  3. ACKs... Scarce information
8 Posts 2 Posters 2.6k Views 2 Watching
    moskovskiy82
    I've read through the api, several forum topics and it is still unclear to me.
    By default acks are disabled.
    Is it a good practice to enable them on sensors with switches and dimmers?
    If yes.
    In the api it says - * if you want destination node *
    Destination node in this case is the gateway which must send the ack upon the receipt of data?
      Inter node acks is always enabled. The result is returned when calling send().
      But if you want destination node to send a ack back to the origin you must enable this manually when calling send. The end-to-end ack message appears in the incomingMessage function.
        moskovskiy82
        Strangly i have a sketch with the following
          float mq_reading = analogRead(MQ_Pin);
          if (isnan(mq_reading))
          { Serial.println("Failed mq_reading"); }
          else if (mq_reading != last_mq_reading)
          { last_mq_reading = mq_reading;
            gw.send(msgMQ.set(mq_reading, 1));
        And on the controller (MQTT client gateway on NODEMcu) i never see ACK enabled
        mygateway1-out/71/6/1/0/37 309.0
          I don't understand, could you rephrase?
            moskovskiy82
            On one of my nodes i have ack message set for the MQ sensor as can be seen in the code
            On the controller (Openhab) i see the message like
            This sensor conencts to the MQTT client gateway and the structure of MQTT is supposed to be
            MY_MQTT_PUBLISH_TOPIC_PREFIX/FROM-NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
            So shouldn't the message have 1 before 37 at the end like below?
            mygateway1-out/71/6/1/1/37 309.0
              To enable ack you must call:
              gw.send(msgMQ.set(mq_reading, 1), true);
                moskovskiy82
                Thank you didn't notice that it was a decimal point one.
                So is it reasonable to enable ack for switches? And leave it disabled for sensors reporting data?
                  You only need to enable if if you actually use the resulting ack message for something.
                  If you look at the RelayWithButton example you can see an example of how the local relay only get updated when the ack is received (after pressing the local button).
