  3. 💬 Easy/Newbie PCB for MySensors
mysensorsbatteryeasynewbiepcbmysx
716 Posts 111 Posters 681.8k Views 93 Watching
    I don't think it is PCB related, try to make sure it is not a faulty arduino
    Mr_sensor
    @gohan said in 💬 Easy/Newbie PCB for MySensors:
    I already changed the arduino for a fresh soldered one but that did not alter things.
    • M Mr_sensor
      @sundberg84 Hi, I soldered a board holding a humidity and temperature sensor. That is working fine and reporting to may gateway (mqtt). Only thing which I do not get working ok is the battery level measurement. As I already posted in an other topic here.
      Here are some pictures of my board. The bat jumper is connected with a wire on the bottom. And the code I use on it right now.
      I already changed the pro mini for a fresh soldered one but still getting the the same result. Just ones giving the volt and % and after that only giving 0 volt as output.
      tried to include delay(500) in the sketch but that did not help. So how to solve this?
      #define MY_NODE_ID 2
      #define MY_PARENT_NODE_ID 0
      // Enable debug prints
      //#define MY_RS485
      #include <SparkFunHTU21D.h>
      #include <Wire.h>
      //static const uint8_t FORCE_UPDATE_N_READS = 10;
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define CHILD_ID_BATTERY 2
      //#define CHILD_ID_VOLT 2
      #define CHILD_ID_PRCNT 3
      float lastTemp;
      float lastHum;
      uint8_t nNoUpdatesTemp;
      uint8_t nNoUpdatesHum;
      boolean metric = true;
        sendSketchInfo("Humidity", "2.0");
        present(CHILD_ID_HUM, S_HUM);
         present(CHILD_ID_BATTERY, S_MULTIMETER);
        //metric = getControllerConfig().isMetric;
      unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
      static int oldBatteryPcnt = 0;
      //Create an instance of the object
      HTU21D myHumidity;
      MyMessage msgBattery(CHILD_ID_BATTERY, V_VOLTAGE);
      //MyMessage msgBattery(CHILD_ID_BATTERY, V_PRCNT);
          myHumidity.begin();
          analogReference(INTERNAL1V1);
      #else
          analogReference(INTERNAL);
        float temperature = myHumidity.readTemperature();
        //if (!metric) {
        //    temperature = (temperature * 1.8) + 32.0;
        Serial.print("T: ");
        Serial.println(temperature);
        float humidity = myHumidity.readHumidity();
        Serial.print("H: ");
        Serial.println(humidity);
         // get the battery Voltage
          delay(500);
      #ifdef MY_DEBUG
          Serial.println(sensorValue);
      #ifdef MY_DEBUG
          float batteryV  = sensorValue * 0.003363075;
          Serial.print("Child ID ");
          Serial.print(CHILD_ID_BATTERY);
          Serial.print(batteryV);
          Serial.println(" V");
          Serial.print("Battery Percent: ");
          Serial.print(batteryPcnt);
          Serial.println(" %");
              // Power up radio after sleep
              oldBatteryPcnt = batteryPcnt;
        sleep(SLEEP_TIME); //sleep a bit
      0_1518613859739_IMG_5970.jpg 0_1518613878092_IMG_5971.jpg 0_1518613893620_IMG_5972.jpg 1_1518613931939_IMG_5907.jpg 0_1518613931939_IMG_5906.jpg 0_1518613977125_IMG_5908.jpg
      @mr_sensor - I can not see any errors on the pictures you posted.
      Can you measure the voltage on Booster-Vout and also on this pad.
      M 1 Reply Last reply
      • sundberg84S sundberg84
        Mr_sensor
        @sundberg84 said in 💬 Easy/Newbie PCB for MySensors:
        I did measure the parts you mentioned. Booster is 3,36 v and the other pad is 0,00 the input strait from the batteries is 2,80 v
        Also, Just for my info, does it matter how the resistors or capacitors are soldered on the board? My biggest problem is always determine the right resistors value and the right way to solder them (+ -). On the pcb some of them are coded (very handy for me as a beginner) with a G but not all of them?
        So my worry was that I maybe have soldered the "battery measurer" ones in the wring direction? Could that be the problem here?
          Resistors can be soldered either way, but if you read 0v on that capacitor pin it mean you have a problem between the battery and the capacitor, so you have to backtrack the connection that is missing
            Mr_sensor
            I measured the capacitor again and get a 0,10 output.
              What are the resistor values you used? 0.1v is quite low
                Mr_sensor
                Maybe I used the wrong capacitor it says 1uf (50v) but now I see it has to be 0,1uf could that be the problem here?
                • sundberg84S
                  #508
                  Capacitor value does not change the voltage. The resistors does... I would double check that you use the right resistors. For example it's easy to use a resistor marked 1k instead of 1M. With 3.3v you should have around 1v on the capacitor.
                    you are also missing the capacitor on the booster output for better stability
                      Mr_sensor
                      Ok, I assumed it was not needed when using a battery. Which one to use there?
                        It is needed if you use a booster. Look at project page for details.
                        • M Mr_sensor
                          @mr_sensor a advice is to measure the resistance again over the resistors.
                            Mr_sensor
                            @sundberg84 Well I tried that but did not get the measurement straight from the pcb si I decided t solder a new board using the right capacitor this time (0,1uf instead of 1uf) made sure using the right resistors as well and adding a capacitor after the booster. Than with the same mini pro from the other board tested again and wow it is working as intended.
                            Child ID 2Battery Voltage: 3.44 V
                            Battery Percent: 102 %
                            2930 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:102
                            2938 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            2945 TSF:TDI:TSL
                            2947 MCO:SLP:WUP=-1
                            2949 TSF:TRI:TSB
                            3065 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            T: 998.00
                            3178 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            H: 998.00
                            957
                            Child ID 2Battery Voltage: 3.22 V
                            Battery Percent: 95 %
                            3690 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                            3698 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            3704 TSF:TDI:TSL
                            3706 MCO:SLP:WUP=-1
                            3708 TSF:TRI:TSB
                            3815 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            T: 998.00
                            3932 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            H: 998.00
                            955
                            Child ID 2Battery Voltage: 3.21 V
                            4442 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            4452 TSF:TDI:TSL
                            4454 MCO:SLP:WUP=-1
                            4456 TSF:TRI:TSB
                            4560 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            T: 998.00
                            4673 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            H: 998.00
                            953
                            5185 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            5193 TSF:TDI:TSL
                            5195 MCO:SLP:WUP=-1
                            5197 TSF:TRI:TSB
                            5304 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            T: 998.00
                            5416 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            H: 998.00
                            952
                            Child ID 2Battery Voltage: 3.20 V
                            5926 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            5935 TSF:TDI:TSL
                            5939 MCO:SLP:WUP=-1
                            5941 TSF:TRI:TSB
                            6045 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            T: 998.00
                            6158 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            H: 998.00
                            952
                            6670 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            6678 TSF:TDI:TSL
                            6680 MCO:SLP:WUP=-1
                            6682 TSF:TRI:TSB
                            6789 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            T: 998.00
                            6901 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            H: 998.00
                            952
                            7411 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            7419 TSF:TDI:TSL
                            7424 MCO:SLP:WUP=-1
                            7426 TSF:TRI:TSB
                            7530 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            T: 998.00
                            7643 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            H: 998.00
                            952
                            8155 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            8163 TSF:TDI:TSL
                            8165 MCO:SLP:WUP=-1
                            8167 TSF:TRI:TSB
                            8273 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            T: 998.00
                            8388 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            H: 998.00
                            955
                            8898 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            8908 TSF:TDI:TSL
                            8910 MCO:SLP:WUP=-1
                            8912 TSF:TRI:TSB
                            9021 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            T: 998.00
                            9132 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            H: 998.00
                            948
                            Child ID 2Battery Voltage: 3.19 V
                            Battery Percent: 94 %
                            9646 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:94
                            9654 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            9660 TSF:TDI:TSL
                            9662 MCO:SLP:WUP=-1
                            9664 TSF:TRI:TSB
                            9771 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            T: 998.00
                            9881 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            H: 998.00
                            952
                            10395 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
                            10403 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            10409 TSF:TDI:TSL
                            10412 MCO:SLP:WUP=-1
                            10414 TSF:TRI:TSB
                            10520 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            T: 998.00
                            10635 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
                            H: 998.00
                            953
                            11147 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            11155 TSF:TDI:TSL
                            Now in mqtt I can see the percentage as:
                            95
                            qos : 0, retain : false, cmd : publish, dup : false, topic : **mygateway1-out/2/255/3/0/0**, messageId : , length : 30, Raw payload : 5753```
                            But not the voltage?
                            • M Mr_sensor
                              2945 TSF:TDI:TSL
                              2947 MCO:SLP:WUP=-1
                              2949 TSF:TRI:TSB
                              T: 998.00
                              H: 998.00
                              957
                              3704 TSF:TDI:TSL
                              3706 MCO:SLP:WUP=-1
                              3708 TSF:TRI:TSB
                              T: 998.00
                              H: 998.00
                              955
                              4452 TSF:TDI:TSL
                              4454 MCO:SLP:WUP=-1
                              4456 TSF:TRI:TSB
                              T: 998.00
                              H: 998.00
                              953
                              5193 TSF:TDI:TSL
                              5195 MCO:SLP:WUP=-1
                              5197 TSF:TRI:TSB
                              T: 998.00
                              H: 998.00
                              952
                              5935 TSF:TDI:TSL
                              5939 MCO:SLP:WUP=-1
                              5941 TSF:TRI:TSB
                              T: 998.00
                              H: 998.00
                              952
                              6678 TSF:TDI:TSL
                              6680 MCO:SLP:WUP=-1
                              6682 TSF:TRI:TSB
                              T: 998.00
                              H: 998.00
                              952
                              7419 TSF:TDI:TSL
                              7424 MCO:SLP:WUP=-1
                              7426 TSF:TRI:TSB
                              T: 998.00
                              H: 998.00
                              952
                              8163 TSF:TDI:TSL
                              8165 MCO:SLP:WUP=-1
                              8167 TSF:TRI:TSB
                              T: 998.00
                              H: 998.00
                              955
                              8908 TSF:TDI:TSL
                              8910 MCO:SLP:WUP=-1
                              8912 TSF:TRI:TSB
                              T: 998.00
                              H: 998.00
                              948
                              9660 TSF:TDI:TSL
                              9662 MCO:SLP:WUP=-1
                              9664 TSF:TRI:TSB
                              T: 998.00
                              H: 998.00
                              952
                              10409 TSF:TDI:TSL
                              10414 TSF:TRI:TSB
                              T: 998.00
                              H: 998.00
                              953
                              11155 TSF:TDI:TSL
                              95
                              @mr_sensor good to hear its working.
                              It looks like you are only sending the % and not the voltage?
                              • D
                                D
                                dakipro
                                @Mr_sensor It happened to me once that capacitor was just shortening the circuit, it was a smd, but when I removed it and tested it it was constantly making shortage, thus the circuit was never working and luckily my power supply had a low enough protection.
                                I examined cap very closely, all looked fine, but internally it was not working fine.
                                Since most of us (well, me at least) are buying cheap components I made it a habit now to always measure every passive component before installation, partly eliminates one variable
                                • sundberg84S
                                  #516
                                  A short sneak-peak on the upcoming revision...
                                  Still a long way to go...
                                  Rev 10 - Nrf24l01+ ed.
                                  • Completley redesigned in KiCad.
                                  • MysX location changed to accept more MysX boards and align like RFM version.
                                  • Optional signing added
                                  • Optional SPI flash added.
                                  • Extra pins aligned to 2.45 vertical & horisontal
                                  • Relocated Extra + Bat Measurer some to allow more space to booster
                                  • Changed pull-up resistor from D3 to D5 to have one more pin for Interrupt
                                  • Relocated D5 pullup, MysX and IRQ jumper some.
                                  • Changed footprint (silk-screen) on capacitor to easier show Gnd/Pos side.
                                  Need to change footprint on voltage regulator on both nrf and rfm edition back to a square and not a liniar one. (rev 9 change). Not intended to revert back.
                                  Also a bit worried the 4,7uF cap os to far away from radio.
                                  gohanG Nca78N 2 Replies Last reply
                                    Putting it underneath the nrf24 module? I know it is not a "clean solution" but there would be still be unused space under the radio module
                                      @gohan - thanks, not what I want to do - I have descided to have optional/more advanced on bottom side. This is the core idea of the PCB. I might revert back to Rev 9 footprint and squeeze it in like prev. revision.
                                        maybe a smaller footprint for ceramic instead of electrolitic?
                                          Nca78N
                                          Nca78N
                                          Please don't do like that and follow the guideline for the MYSX connector (location was already wrong in previous versions and it's a bit annoying to make MYSX boards for Easy PCB):
                                          *"The MYSX connector should be placed close to the board edge with a 100 mil spacing from all edges. The footprint has a courtyard outline to emphasize this"
                                          I agree especially with other traces to cross before reaching the radio.
