  3. Node communication without gateway
12 Posts 5 Posters 4.7k Views 7 Watching
    A Former User
    Hello
    Is it possible to have two nodes talking to each other without having a gateway.
    I would like to build a water tank monitor (that is remotely placed) that can send info to a another node
    and tell me to turn the pump off when tank is full. Both nodes must be powered by batteries.
    Sigolhi
    H Boots33B 2 Replies Last reply
    • ? A Former User
      Hello
      Sigolhi
      H
      H
      Heizelmann
      @sigolhi I have a similar problem and started a thread about this a while ago. See here https://forum.mysensors.org/topic/6413/node-to-node-communication. It is still unclear how to do a node-to-node communication without a gateway. Even a repeater node will not help.
      • ? A Former User
        Hello
        Sigolhi
        Boots33B
        Boots33B
        Boots33
        @sigolhi Even if you can get the nodes to connect without a gateway you may still have issues trying to run them on batteries. Any node that is expecting to receive a message cannot sleep so will be rather heavy if on batteries alone. You may also need to add solar charging as well.
        H 1 Reply Last reply
        • Boots33B Boots33
          H
          H
          Heizelmann
          @Boots33 Yes, that's important, I forgot this. In my case the receiving node is line powered.
            A Former User
            Hello everyone,
            My reciever node is on a 12V offgridsystem with solarpower backup so that is not my problem.
            I only want to recieve the signal from my remote water tank (150 meters away) so i know when to shut down the pump (and power generator). Without setting up a complete network.
            • ? A Former User
              Hello everyone,
              @sigolhi MySensors isn't primarily designed for your scenario, but there is an easy workaround: Let one of the nodes be a gateway. It could be a serial gateway, or any other type.
              That's the solution I used for my arcade game.
              It is possible to connect a controller to the gateway, but the gateway won't care if you don't.
                H
                H
                Heizelmann
                wrote on last edited by Heizelmann
                @mfalkvidd I would only mention that in my scenario this is not possible. I already have a gateway and controller. As far as I know a second gateway is not allowed.
                • H Heizelmann
                  @Heizelmann Yes, there can only be one gateway per MySensors network. But it is possible to have multiple MySensors networks by using different radio channels.
                  How to set the channel depends on which transport you are using. Look for the channel setting in MyConfig.h. All nodes in one MySensors network need to use the same channel.
                  • H
                    H
                    Heizelmann
                    So it must be possible for one node to connect to two networks. Is this possible?
                    • H Heizelmann
                      @Heizelmann No. But a controller can communicate with all networks.
                        A Former User
                        Hi all, thank you for answering.
                        I will try the solution mfalkvidd proposed.
                        I'll report back when i have tried it.
                        Sigolhi
                        berkseoB 1 Reply Last reply
                        • ? A Former User
                          Sigolhi
                          berkseoB
                          berkseoB
                          berkseo
                          wrote on last edited by berkseo
                          @sigolhi
                          Yes, communication between two nodes is possible without a controller and gateway. I do this. And I tie them to each other in the air, it is not necessary to prescribe in the sketches. See my videos in this topic. Carefully look :)
                          Master - Slave Сommunication | Micro Network
