Automatic stairs led lighting arduino shield
Re: Automatic stairs led lighting arduino shield
Hi @aivaredze
Could you help to detail the hardware specification such as: LED Strip, Power Supply Switch and what is the device which shown on top of 2 PIR sensor?
thanks,
Boly -
Leds 12v 2.5A max per strip
Power supply: 12v and multiply the number of strips buy the max current they use to get the minimum output current for the power supply
The top right component is a photo resistor used to measure how much light is in the room, so you don't turn on the stairs lights during the day -
Have you tried searching for "light resistor"? Or perhaps "Light resistor arduino" ? ;)
@tbowmo said in Automatic stairs led lighting arduino shield:
Thanks Tbowmo, it is this one?
http://www.ebay.com/itm/5-Types-10-Pcs-Photoresistor-Dependent-Light-Resistor-LDR-Pack-For-Arduino-Kit-/232366567175?epid=28002809838&hash=item361a206f07:g:QQ0AAOSwKflZO107 -
Yes, that's the one..
