  3. pir combination with working 4-relay and 4 buttons
13 Posts 3 Posters 4.0k Views 5 Watching
  • DickD
    DickD
    Dick
    I have a working 4-relay with 4 buttons project. Now I want to integrade a pir that only send the status to my Domoticz controler. I am a newbee but lerning.
    What I have now is this
    #include "Bounce2.h"
    unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds)
    #define RELAY_ON 0                      // switch around for realy HIGH/LOW state
    #define RELAY_OFF 1
    // Initialize motion message
    #define RADIO_ID 11                    // radio Id, whatever channel you assigned to
    #define noRelays 4
    const int relayPin[] = {A1, A2, A3, A0}; //  switch around pins to your desire
    const int buttonPin[] = {A5, 6, 7, 8}; //  switch around pins to your desire
    class Relay             // relay class, store all relevant data (equivalent to struct)
    public:
      int buttonPin;                    // physical pin number of button
      int relayPin;                     // physical pin number of relay
      byte oldValue;                    // last Values for key (debounce)
      boolean relayState;               // relay status (also stored in EEPROM)
    Relay Relays[noRelays];
    Bounce debouncer[noRelays];
    MyMessage msg[noRelays];
      gw.begin();
      gw.sendSketchInfo("Motion Sensor", "1.0");
      gw.present(CHILD_ID, S_MOTION);
      gw.begin(incomingMessage, RADIO_ID, true);
      delay(250);
      gw.sendSketchInfo("Multy-Relay&Pulsanti", "0.2");
      delay(250);
      // Initialize Relays with corresponding buttons
      for (int i = 0; i < noRelays; i++)
        Relays[i].buttonPin = buttonPin[i];              // assign physical pins
        Relays[i].relayPin = relayPin[i];
        msg[i].sensor = i;                                   // initialize messages
        msg[i].type = V_LIGHT;
        debouncer[i] = Bounce();                        // initialize debouncer
        debouncer[i].attach(buttonPin[i]);
        debouncer[i].interval(5);
        pinMode(Relays[i].buttonPin, INPUT_PULLUP);
        Relays[i].relayState = gw.loadState(i);                               // retrieve last values from EEPROM
        digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
        gw.send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
        gw.present(i, S_LIGHT);                               // present sensor to gateway
        delay(250);
      // Read digital motion value
      Serial.println(tripped);
      gw.send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
      gw.process();
      for (byte i = 0; i < noRelays; i++)
        debouncer[i].update();
        byte value = debouncer[i].read();
        if (value != Relays[i].oldValue && value == 0)
          gw.saveState( i, Relays[i].relayState );
        }                 // save sensor state in EEPROM (location == sensor number)
        Relays[i].oldValue = value;
    // process incoming message
      if (message.type == V_LIGHT)
        if (message.sensor < noRelays)            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
          digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
          gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
    During the compilation I get the next error
    _4relay:34: error: conflicting declaration 'MyMessage msg [4]'
    _4relay:16: error: 'msg' has a previous declaration as 'MyMessage msg'
    _4relay:49: error: expected unqualified-id before '{' token
    I understand that it has to do something with the MyMessage msg but don't know hoe to solve.
    Who can help me??
      You cannot declare two variables with the same name ("msg" in your case). The error message is pretty clear in this case.
      • DickD
        DickD
        Dick
        Still having problems with my combination design. This is the working 4 relais sensor:
        #define RELAY_OFF 1
        #define noRelays 4
        public:
          delay(250);
          delay(250);
            delay(250);
          gw.process();
        I try so combine it with the "motion Sensor" example from my sensors:
         * Version 1.0 - Henrik Ekblad
         * Motion Sensor example using HC-SR501
         * http://www.mysensors.org/build/motion
          gw.begin();
        Now it looks like this combined with each other without compilation errors:
        unsigned long SLEEP_TIME = 90000; // Sleep time between reports (in milliseconds)
        #define RELAY_OFF 1
        MyMessage motionmsg(CHILD_ID, V_TRIPPED);
        #define noRelays 4
        public:
          gw.begin();
          gw.sendSketchInfo("Motion Sensor", "gordijn");
          delay(250);
          gw.sendSketchInfo("Multy-Relay", "gordijn");
          delay(250);
            delay(250);
          gw.send(motionmsg.set(tripped?"1":"0"));  // Send tripped value to gw
          gw.process();
        during starting-up the sensor all relays get activated. If a movement takes place (pir active) the relays deactvate. I am not able to controle my relays with the buttons also a part of the project, disconnecting the pir and the reais works fine as well as the buttons.
        Who give it a try to solve it?
        Dick
        • DickD
          DickD
          Dick
          Can anybody help me to get this combi sensor to work?
          This is the script at this moment and during compilation I get an error:
          expected initializer before 'MyMessage'bolded text
          boolean lastmotionstate
          #define RELAY_OFF 1
          #define noRelays 4
          public:
           gw.begin();
          lastmotionstate =0;
           delay(250);
           delay(250);
             delay(250);
             if (lastmotionstate != tripped)
          lastmotionstate =tripped;
          //  gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
           gw.process();
          • DickD Dick
            #define RELAY_OFF 1
            #define noRelays 4
            public:
             gw.begin();
            lastmotionstate =0;
             delay(250);
             delay(250);
               delay(250);
             gw.process();
            @Dick looks like you are missing a ; after
            • DickD
              DickD
              Dick
              Thanks for the tip, I added the Boolean, so that is one step. No I thought it is in place but now I got a warning
              'Sleep' was not declarered in this scope
              that is strange because I declared it. Pleas advise me
              In#include <SPI.h>
              #define CHILD_ID_PIR 1
              #define RELAY_OFF 1
              #define RADIO_ID 11                // Radio Id, whatever channel you assigned to
              #define PIR_SENSOR_DIGITAL_INPUT 3     // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
              #define noRelays 4
              const int relayPin[] = {A1, A2, A3, A4}; //  switch around pins to your desire
              const int buttonPin[] = {5, 6, 7, 8}; //  switch around pins to your desire
              //unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
              public:
              boolean metric = true;
              boolean prevPIRstatus = false;
              int lastLightLevel;
              MyMessage msgPIR(CHILD_ID_PIR, V_TRIPPED);
              MyMessage msgRelays[noRelays];
                gw.begin();
                gw.sendSketchInfo("Combi PIR, Temp, Hum, 4 Relay and Switch, LDR sensor", "1.0");
                // Initialize and present Relays with corresponding buttons
                  msgRelays[i].sensor = i;                                   // initialize messages
                  msgRelays[i].type = V_LIGHT;
                  gw.send(msgRelays[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
                  delay(250);
                gw.present(CHILD_ID_PIR, S_MOTION);
                // Deal with incoming messages and when enabled repeat
                gw.process();
                // Deal with PIR
                boolean tripped = digitalRead(PIR_SENSOR_DIGITAL_INPUT) == HIGH;
                // Check if PIR Changed
                if (prevPIRstatus |= tripped) {
                  gw.send(msgPIR.set(tripped?"1":"0"));  // Send tripped value to gw
                 // prevPIRstatus = tripped; // store new value to PIR status to run update on next loop when changed
                sleep(digitalPinToInterrupt(PIR_SENSOR_DIGITAL_INPUT), CHANGE, SLEEP_TIME);
                // Deal with relays and buttons
                //gw.sleep(SLEEP_TIME); //sleep a bit
                    gw.saveState(message.sensor, Relays[message.sensor].relayState); // save sensor state in EEPROM (location == sensor number)
              • DickD Dick
                In#include <SPI.h>
                #define RELAY_OFF 1
                #define noRelays 4
                public:
                int lastLightLevel;
                  gw.begin();
                    delay(250);
                  gw.process();
                  // Deal with PIR
                @Dick the IDE normally says which line the error occurred on. Knowing that helps a lot when troubleshooting.
                This line
                should probably be
                gw.sleep(digitalPinToInterrupt(PIR_SENSOR_DIGITAL_INPUT), CHANGE, SLEEP_TIME);
                DickD 1 Reply Last reply
                • DickD
                  DickD
                  Dick
                  thats logic, I hoped that I learned something in the last cople of days but trouble shooting is something else. Thank you for your advise and go on with testing and adding other devises.
                    This line
                    should probably be
                    DickD
                    DickD
                    Dick
                    still strugling. it must beeasy but it isn't, mij working 4 button and 4 relais
                    #define RELAY_OFF 1
                    #define noRelays 4
                    public:
                      delay(250);
                      delay(250);
                        delay(250);
                      gw.process();
                    Combined with a pir like this where the pir is working perfect but the buttons in combi with the relay are not working anymore. What is wrong in this comnined script?
                    NO ERRORS DURING COMPILATION!
                    unsigned long SLEEP_TIME = 60000; // Sleep time between reports (in milliseconds)
                    #define RELAY_OFF 1
                    #define noRelays 4
                    public:
                      //gw.begin();
                      //gw.sendSketchInfo("Combi PIR, Temp, Hum, 4 Relay and Switch, LDR sensor", "1.0");
                      delay(250);
                      delay(250);
                        delay(250);
                      gw.process();
                      // Deal with PIR
                    • DickD Dick
                      #define RELAY_OFF 1
                      #define noRelays 4
                      public:
                        delay(250);
                        delay(250);
                          delay(250);
                        gw.process();
                      #define RELAY_OFF 1
                      #define noRelays 4
                      public:
                        //gw.begin();
                        delay(250);
                        delay(250);
                          delay(250);
                        gw.process();
                        // Deal with PIR
                      @Dick the code is using child id 0, 1, 2 and 3 for the relays, and then 1 again for the pir. That will confuse the system. I would change
                      to
                      #define CHILD_ID_PIR noRelays  // relays use child id 0...noRelays-1 so let the pir use the next number
                      and move this definition after #define noRelays.
                      • DickD
                        DickD
                        Dick
                        I finaly made it 4 buttons, 4 relay and a pir and here the script for sharing
                        #define USE_MOTION_SENSOR
                        #define MOTION_SENSOR_PIN    3
                        #define RELAY_OFF 1
                        Bounce motionsDebouncer = Bounce();
                        #define noRelays 4
                        public:
                          delay(250);
                          delay(250);
                          pinMode( MOTION_SENSOR_PIN, INPUT_PULLUP );
                          motionsDebouncer.attach(MOTION_SENSOR_PIN);
                          motionsDebouncer.interval(50);
                            delay(250);
                          if ( motionsDebouncer.update()) {
                            int value = motionsDebouncer.read();
                            Serial.println( "Motion sensor is " + (String)value );
                          gw.process();
                          delay( 50 ); // give the input pins some rest. Incomming messages are still being processed.
                        • DickD Dick
                          #define RELAY_OFF 1
                          #define noRelays 4
                          public:
                            delay(250);
                            delay(250);
                              delay(250);
                            gw.process();
                          Great work @Dick !
                          You might want to change
                          to
                          gw.wait( 50 ); // give the input pins some rest. Incoming messages are still being processed.
                          Delay will prevent incoming messages from being processed while gw.wait handles incoming messages.
                          • DickD
                            DickD
                            Dick
                            thanks for this change. I read about it. I change it right away.
