  3. receive message...
receive message...
6 Posts 3 Posters 4.0k Views 3 Watching
  • TmasterT
    TmasterT
    Tmaster
    wrote on last edited by Tmaster
    Hello . on led rgb controller or relay exemples,if you want receive a message from controller part of the code is that one :
      //When receiving a V_STATUS command, switch the light between OFF
      //and the last received dimmer value
      if ( message.type == V_STATUS ) {
        Serial.println( "V_STATUS command received..." );
    My Question is ; if i have 2 diferent relay nodes or rgb controller nodes ,how this simple "if MESSAGE IS V_STATUS or V_LIGHT " define what node refers to?
    i mean how to select with one i want to switch on or off?
    i'm a arduino fan .Even sometimes don't undestanding how to use it :P
      Node is same. But sensor may differ. You'll find sensor number in message.sensor.
      • TmasterT
        TmasterT
        Tmaster
        so the problem of try turn one sensor on and turn the other will not exist because its already on message core?
        sory about this question but in not good on code as i am on eletronics and i dont know /understand yet all the api
          Sorry, I don't understand the question.
          • TmasterT
            TmasterT
            Tmaster
            imagine i have 2 diferent arduinos with relays. i will upload the same code for both, exept the node_id .
            then i want turn node 1 on. gw send message "to the air" and both arduino get message saying "light on"
            what i can't understand yet is ,that part of code only says ; if message is v_light turn on, For example
            where is the part saying only turn relay 1 on?(differ nodes)will both relays turn on? if they have same code(exept de id)?
            • TmasterT Tmaster
              @Tmaster a node's receive function will only be called if the message is addressed to that node.
