  3. Esp8266 with wifi off
4 Posts 3 Posters 8.7k Views 4 Watching
  • S
    stedew
    wrote on last edited by stedew
    I have a small question and maybe someone else already knows the answer.
    For testing i want to use a esp8266 (esp12 /nodemcu board) with a nrf24L01+) as a GW (serial).
    I have this working but i want to shut down the WIFI completely what instruction i have to use for this?
        wifi_set_sleep_type(MODEM_SLEEP_T);
    	delay(1);
        system_deep_sleep_set_option(MODEM_SLEEP_T);```
    I don't know exactly and also while testing i was pinging the wrong ip so i got a little confused ;-)
    What i basicly want to do is use the esp as a high performance GW/node.
    So any suggest are welcome.
    regards,
    Stefan.
    • E
      E
      emc2
      Make sure you include this in your sketch
      #include <ESP8266WiFi.h>
      Then add the following lines at the beginning of your setup()
        WiFi.disconnect();
        WiFi.mode(WIFI_OFF);
        WiFi.forceSleepBegin();
        delay(1);
      It should totally disable ESP WiFi functions and basically you end up with an arduino nano.
      S 1 Reply Last reply
      • E emc2
          WiFi.disconnect();
          delay(1);
        stedew
        @emc2
        Tnx spot on :thumbsup:
        Before i measure 88mA and now ~ 30mA. In reality the profit (% saving) will be even higher. The test setup is with all node mcu hardware so there will definitly be a higher gain with a "bare" esp.
        As for some may ask: why use a esp (nodeMCU) as a arduino?
        -"Solid" Integrated 3v3 regulator
        -Good RF design(shielding)
        -USB RS232 interface
        -High processing power (if needed).
        -I could not get the wifi gateway rock solid (compared to the RS232) .
        From the moment domoticz disconnect (or the ESP lost connection) there was no communication anymore without an intervention to domoticz.
        Regards,
        Stefan.
        • AWIA
          AWIA
          AWI
          :thumbsup: sounds good. The processing power and memory would allow for a (basic) controller functionality.
