  3. Random Sensor Readings
5 Posts 4 Posters 2.1k Views 2 Watching
  • D
    diggs
    Hi all,
    Not sure if this a domoticz or mysensor issue. Every once in a while I will get a random temp reading on my graph and I am not sure exactly how to go about tracking down the issue, so any advice appreciated. The sensor being used is a DS18B20 on a serial gateway to a PI. Normally if I lose radio connection the sensor data will flatline so the issue must be somewhere else. In this case it has dropped to zero degrees.
    upload-bfbfd0de-d9ac-47e1-9880-a3b039be0be4
    AWIA 1 Reply Last reply
    • D diggs
      Hi all,
      AWIA
      AWIA
      AWI
      @diggs my blind conclusion would be that your sensor node is sending the wrong value. i.e. that it doesn't read the right (or no) value from the DS18B20..
      • F
        F
        fleinze
        @diggs: This is definitely the sensor sending zero degree. I think a digital reading of zero also corresponds to 0 degree C.
        • R
          R
          robosensor
          Dallas sensor reading code contains CRC checksum validation, so invalid readings from sensor should be skipped.
          • D
            diggs
            Thanks for the input all
            I might put two sensors together and see what transpires to see if I can narrow things down a bit and see if it is specifically a sensor issue or the controller.
