  3. Battery powered sensor last 1 week
29 Posts 7 Posters 10.5k Views 6 Watching
  • Martin TellblomM
    Martin TellblomM
    Martin Tellblom
    I have made a sensor based an a Easy/Newbie PCB a pro Mini (3,3V 8Mhz with desolderd power LED and Regulator) attached a soil moisture sensor and checking every 2 hrs. The 2 AA batteries last just under a week.
    What do I need to do more to get it to last a little bit longer that just under a week?
    The sensor is the one here: https://www.mysensors.org/build/moisture
    Her is the code I have adapted to check for battery aswell
       The MySensors Arduino library handles the wireless radio link and protocol
       between your home built sensors/actuators and HA controller of choice.
       The sensors forms a self healing radio network with optional repeaters. Each
       repeater and gateway builds a routing tables in EEPROM which keeps track of the
       network topology allowing messages to be routed to nodes.
       Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
       Copyright (C) 2013-2015 Sensnology AB
       Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
       Documentation: http://www.mysensors.org
       Support Forum: http://forum.mysensors.org
       This program is free software; you can redistribute it and/or
       modify it under the terms of the GNU General Public License
       version 2 as published by the Free Software Foundation.
       DESCRIPTION
       Arduino soil moisture based on gypsum sensor/resistive sensor to avoid electric catalyse in soil
        Required to interface the sensor: 2 * 4.7kOhm + 2 * 1N4148
       Gypsum sensor and calibration:
          DIY: See http://vanderleevineyard.com/1/category/vinduino/1.html
          Built: Davis / Watermark 200SS
              http://www.cooking-hacks.com/watermark-soil-moisture-sensor?_bksrc=item2item&_bkloc=product
              http://www.irrometer.com/pdf/supportmaterial/sensors/voltage-WM-chart.pdf
              cb (centibar) http://www.irrometer.com/basics.html
                  0-10 Saturated Soil. Occurs for a day or two after irrigation
                  10-20 Soil is adequately wet (except coarse sands which are drying out at this range)
                  30-60 Usual range to irrigate or water (except heavy clay soils).
                  60-100 Usual range to irrigate heavy clay soils
                  100-200 Soil is becoming dangerously dry for maximum production. Proceed with caution.
       Connection:
        D6, D7: alternative powering to avoid sensor degradation
       A0, A1: alternative resistance mesuring
        Based on:
        "Vinduino" portable soil moisture sensor code V3.00
         Date December 31, 2012
         Reinier van der Lee and Theodore Kaskalis
         www.vanderleevineyard.com
       Contributor: epierre
    // Copyright (C) 2015, Reinier van der Lee
    // www.vanderleevineyard.com
    // This program is free software: you can redistribute it and/or modify
    // it under the terms of the GNU General Public License as published by
    // the Free Software Foundation, either version 3 of the License, or
    // any later version.
    // This program is distributed in the hope that it will be useful,
    // but WITHOUT ANY WARRANTY; without even the implied warranty of
    // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    // GNU General Public License for more details.
    //#define MY_DEBUG
    #define  MY_NODE_ID 30
    int BATTERY_SENSE_PIN = A0;
    #include <math.h>       // Conversion equation from resistance to %
    // Setting up format for reading 3 soil sensors
    #define NUM_READS 10    // Number of sensor reads for filtering
    #define CHILD_ID 0
    MyMessage msg(CHILD_ID, V_LEVEL);
    unsigned long SLEEP_TIME = 7200000; //  Every 2 hrs //Sleep time between reads (in milliseconds)
    long buffer[NUM_READS];
    int index;
    int oldBatteryPcnt = 0;
    /// @brief Structure to be used in percentage and resistance values matrix to be filtered (have to be in pairs)
    typedef struct {
      int moisture; //!< Moisture
      long resistance; //!< Resistance
    } values;
    const long knownResistor = 4700;  // Constant value of known resistor in Ohms
    int supplyVoltage;                // Measured supply voltage
    int sensorVoltage;                // Measured sensor voltage
    values valueOf[NUM_READS];        // Calculated moisture percentages and resistances to be sorted and filtered
    int i;                            // Simple index variable
      analogReference(INTERNAL1V1);
    #else
      analogReference(INTERNAL);
    void presentation()  {
      sendSketchInfo("Soil Moisture Sensor Reverse Polarity", "1.0");
      present(CHILD_ID, S_HUM);
      measure(6, 7, 1);
     //  Serial.print ("\t");
     // Serial.println (average());
      long read1 = average();
      measure(7, 6, 0);
      //Serial.print ("\t");
      //Serial.println (average());
      long read2 = average();
      long sensor1 = (read1 + read2) / 2;
      /*Serial.print ("resistance bias =" );
      Serial.println (read1 - read2);
      Serial.print ("sensor bias compensated value = ");
      Serial.println (sensor1);
      Serial.println ();
      //send back the values
      send(msg.set((long int)ceil(sensor1)));
      // delay until next measurement (msec)
      //Serial.println(sensorValue);
      // DEBUG Battery INFO
      float batteryV  = sensorValue * 0.003363075;
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
      // END DEBUG INFO
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
      sleep(SLEEP_TIME);
    void measure (int phase_b, int phase_a, int analog_input)
      // read sensor, filter, and calculate resistance value
      // Noise filter: median filter
      for (i = 0; i < NUM_READS; i++) {
        // Read 1 pair of voltage values
        digitalWrite(phase_a, HIGH);                 // set the voltage supply on
        delayMicroseconds(25);
        supplyVoltage = analogRead(analog_input);   // read the supply voltage
        digitalWrite(phase_a, LOW);                  // set the voltage supply off
        delay(1);
        digitalWrite(phase_b, HIGH);                 // set the voltage supply on
        sensorVoltage = analogRead(analog_input);   // read the sensor voltage
        digitalWrite(phase_b, LOW);                  // set the voltage supply off
        // Calculate resistance
        // the 0.5 add-term is used to round to the nearest integer
        // Tip: no need to transform 0-1023 voltage value to 0-5 range, due to following fraction
        long resistance = (knownResistor * (supplyVoltage - sensorVoltage ) / sensorVoltage) ;
        delay(1);
        addReading(resistance);
        Serial.print (resistance);
    // Averaging algorithm
    void addReading(long resistance) {
      buffer[index] = resistance;
      index++;
      if (index >= NUM_READS) index = 0;
    long average() {
      long sum = 0;
      for (int i = 0; i < NUM_READS; i++) {
        sum += buffer[i];
      return (long)(sum / NUM_READS);
    MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
    • scalzS
      scalzS
      Hello.
      I think, depending on how your sensor is connected, it is always powered on. Your node is sleeping but you would need to use a mosfet to power off the sensor when you don't use it. Or use an IO pin to deliver the power instead of a "mosfet switch".
      • Martin TellblomM
        Martin TellblomM
        Martin Tellblom
        @scalz said:
        always powere
        Alright, as you proberbly understand I'm not a electronics engineer :) so please explain that to me.
        This is how its setup:
        Everything is build on @sundberg84 Easy/Newbie PCB (This is my LAB PCB that I try out on before soldering, easier to chane components to see if someone of the cheap once are broken)
        Sensor Vcc connected to 3,3V, GND to GND and sensor to D3.
        So what do I have to do to turn of the sensor when I put the arduino to sleep?
        • Martin TellblomM Martin Tellblom
          @scalz said:
          always powere
          @Martin-Tellblom - instead of wire power from VCC to the sensor you could try power it through D3 or another IO pin.
          Then you set this pin to HIGH to power the sensor and then LOW before you sleep the node.
          If you have a multimeter you could measure the ampere when you sleep the node.
          • Martin TellblomM
            Martin TellblomM
            Martin Tellblom
            Alright so if I connect the Vcc sron the sensor to D2 (since I use D3 for measurement) and set that HIGH before I measure, should I have a sleep for it to power up aswell?
            Something Like this?
              digitalWrite(SOIL_POWER_PIN , HIGH);
              moisture = analogRead(SOIL_SENSE_PIN);
              digitalWrite(SOIL_POWER_PIN , LOW);
            sundberg84S Nca78N 2 Replies Last reply
              @Martin-Tellblom - Yes, something like that.
              Dont use delay, use wait(); if tou want to create a pause for reading.
              Martin TellblomM 2 Replies Last reply
              • sundberg84S sundberg84
                Martin TellblomM
                Martin TellblomM
                Martin Tellblom
                @sundberg84
                OK,
                I have now changed to the below code and changed to a SOIL sensor with the LED still on
                The LED is lit up even after digitalWrite(SOIL_POWER_PIN , LOW); so I don't think its working
                  wait(25);
                  wait(25);
                  if (oldMoisture != moisture) {
                    send(msgSoil.set(moisture, 0));
                    sendBatteryLevel(moisture);
                    oldMoisture = moisture;
                  //Check Battery Level
                  sleep(SLEEP_TIME);
                  Martin TellblomM
                  Martin TellblomM
                  Martin Tellblom
                  @sundberg84
                  Stupid me, forgot defining it as output pinMode(SOIL_POWER_PIN, OUTPUT); in the setup
                  It's working now
                  • sundberg84S
                    Good! @Martin-Tellblom If you can measure how much uA it consumes in sleep() mode you can then calculate the life expectancy. Around 100uA is fine in my world with a booster and pro mini.
                    Martin TellblomM 1 Reply Last reply
                      Martin TellblomM
                      Martin TellblomM
                      Martin Tellblom
                      I thought I could do that with my multimeter but I get no value
                        @Martin-Tellblom - Put the multimeter in series with VCC. Dont forget to change the input on your multimeter.
                        cimba007C 1 Reply Last reply
                          cimba007C
                          cimba007C
                          cimba007
                          wrote on last edited by cimba007
                          @sundberg84
                          Be aware that depending on the mesurement range a multimeter could introduce a big burdan voltage.
                          Just simple and short: To measure in the mA range you the multmeter measures the voltage drop accross a series resistor with an value .. call it A.
                          Switching to the µA range the mutltimeter switches to a much larger resistor (e.g. 1000times A) to measure a significat enough voltage drop. With the wrong voltage range .. measuring µA while the board is consuming in the mA range might lead to a huge voltage drop and your circuit not working at all.
                          So do this:
                          • Switch to mA mode .. take your measurement .. wait until you KNOW for sure your circuit is in sleep mode (add some messages on the serial console) and THEN switch to µA range.
                          • Martin TellblomM
                            Martin TellblomM
                            Martin Tellblom
                            I don't think my multimeter is good enough for this, It seems like it put in some power due if I
                            I will try this when I get home today and see if I need a new multimeter or not :)
                            • scalzS
                              scalzS
                              wrote on last edited by scalz
                              and with a multimeter only, due to burden voltage and depending of the multimeter precision, you won't get the true power consumption, an approx which is still nice, you can know what "looks" power consumption and tendancy. Even if you're using a nice expensive Fluke. Best precision for this is uCurrent Gold+multimeter ;)
                              • Martin TellblomM
                                Martin TellblomM
                                Martin Tellblom
                                wrote on last edited by Martin Tellblom
                                @scalz
                                Or just simply take percentage and date/time and then a few days later see what has changed percentage wise ...
                                Its to simple I know but if 1% battery power equals 4 days the sensor probably last for about 9-10 month (the last percentage I suppose you don't get any communication with :) )
                                  @scalz
                                  @Martin-Tellblom - Im not sure it works that way. It depends on which battery you use.
                                  Voltage tends to drop faster in the end for normal AA batteries.
                                  My sensors doesnt drop that much (maybe 5%) the first 6 months.
                                  • Martin TellblomM
                                    Martin TellblomM
                                    Martin Tellblom
                                    @sundberg84 Hmm What you are saying is that I need to buy a new and better Multimeter :) This is the reason I was waiting for ..... :9
                                      @Martin-Tellblom - I hope you dont give up! Battery operations was the hardest part for me to figure out...
                                      • Martin TellblomM
                                        Martin TellblomM
                                        Martin Tellblom
                                        I only have two kind of sensors that I need to be battery operated and that's the plants warning that they are out of water and soon gonna die and the dogs water bowl warning that they soon gonna die (KIDDING). The dogs bowl I like to measure the levels and have that to compare with the temperature, just for fun.
                                        I hope I get this working aswell, It wont be pretty with a cable around the few plants we got
                                        • N
                                          N
                                          Nicklas Starkel
                                          @Martin-Tellblom , I'm in this mess as well. Just ordered a new Multimeter off aliexpress :)
                                          @sundberg84 , have you tried other batteries? I bough some ultrafire 3.7V 8800mAh and will try these.
                                          They were cheap so no loss if they do not work out..
