  3. Please help! Arduino UNO + RFM69HW (TSM:INIT:TSP FAIL)
23 Posts 4 Posters 5.0k Views 3 Watching
  • vladimirV
    vladimirV
    vladimir
    Hello!
    Please help me understand the problem.
    My relay node is built on Arduino UNO + RFM69HW 868 mhz
    My gateway node is built on NodeMcu + RFM69HW 868 mhz
    Controller Openhab 2.2 (Openhabian + Raspberry Pi 3)
    MySensors library 2.2
    Here's what the port monitor shows:
    16 MCO:BGN:INIT REPEATER,CP=RRNRA---,VER=2.2.0
    26 MCO:BGN:BFR
    27 TSM:INIT
    28 TSF:WUR:MS=0
    80 !TSM:INIT:TSP FAIL
    81 TSM:FAIL:CNT=1
    83 TSM:FAIL:DIS
    84 TSF:TDI:TSL
    The code of my relay node:
     * Version 1.0 - Henrik Ekblad
    //#define MY_RADIO_NRF24
    //#define MY_RADIO_NRF5_ESB
    #define MY_RADIO_RFM69
    //#define MY_RADIO_RFM95
    #define MY_REPEATER_FEATURE
    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before()
    	for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
    		pinMode(pin, OUTPUT);
    		present(sensor, S_BINARY);
    	if (message.type==V_STATUS) {
    		// Change relay state
    		digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
    		// Store state in eeprom
    		// Write some debug info
    		Serial.print(message.sensor);
    Photo of my relay node:
    My relay node
    Please tell me what I'm doing wrong and how to fix this problem?
    • scalzS
      scalzS
      wrote on last edited by scalz
      A few things are wrong I think:
      • RFM69 'HW' variant needs this define in your relay sketch:
      #define MY_IS_RFM69HW
      you can check docs here ;) https://www.mysensors.org/download/sensor_api_20#configuration
      • RFM69 is not 5v tolerant on VCC, nor the spi bus. you're using a UNO, I understand you're using 3v, but UNO mcu is powered by 5v and outputs 5v signals on spi bus as (I think the 'not 5v tolerant' is in docs too. maybe we should highlight it
      • vladimirV
        vladimirV
        vladimir
        @scalz, many thanks for the reply and the desire to help!
        I understand what you are talking about, but for now I can figure out how to solve it.
        Perhaps you have ideas?
        Replace Arduino board with Pro Mini 3.3V?
        • vladimirV vladimir
          @vladimir yes, either replace with a 3.3V board or use a level converter.
          vladimirV 1 Reply Last reply
            vladimirV
            vladimirV
            vladimir
            @mfalkvidd I'm not properly connected? In the photo above. He's turned over there.
              That is the voltage regulator like the one on the arduino that supplies the 3.3v pin, but the Arduino is using 5v also on the other GPIO pins and that usually could kill the RFM69 that should operate at 3.5V max on data pins
                vladimirV
                vladimirV
                vladimir
                @gohan what regulator can you advise? Can you show an example?
                  search for "logic level shifter"
                    @vladimir the shopping guide at https://www.mysensors.org/build/connect_radio lists a logic level shifter.
                      vladimirV
                      vladimirV
                      vladimir
                      @gohan thank you very much for your help! :raised_hands:
                        vladimirV
                        vladimirV
                        vladimir
                        @mfalkvidd thank you very much for your help! :+1: :v:
                          I hope you didn't fry the rfm69, so in case you are still having problems with the level shifter connected try with another module
                            vladimirV
                            vladimirV
                            vladimir
                            @gohan I'm afraid that they suffered greatly during my experiments. I'll try with the new ones. Can you tell me how to connect the converter?
                              https://learn.sparkfun.com/tutorials/bi-directional-logic-level-converter-hookup-guide and https://learn.adafruit.com/neopixel-levelshifter/shifting-levels are pretty extensive guides
                                vladimirV
                                vladimirV
                                vladimir
                                @mfalkvidd Thank you! I hope I can figure it out. To regret, my knowledge of English is not very great. As I understand it, the connection scheme will be the most similar to this:
                                I'm right?
                                  I'm right?
                                  @vladimir yes, that looks great (except for the brown cable that doesn't go through the level shifter)
                                    vladimirV
                                    vladimirV
                                    vladimir
                                    @mfalkvidd So I do not like the converter for 4 channels?
                                    Here this is indicated by the link you gave me above
                                    It will take 5? More precisely 8-channel version?
                                      @vladimir you will need to shift all signals. You can use multiple 4x boards, or a bigger board.
                                      Edit: maybe miso and dio0 don't need to be shifted, since the Arduino only reads from it. But I am not 100% sure.
                                        vladimirV
                                        vladimirV
                                        vladimir
                                        @mfalkvidd Thank you! :raised_hands: I'll try tomorrow.
                                          4ch is enough as the brown cable is the interrupt signal so it's just an input on the arduino
