it is steady with the same amount of light, changing it it keeps steady on the new value but with a hi speed logging. , I checked it just now. The LDR is connected to the +5v and A0 with a resister of 10k to gnd.
                    • DickD Dick
                      @Dick now I see the problem! There are two Serial.println(lightLevel);
                      Remove the Serial.println(lightLevel); that sits just before the if clause.
                      • DickD
                        DickD
                        Dick
                        YES yes yes, I did not see that one. Your solution is working perfect also with the difference in light (5%).
                        Thank you for the support and have a nice weekend
                        • DickD Dick
                          @Dick you're welcome, the same to you
                          Back to buildning lighting for my wife's makeup mirror :)
                            DickD
                            DickD
                            Dick
                            good luck and i advice you to do it wll otherwise you have an issue:sweat:
