  3. 💬 Easy/Newbie PCB for MySensors
mysensorsbatteryeasynewbiepcbmysx
716 Posts 111 Posters 681.8k Views 93 Watching
    In that case you could also go for rs485 bus. Voltage sources could be also 7 or 9v since you will be using the internal regulator anyway. Most sensor can operate at 5v too, so you don't actually need 3.3v. Optimizing for battery isn't that bad too. Since you are powering the nodes you could also use esp8266 nodes
    • sundberg84S sundberg84
      @Tommas 5v + 3.3v pro mini there is no example for this. Add your 3.3v pro mini and radio. Connect 5v to raw and put a jumper/connect both reg and bat.
      If you want to use to for 2xaa please follow the example.
      Tommas
      Dear @sundberg84
      If i use 5V regulated example, has it got 3.3V output for the sensors?
      dbemowskD 1 Reply Last reply
        if you install the voltage regulator in the top left area, you will have the 3.3v ( if I got your question right)
        T 1 Reply Last reply
          Tommas
          @gohan
          Oh OK! Thank you! The decision is hard for me, which solution i should use:) .
          • T Tommas
            Dear @sundberg84
            dbemowskD
            dbemowskD
            @Tommas If you are using 5 volts in and not using a 3.3v pro mini that has the 3.3v regulated output, then you have to add a TO92 case style 3.3v regulator and two capacitors to the board. Here are some that should work. Whatever one you get, make sure you check the pinout against the markings on the board as not all regulators have the same pinout.
            http://www.mouser.com/Semiconductors/Power-Management-ICs/LDO-Voltage-Regulators/_/N-5cgac?P=1z0y3jsZ1z0wa2e&pop=88zz
            • dbemowskD dbemowsk
              Tommas
              Dear @dbemowsk
              I bought these: https://www.ebay.com/itm/401088383355
              Thank you!
              • T Tommas
                Dear @dbemowsk
                Thank you!
                #427
                @Tommas - this is the voltage regulator that the board is designed for so the markings/pinout will be right for you. If you put 5v on the PCB input and use 3.3v pro mini though, the only choise you have is to put 5v on RAW and let the onboard voltage regulator on the PCB regulate it down to 3.3v. The voltage regulator on the PCB only regulate the voltage to the radio and are meant for a 5v input on a 5v pro mini. Using raw means there is no need for the LE33.
                  @keldandorin - are you using a booster as mentioned above?
                  The problem is in that case noice introduces in the radio from the booster (a known issue). I will in the future try to buy me a oscilloscope and diagnose more... but for now, if you add a "bad/cheap" booster it will be this problem. 2.8v sounds really bad though, and most likley a really bad clone.
                  You have two options.
                  1. Try another booster, and/or try to filter with capacitors.
                  2. Load a new bootloader that can handle lower voltages accoring to link above.
                  Let me know if I can assist you in any way.
                  keldandorinK
                  keldandorinK
                  keldandorin
                  @sundberg84 Is there any way to say if booster is a bad one or not before ordering them?
                  The one I ordered was the one on shoping list from aliexpress. Will try I capacitator and see if I can get a new booster from kjell&Comany tomorrow just to try. Build a setup on bread bord where I powered radio with 2 AA and got the same result. Got a fju places where I like to put some sensors with no power so realy need to get this working :). Could the radiomodules be bad to?
                    Bad quality from cheap Chinese suppliers, is always an option 😁
                    • keldandorinK keldandorin
                      @keldandorin - could be a weak clone radio yes.
                      Just to get your hopes up, I got booster driven nodes all around the place with Nrf24l01+ radio and they works great!
                      I change battery every 1-1.5 years but as I said, the experience is that the radio - booster needs a good teamwork :)
                      keldandorinK 1 Reply Last reply
                        keldandorinK
                        keldandorinK
                        keldandorin
                        wrote on last edited by keldandorin
                        #431
                        @sundberg84 Sounds good, Thats what I'm looking for. Have never worked with tinkers like this befor so everything is new. But this place is great thx for taking time.
                        • pellusfromtellusP
                          pellusfromtellusP
                          pellusfromtellus
                          Sorry, I'm a bit slow and maybe a little off-topic: A quicky:
                          Can I read somewhere how payment is done when ordering from openhardware.io? On the start page for openhardware.io there is no clue. I've also tried to search this section (easy-newbie-pcb-for-mysensors) for "payment".
                          Yes, I've read that the "order" is more like a forward of orderinformation to the supplier, but do I really need to order first and after that ask what payment solution is present?
                          A complete rookie! Love this stuff! My path: Domoticz/Zwave and now a big MySensors-fan! :)
                          • pellusfromtellusP pellusfromtellus
                            @pellusfromtellus - to get a 100% right answer we ping @hek but I recommend paypal!
                              @pellusfromtellus
                              I think most of them handle paypal/card. You can press the "Order" button to find out. Nothing is binding until payment has been done.
                              • Paul RobertsonP
                                Paul RobertsonP
                                Paul Robertson
                                Is there a drilling and outline file available?
                                • Paul RobertsonP Paul Robertson
                                  @Paul-Robertson - hi!
                                  Yes, but this is Eagles output gerber files.
                                  Drill: SundbergMys9.TXT
                                  Outline can be found in all other files:
                                  https://www.pcbway.com/project/share/How_to_generate_Gerber_from_Eagle.html
                                  0_1505990995661_upload-c5e3c1d3-3dfb-46dc-9e10-e2d5dbfaca0d
                                  • sinczeS
                                    sinczeS
                                    sincze
                                    MySensors Evangelist
                                    Damn. Just missing the 0,1uF capacitor ..... to complete the 5v build. This will be my smallest build yet ;-) using PCB v9
                                    • sinczeS sincze
                                      dbemowskD
                                      dbemowskD
                                      This post is deleted!
                                      • H
                                        H
                                        hiddenuser
                                        IS it possible to use TP4056 (https://www.aliexpress.com/item/5-pcs-Micro-USB-5V-1A-18650-TP4056-Lithium-Battery-Charger-Module-Charging-Board-With-Protection/32728720869.html?spm=a2g0s.9042311.0.0.A0lkC7) this instead of using the step up booster?
                                        Thanks!!
                                          If you want to use a lipo battery, you need a voltage regulator
