  3. RPI Gateway Error
RPI Gateway Error
gateway
5 Posts 3 Posters 828 Views 2 Watching
  • hakha4H
    hakha4H
    hakha4
    Hi!
    I'm using a rpi gw with nrf24 in combination with Domoticz,worked ok until upgrading Domoticz that must have debian buster to work! Now it is impossible to build the gw , I have tried a number of times with fresh debian installs. and different pi's
    1. when doing 'make' a number of warnings but no errors : one example see below
    ./core/MyMessage.cpp:284:17: warning: ‘char strncpy(char*, const char*, size_t ’ output may be truncated copying between 0 and 25 bytes from a string of length 25 [-Wstringop-truncation]
    (void)strncpy(buffer, this->data, this->getLength());
    In member function ‘char* MyMessage::getString(char*) const’,*
    1. output from test :
    Mar 25 10:59:23 INFO Starting gateway...
    Mar 25 10:59:23 INFO Protocol version - 2.3.2
    Mar 25 10:59:23 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=255,VER=2.3.2
    Mar 25 10:59:23 DEBUG TSF:LRT:OK
    Mar 25 10:59:23 DEBUG TSM:INIT
    Mar 25 10:59:23 DEBUG TSF:WUR:MS=0
    Mar 25 10:59:23 DEBUG !TSM:INIT:TSP FAIL
    Mar 25 10:59:23 DEBUG TSM:FAIL:CNT=1
    Mar 25 10:59:23 DEBUG TSM:FAIL:DIS
    Mar 25 10:59:23 DEBUG TSF:TDI:TSL
    Mar 25 10:59:33 DEBUG TSM:FAIL:RE-INIT
    Mar 25 10:59:33 DEBUG TSM:INIT
    Mar 25 10:59:33 DEBUG !TSM:INIT:TSP FAIL
    Mar 25 10:59:33 DEBUG TSM:FAIL:CNT=2
    Mar 25 10:59:33 DEBUG TSM:FAIL:DIS
    Mar 25 10:59:33 DEBUG TSF:TDI:TSL
    ^CMar 25 10:59:38 NOTICE Received SIGINT
    I am using an adapter (https://oshpark.com/shared_projects/aXLXBO3f) so pinout is ok.
    Configuration :
    ./configure --my-transport=rf24 --my-rf24-irq-pin=18 --my-gateway=ethernet --my-port=5003 --my-leds-err-pin=11 --my-leds-rx-pin=13 --my-leds-tx-pin=15
    (tried with just ./configure --my-transport=rf24, same result)
    Software/hardware:
    debian ver 10.3 (with SPI enabled)
    processor : 0
    model name : ARMv7 Processor rev 5 (v7l)
    BogoMIPS : 38.40
    Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
    CPU implementer : 0x41
    CPU architecture: 7
    CPU variant : 0x0
    CPU part : 0xc07
    CPU revision : 5
    processor : 1
    BogoMIPS : 38.40
    CPU architecture: 7
    CPU variant : 0x0
    CPU part : 0xc07
    CPU revision : 5
    processor : 2
    BogoMIPS : 38.40
    CPU architecture: 7
    CPU variant : 0x0
    CPU part : 0xc07
    CPU revision : 5
    processor : 3
    BogoMIPS : 38.40
    CPU architecture: 7
    CPU variant : 0x0
    CPU part : 0xc07
    CPU revision : 5
    Hardware : BCM2835
    Revision : a01041
    Serial : 000000004831d281
    Model : Raspberry Pi 2 Model B Rev 1.1
    Compiler : gcc (Raspbian 8.3.0-6+rpi1) 8.3.0
    Is there a known problem with latest debian Buster ?
    I'm going nut's and have run out of ideas how to solve this
    Sorry for this long text, but wanted to give as much information as possible.
    Any help appreciated!
    • hakha4H hakha4
      Hi!
      Configuration :
      Software/hardware:
      processor : 0
      BogoMIPS : 38.40
      CPU architecture: 7
      CPU variant : 0x0
      CPU part : 0xc07
      CPU revision : 5
      processor : 1
      BogoMIPS : 38.40
      CPU architecture: 7
      CPU variant : 0x0
      CPU part : 0xc07
      CPU revision : 5
      processor : 2
      BogoMIPS : 38.40
      CPU architecture: 7
      CPU variant : 0x0
      CPU part : 0xc07
      CPU revision : 5
      processor : 3
      BogoMIPS : 38.40
      CPU architecture: 7
      CPU variant : 0x0
      CPU part : 0xc07
      CPU revision : 5
      Hardware : BCM2835
      Revision : a01041
      zboblamontZ
      zboblamontZ
      zboblamont
      @hakha4 Domoticz flaked on update with my Buster on the Pi Controller, updated Buster and all fixed.
      • hakha4H
        hakha4H
        hakha4
        I have updated Buster and Domoticz works ok but can't get the gw to work. Btw is it normal (ok) to get a number of warnings when compiling??
        C 1 Reply Last reply
        • hakha4H hakha4
          C
          C
          cvdenzen
          @hakha4 said in RPI Gateway Error:
          I am getting the same warnings (about string truncation), that doesn't make it "normal", but I have a working gateway in Buster on my raspberry pi (raspbian). The error is about the radio. You have a rf24, I use a rfm69, so that is quite different.
          Another difference is the gateway version. Mine is using protocol version 2.4.0-alpha:
          Apr 29 22:12:35 INFO  Starting gateway...
          Apr 29 22:12:35 INFO  Protocol version - 2.4.0-alpha
          Apr 29 22:12:35 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
          Apr 29 22:12:35 DEBUG TSF:LRT:OK
          Apr 29 22:12:35 DEBUG TSM:INIT
          Apr 29 22:12:35 DEBUG TSF:WUR:MS=0
          Apr 29 22:12:35 DEBUG TSM:INIT:TSP OK
          Apr 29 22:12:35 DEBUG TSM:INIT:GW MODE
          Apr 29 22:12:35 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
          Apr 29 22:12:35 DEBUG MCO:REG:NOT NEEDED
          Apr 29 22:12:35 DEBUG MCO:BGN:STP
          Apr 29 22:12:35 DEBUG MCO:BGN:INIT OK,TSP=1
          Apr 29 22:12:35 DEBUG GWT:RMQ:CONNECTING...
          Apr 29 22:12:35 DEBUG connected to 127.0.0.1
          Apr 29 22:12:35 DEBUG GWT:RMQ:OK
          Apr 29 22:12:35 DEBUG GWT:TPS:TOPIC=mysensors/all/0/255/0/0/18,MSG SENT
          Apr 29 22:12:35 DEBUG TSM:READY:NWD REQ
          Apr 29 22:12:35 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
          Apr 29 22:12:40 DEBUG TSF:MSG:READ,153-153-0,s=4,c=1,t=23,pt=0,l=4,sg=0:3.75
          Apr 29 22:12:40 DEBUG GWT:TPS:TOPIC=mysensors/all/153/4/1/0/23,MSG SENT
          I am using this version of MySensors (branch development):
          git status
          On branch development
          Your branch is up to date with 'origin/development'.
          The last commits that I have are:
          git log
          commit 397b70f37b4fc5ffd15dddf49364cce2408e5bb5 (HEAD -> development, origin/development, origin/HEAD)
          Author: Henrik Ekblad <henrik.ekblad@gmail.com>
          Date:   Mon Jan 6 15:47:04 2020 +0100
              Fix logparser frequency regexp (#1380)
          commit 9040272ccbf57026780ed10f589a5498db729ae9
          Author: Olivier <tekka007@users.noreply.github.com>
          Date:   Mon Dec 9 22:43:02 2019 +0100
              Development version 2.4.0-alpha (#1373)
          So maybe you can try this newer development branch to build your gateway.
          • hakha4H
            hakha4H
            hakha4
            Hi! Thank's for info. I had almost given up and now using an ESP GW instead but I'll give your setup a try:+1:
