  3. PN532 NFC RFID module V3 kits : Didn't find PN53x board
arduinonfcpn532
3 Posts 3 Posters 8.0k Views 2 Watching
  • S
    SebDominguez
    Hello
    I'm trying to make my PN532 NFC RFID module V3 kits working with my Arduino Uno.
    According to this manual to communicate with the Arduino in I2C mode I need to set the DIP switch like this :
    Channel 1: ON
    Channel 2: OFF
    Here is the wiring:
    Configuration Table
    Wiring
    I'v tried with this lib and the Adafruit one
    There is my code (it's the iso14443a_uid sketch)
    #if 0
      #include <PN532_SPI.h>
      #include "PN532.h"
      PN532_SPI pn532spi(SPI, 10);
      PN532 nfc(pn532spi);
    #elif 0
      #include <PN532_HSU.h>
      #include <PN532.h>
      PN532_HSU pn532hsu(Serial1);
      PN532 nfc(pn532hsu);
    #else
      #include <Wire.h>
      #include <PN532_I2C.h>
      #include <PN532.h>
      #include <NfcAdapter.h>
      PN532_I2C pn532i2c(Wire);
      PN532 nfc(pn532i2c);
    void setup(void) {
      Serial.begin(115200);
      Serial.println("Hello!");
      nfc.begin();
      uint32_t versiondata = nfc.getFirmwareVersion();
      if (! versiondata) {
        Serial.print("Didn't find PN53x board");
        while (1); // halt
      // Got ok data, print it out!
      Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
      Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
      Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
      // Set the max number of retry attempts to read from a card
      // This prevents us from waiting forever for a card, which is
      // the default behaviour of the PN532.
      nfc.setPassiveActivationRetries(0xFF);
      // configure board to read RFID tags
      nfc.SAMConfig();
      Serial.println("Waiting for an ISO14443A card");
    void loop(void) {
      boolean success;
      uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
      uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
      // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
      // 'uid' will be populated with the UID, and uidLength will indicate
      // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
      success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
      if (success) {
        Serial.println("Found a card!");
        Serial.print("UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
        Serial.print("UID Value: ");
        for (uint8_t i=0; i < uidLength; i++)
          Serial.print(" 0x");Serial.print(uid[i], HEX);
        Serial.println("");
        // Wait 1 second before continuing
        delay(1000);
      else
        // PN532 probably timed out waiting for a card
        Serial.println("Timed out waiting for a card"
    [/code]);
    This is my output
    Hello!
    Thanks for help :)
    • D
      D
      DavidZH
      In your sketch, remove everything above, and including #else and also the line #endif. You only need the I2C declarations in your case.
      Good luck!
      • K
        K
        knava.4
        Hi!
        I have the same problem. Did you resolve it?
        Thanks!
