  3. Domoticz
  4. Handling push buttons events
3 Posts 2 Posters 2.6k Views 2 Watching
  • N
    N
    napo7
    wrote on last edited by napo7
    Hi !
    I'm planning to drive lights with my MySensors devices :
    I have some Mysensors devices with 8 light outputs (dimmers boards and relay boards),
    and I have some Mysensors devices with 8 push button inputs.
    I'm used to have 3 functions on the same button with my previous home automation system :
    I have the "short press" event, "long press begining" event, and the "long press release" event.
    Using these events, I usually set different actions on short press events and on long press begin events.
    This allows me , i.e., to drive 2 differents lights with the same button, or to set a dim level with a long press, and an ON/OFF command on a short press.
    How should I define my Mysensors devices to return the short press/long press/release events , that can be handled by domoticz ?
    What would be the best way to handle those kind of events in Domoticz ?
    Perhaps using the "V_TEXT" subdevice type could allow me to report differents events "PULSE/HOLD/RELEASE", but I suppose then I'll have to use nothing else but scripts to handle these on domoticz ?
    AWIA 1 Reply Last reply
    • N napo7
      Hi !
      AWIA
      AWIA
      AWI
      @napo7 I am doing something similar. At first I tried to have Domoticz handle the short/long keypresses. Not very succesfull because of timing. i.e. I was not able to get dimming realiable. In my case I have the actuator (key fob) time the key-press and send the dimming level. As there is no up/down dimming command I use the V_UP/ V_DOWN of the S_COVER.
      • N
        N
        napo7
        Handling the short press/long press/release by the arduino is quite easy.
        I can already send a different event regarding what happens on each button, but the event has to be handled by domoticz ;)
        Previously, I was using a custom-made software for all my home automation.
        I handled the thing like this :
        When event is "pulse" :
        if timer is OFF and light is OFF :
        - Turn a timer ON for 5 seconds.
        - Turn light to 1st dim level (levels are 2, 5, 10, 30, 50 and 100%)
        if light is ON and timer is ON :
        • Reset timer to 5s.
        • Turn light to next dim level
          If light is ON but timer is OFF :
        • Turn light OFF
        when event is "hold" :
        -do another action (ie. turn on/off another light)...
        That was working corretly, I did put this script in a function that I could reuse for each light easily, but it was my own home automation system software, and now I want to turn to another system, no more time to fix/enhance my own software !
