  3. Which thumbwheel switch would be more fantastic ?
15 Posts 8 Posters 4.4k Views 7 Watching
  • K
    K
    kynix
    Banned
    wrote on last edited by hek
    Thumbwheel switch can be seen anywhere, especially it can be connected to cars and when driving, thumbwheel switch has become an indispensable part. I am going to buy a new thumbwheel switch to make my car refresh so I went to a retailing shop, satisfied with two thumbwheel switches. I am puzzled about that, so I come to this forum to turn to you to discuss which one would be more fantastic.
    Here are two thumbwheel switches offered for you to choose from:
    One is A7BS-207
    SPECIFICATIONS:
    Termination-Style: Card Edge/Solder Pad with Component Mounting
    Mounting-Type: Panel Mount, Snap-In
    Features:
    Actuator-Type: Pushwheel
    Contact-Material: -
    Contact-Finish: -
    Number-of-Positions: 10 Position
    Panel-Cutout-Dimensions: -
    Contact-Rating-Voltage: 0.1A @ 50VAC/28VDC
    Output-Code: BCD
    Read-Out: 0 ~ 9
    Number-of-Sections: 1
    Display-Characters-Height: 0.189" (4.80mm)
    End-Caps: Sold Separately
    Section-Width: 0.315" (8.00mm)
    Actuator: Thumbwheel
    Wide Range of Locking-type
    Models Available
    • Character height of 4.8 or 3.2 mm makes for easy-to view display.
    • Installation is easy with snap-in mounting.
    • The series includes a complete range of locking-type models that prevent accidental operation.
    The other is PICOD131AK2
    The PICOD family offers small panel-mounted pushwheel code switches, ideally suited for high density applications. They are used for the controlling and programming of frequency synthesizers, counters and timers, data comparators, security encoders, weighing machines, etc. The dependable pushbutton action allows narrow 0.3 inch width on panel. Changes to higher or lower settings are accomplished rapidly by successive operation of the appropriate buttons. The featherweight PICOD is less than 0.6 inch high, yet
    rugged enough for hand-held and portable instruments that may be subjected to field abuse. Heavy gold plating on wiping contacts affords low contact resistance for reliable operation over long periods of service. Easy-to-read characters are viewed through dust-sealed window. Installation costs are minimized by snap together design – no inconvenient hardware.
    SPECIFICATIONS:
    features:
    Contact-Material: Copper Alloy
    Contact-Finish: Gold
    Contact-Rating-Voltage: 0.1A @ 40VAC/DC
    Output-Code: BCD
    Read-Out: 0 ~ 9
    Display-Characters-Height: 0.122" (3.10mm)
    Section-Width: 0.300" (7.62mm)
    I have been puzzled about which thumbwheel switch would be more fantastic. As far as I am concerned, I would consider the A7BS-207 as it looks very light and easy to mount. What is your idea ? Do you agree with my ideas ? Any of your ideas would be highly appreciated.
    May someone would like to help ?
    thanks in advance.
    YveauxY 1 Reply Last reply
    • K kynix
      One is A7BS-207
      SPECIFICATIONS:
      Features:
      Contact-Material: -
      Contact-Finish: -
      Output-Code: BCD
      Read-Out: 0 ~ 9
      Models Available
      SPECIFICATIONS:
      features:
      Output-Code: BCD
      Read-Out: 0 ~ 9
      thanks in advance.
      YveauxY
      YveauxY
      This post is deleted!
      K 1 Reply Last reply
      • YveauxY Yveaux
        [[topic:post-is-deleted]]
        K
        K
        kynix
        Banned
        @Yveaux Thanks for your comment. I would definately and confidently choose the first one. thank you very much.
        • K
          K
          kynix
          Banned
          @all What is others' opinions ? I would like to listen to others' opinions.
            @kynix,
            Why do you continue to spam this community? What's the purpose? It will only create badwill when someone searches for your ugly spamming corporation.
            https://forum.mysensors.org/topic/6090/is-there-an-easier-way-to-compare-the-voltages-of-these-two-sensors/3
            No-one will here will ever ever buy anything from you.
            P.S. Your tactics works both ways you know. Try google "Kynix" and follow the second link to your own facebook page. We'll continues associate your company name with SPAM as long as you continue doing this crap. Mo ha ha.
            • scalzS
              scalzS
              wrote on last edited by scalz
              I agree too with @hek, crappy commercial/marketing practice = :poop: company
              • YveauxY
                YveauxY
                Yeah, pretty low fooling MySensors users into a discussion... :-1:
                • K
                  K
                  kynix
                  Banned
                  Do you think your comments are bad for dignity ?
                    @kynix, you've lost already.
                    And you might wanna change your company name. It has bad associations now. And It'll take a long time to get rid that. :facepunch:
                      @kynix,
                      K
                      K
                      kynix
                      Banned
                      Nothing can change us.
                      tekkaT tbowmoT AnticimexA 3 Replies Last reply
                      • K kynix
                        tekkaT
                        tekkaT
                        tekka
                        @kynix One + 2 = ?
                        • K kynix
                          tbowmoT
                          tbowmoT
                          tbowmo
                          @kynix
                          Taken from http://www.SPAMMINGCOMPANYLINKREMOVED.com/profile :
                          Kynix Semiconductor HongKong Limited was founded in 2008, specializing in electronic components distribution business. We adhere to honesty and ethics as our business philosophy, and have gradually established an excellent reputation and credibility in our international business. With the accurate quotation, excellent credit, reasonable price, reliable quality, fast delivery, authentic service, we have won the praise of majority of customers.
                          How would you explain your posts above, when the company you seem to represent, have this on their website? Posting spam on forums doesn't rank high on any normal thinking persons ethics scale.
                            ...and they do it on all electronics forums they can find:
                            I.e.
                            https://www.infineonforums.com/threads/4698-Questions-regarding-Infineon-BTN8962
                            http://forum.basecamelectronics.com/index.php?p=/discussion/2392/encoder-missing-counts
                            :poop:
                            • K kynix
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @kynix your brand suck. All your products suck. I don't ever want to see your name here ever again. And you smell bad too.
                              • C
                                C
                                Chester
                                How many thumbs do you require to create one switch? Is there a good thumb to wheel ratio that makes for a good switch? Would you make the switch out of different wheels, say light passenger vehicle versus a late 16th century cart wheel? Would you be able to specify the amount of each type of wheel in the production of said switch? How about thumb types? Can I have one switch made from virgin female thumbs, and would it be more expensive than one made from 50 year old retired carpenter thumbs? I would have thought the carpenter thumbs would be more expensive than virgin female thumbs, as most retired carpenters have lost part of their thumb by the time they retire, so would be quite rare to obtain.
                                TL:DR, your products suck, and have been blacklisted from my stock ordering options too. So long!
