  3. Vera
  4. VERA / Arduino Integration
veraarduinoethernet gateway
4 Posts 2 Posters 1.8k Views 2 Watching
  • S
    sparky60
    I am new to this site. I was directed to this site from the VERA forums. I am trying to integrate an Arduino with VERA. I am reading about the different Gateways and such. The Ethernet Gateway looks good but I do not need the wireless / radio devices. The project I am trying to accomplish....I have 2 out buildings out of range of ZWave and WIFI but I have Ethernet cable run to each of the buildings. I would like to put an Arduino in each of the buildings. I need about 6 digital inputs and a few digital outputs on each board. Door switches, etc. Nothing fancy here. The buildings are pole buildings so running wire is very easy. I saw the examples relay control and door/window button. I would like to combine the 2 without the radio units. Basically, use the I/O on the Gateway Arduino. Is this possible? Also, is it possible to use 2 Ethernet Gateways on a VERA? BTW I have the MySensors Plugin running / installed and running on Vera. I have a basic understanding of Arduino. Any suggestions / comments / directions would be greatly appreciated.
    Thank you.
    korttomaK 1 Reply Last reply
    • S sparky60
      Thank you.
      korttomaK
      korttomaK
      korttoma
      @sparky60
      Yes it is possible to run I/O on a Ethernet Gateway without radio unit
      Yes it is possible to have multiple Gateways connected to the same Vera, you just add another plugin device and use different IP for it. Remember to also use different MAC address for each GW in the sketch.
      Not sure how up to date this example is because I have not updated my devices for a year or 2 but I think you get the idea.
      Example sketch:
       * Version 1.0 - Henrik EKblad
       * Contribution by Tomas Hozza <thozza@gmail.com>
       * LED purposes:
      //#define MY_DEBUG
      #define SN "EthGW/RFM69 Rele Button"
      #define SV "1.1"
      //#define MY_RADIO_NRF24
      #define MY_IS_RFM69HW
      #define MY_RF69_SPI_CS 4  //try changeing this to 9
      #define MY_GATEWAY_W5100
      //#define MY_W5100_SPI_EN 10
      // radio on the same spi bus.
      // Enable to UDP
      //#define MY_USE_UDP
      #define MY_IP_ADDRESS 192,168,1,100   // If this is disabled, DHCP is used to retrieve address
      #define MY_PORT 5003
      //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
      #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xED, 0xED
      // Flash leds on rx/tx/err
      //#define MY_LEDS_BLINKING_FEATURE
      // Set blinking period
      // Enable inclusion mode
      //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
      //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
      //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
      #if defined(MY_USE_UDP)
        #include <EthernetUdp.h>
      #include <Ethernet.h>
      #include <Bounce2.h>
      #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
      #define RELAY_OFF 1
      #define noRelays 4                     //2-4
      const int relayPin[] = {14, 15, 16, 17};       //  switch around pins to your desire
      const int buttonPin[] = {7, 8, 5, 6};   //  switch around pins to your desire
      class Relay             // relay class, store all relevant data (equivalent to struct)
        public:
          int buttonPin;                   // physical pin number of button
          int relayPin;             // physical pin number of relay
          boolean relayState;               // relay status (also stored in EEPROM)
      Relay Relays[noRelays];
      Bounce debouncer[noRelays];
      MyMessage msg[noRelays];
        wait(100);
        // Initialize Relays with corresponding buttons
        for (int i = 0; i < noRelays; i++) {
          Relays[i].buttonPin = buttonPin[i];              // assign physical pins
          Relays[i].relayPin = relayPin[i];
          msg[i].sensor = i;                                   // initialize messages
          msg[i].type = V_LIGHT;
          pinMode(Relays[i].buttonPin, INPUT_PULLUP);
          wait(100);
          Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
          digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
          send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
          wait(50);
          debouncer[i] = Bounce();                        // initialize debouncer
          debouncer[i].attach(buttonPin[i]);
          debouncer[i].interval(30);
          wait(50);
        sendSketchInfo(SN, SV);
        wait(100);
          present(i, S_LIGHT);                               // present sensor to gateway
        wait(100);
        for (byte i = 0; i < noRelays; i++) {
          if (debouncer[i].update()) {
            int value = debouncer[i].read();
            if ( value == LOW) {
              // save sensor state in EEPROM (location == sensor number)
              saveState( i, Relays[i].relayState );
        //wait(20);
        if (message.sender == 0) {
            if (message.sensor < noRelays) {          // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
              digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
              saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
        wait(20);
      • Tomas
      • S
        sparky60
        Thank you for your reply. If I am looking at this code right, you have 4 inputs and 4 outputs, is this correct?
        • S sparky60
          korttomaK
          korttomaK
          korttoma
          @sparky60 yes, 4 inputs and 4 outputs. It should be easy to modify if you need a different amount.
          • Tomas
