  3. My sensorboard MYS 1.0beta
121 Posts 44 Posters 114.0k Views 13 Watching
  • HeinzH
    HeinzH
    Heinz
    @hek ah ok I see. Well that sounds reasonable to me. That could explain why a repeater node did not work with a nano but with an uno ... Thanx alot
      Mrlynx
      @NewFolk how are you powering your node and gateway?
      battery, USB or wallwart?
      Try changing powersource and see if it helps.
      I have had som problem with nrf24L01+ clones that did not work well on highest powerlevels but worked better on RF_PA_HIGH.
      http://www.sa2avr.se
      • N
        N
        NewFolk
        wrote on last edited by NewFolk
        #114
        @Mrlynx
        I power node on MYS board from iPhone wall and with USB through FTDI both give me the same 3.324 on 3.3 pin.
        And GW is powered thought RPI USB - original UNO / clone nano 5v - Adapter Board NRF24L01+ http://www.ebay.com/itm/200960749614?rmvSB=true
        I have just tried to move antenna radio to node and simple radio to GW and it`s work.
        Bud it bad workaround.
        PS will try to change node and GW to RF_PA_HIGH
        edit: change to hight and i saw same ok status. Then I change to
        #define RF24_PA_LEVEL 	   RF24_PA_LOW
        And get 3 successful initialization in a row. So I will test tonight with DHT22.
        Thank you
          smokey1300
          wrote on last edited by smokey1300
          #115
          Ordered 5 kits today looking forward to getting started. For the NRF24L01 you don't need a 4.7uf capacitor anymore?
            Mrlynx
            @smokey1300 I will pack them right away.
            I have not found that a cap is making any difference on the radio modules I bought.
            S 1 Reply Last reply
            • M Mrlynx
              smokey1300
              #117
              @Mrlynx I was thinking of 3v battery powering at least 2 of the boards. My sensors will be DHT11 and 18B20. Can you suggest any simple ways to conserve power on the circuit? Would it be better to just add a external boosting regulator for instance?
                Mrlynx
                @smokey1300 My best tip is to remove led and regulator off the arduino. Then use 3xAA batteries connected to VCC on MYS.
                • N
                  N
                  Nicola Reina
                  Anybody wanting 10 kits at a bargain price. I am sellling them at bargain price due to lack of time to play with them.
                  If you are in Rome I can hand it over directly . If you are at EU maker faire this week end even better see you there.
                  Otherwise I ship them too
                  KR
                  J 1 Reply Last reply
                  • N Nicola Reina
                    KR
                    J
                    J
                    jeti
                    KR
                    Still got the 10Kits?
                    • J jeti
                      KR
                      Mrlynx
                      KR
                      You can still buy these kits from my homepage.
