💬 Jukebox design journal
I got this board a lot time ago and finally have a little time to complete it. MCU and usb-ttl work correctly, all power suppliers are fine, board fits the enclosure. Let's move forward
Finally solved a lot of problems and checked a lot of mistakes. But now the first version of this device works almost properly :trollface:
I will make a small report in the description asap
1 out of 3
devDuino Sensor Node V1.3 (ATmega 328)
OpenHardware.io • 26 Apr 2016, 09:58 • openhardware.io 26 Apr 2016, 11:33 -
💬 MSMDLed
OpenHardware.io • 27 Dec 2018, 11:02 • openhardware.io 27 Dec 2018, 11:02 -
💬 MDMSGate
OpenHardware.io • 10 Jul 2016, 19:42 • openhardware.io 2 Jul 2019, 06:44 -
MySensors Ethernet Gateway RPi form-factor (W5100 module)
OpenHardware.io • 3 Mar 2016, 08:13 • openhardware.io 3 Mar 2016, 08:13 -
💬 Safe relay node
OpenHardware.io • 23 Mar 2018, 18:10 • openhardware.io 24 Apr 2020, 09:51 -
Which MCU + BT/BLE for heart rate and ECG monitoring (from TI ADS1293)
Hardware • 25 Jan 2016, 14:33 • victus 10 Feb 2016, 22:03 -
💬 RFM69 Livolo 1 channel 1 way EU switch(VL-C700X-1_Ver_C2)
OpenHardware.io • 8 May 2017, 16:04 • openhardware.io 12 May 2017, 22:01 -
Home Automation and monitoring
My Project • 26 Jun 2016, 23:04 • sudo_bash80 26 Jun 2016, 23:04
