  3. Sensebender Micro - Abnormal power consumption
14 Posts 8 Posters 5.0k Views 6 Watching
  • qqlapralineQ
    qqlapralineQ
    qqlapraline
    Hello all,
    I have been facing some power saving issues lately with one of my (numerous) Sensebender micro boards.
    Whilst they all use a mere 27µA during sleep, one of them is using between 400 and 700 µA.
    Of course, I have tried the famous Sketch J to see if this was not related to some software issue, but the result was the same.
    I have cleaned the contact and everything using some alcohol but it does not change anything either.
    Any idea there ?
    QQ.
      A broken radio?
      • qqlapralineQ
        qqlapralineQ
        qqlapraline
        Nice try but removing the radio was part of my tests (especially with Sketch J).
        Qq.
        • tbowmoT
          tbowmoT
          tbowmo
          Has it been exposed to extreme humidity or something else external that could cause this?
          • qqlapralineQ
            qqlapralineQ
            qqlapraline
            No, not at all. Actually, it sits on one of my bookshelves. It has been there for a while.
            I thought for a long period that the battery drain was due to some software issue until I conducted some deep analysis.
            Qq
            • scalzS
              scalzS
              very strange!
              pics of your board? And what do you use to measure current ?
              • qqlapralineQ
                qqlapralineQ
                qqlapraline
                Here are some photos (frontside and backside). I use a regular multimeter to monitor the current (serial through the battery power).
                QQ.
                rborerR 1 Reply Last reply
                • qqlapralineQ qqlapraline
                  QQ.
                  rborerR
                  rborerR
                  rborer
                  Hi @qqlapraline , I experience the same issue. I've already built door sensors + Temp + humidity with a pro mini 3.3v and it working since 7 months with the same 2AA's.
                  I've done the same with the sensebender micro and in 2 weeks the battery are ko. I send temp/hum every 5 min, use sleep and interrupt for the door sensor.
                  • qqlapralineQ
                    qqlapralineQ
                    qqlapraline
                    I've found it...Yep, several months later, I've found it.
                    Actually, there were some ghost connections. I have cleaned the different soldering flows using an Exacto. Furthermore, I have re-done the connection (to the NRF and the batteries) using a pump...
                    And...tadah ! now the sleep current consumption is around 25µA.
                    ahmedadelhosniA 1 Reply Last reply
                      ahmedadelhosniA
                      ahmedadelhosniA
                      ahmedadelhosni
                      @qqlapraline so bad soldering caused this ?!
                      • qqlapralineQ
                        qqlapralineQ
                        qqlapraline
                        If « bad soldering » means some imperfections left unfortunately considering my close-to-perfection soldering skills..I would have to say yes..:)
                        That, or oxydation or any other issue.
                        Qq.
                        YveauxY 1 Reply Last reply
                          Qq.
                          YveauxY
                          YveauxY
                          @qqlapraline said in Sensebender Micro - Abnormal power consumption:
                          I've seen much worse:
                          0_1509125965672_upload-74ce712e-65db-4632-8c70-641fd8455023
                          :grimacing:
                          qqlapralineQ gohanG 2 Replies Last reply
                          • YveauxY Yveaux
                            :grimacing:
                            qqlapralineQ
                            qqlapralineQ
                            qqlapraline
                            @Yveaux, thanks for your support ;)
                            • YveauxY Yveaux
                              :grimacing:
                              @Yveaux I think that some people deserve to go to jail for that 😁
