  3. At home / away?
At home / away?
away
25 Posts 11 Posters 7.1k Views 11 Watching
  • Michael_KM
    Michael_KM
    Michael_K
    wrote on last edited by Michael_K
    Hello.
    I'm new to MySensors. I have a Z-Wave system (Homeseer), and would like to tell it that I'm away, and that I've returned.
    I researched RFID, and found a system that would do it (UHF, active transponder tag). I even found an inexpensive interrogator ($150).
    But, I'm wondering if MySensors would be better suited for this project. And, I have 4 other projects for my MySensor network, to augment my Z-Wave system.
    Has anyone tried this?
    Being new to MySensors, I think that the only way to accomplish this task would be for me to put a node in my car (powered when the car is running), and for the system to watch for the loss/reconnection of that node. Is that practical?
    Using mysensors to augment my HomeSeer Hometroller Zee S2.
    zboblamontZ sundberg84S 2 Replies Last reply
    • Michael_KM Michael_K
      Hello.
      zboblamontZ
      zboblamontZ
      zboblamont
      @michael_k Have you considered a phone link latching via bluetooth or similar? Unless you do not have a mobile phone of course.
      Fairly sure somebody very recently posted a piece where his electric car charger would only activate if he was getting close to home, how it was done I cannot recall....
      Michael_KM 1 Reply Last reply
        Hello.
        @michael_k - I'm just using a geofence on our cell phones triggering a fake device in the controller.
          Other people are using BT Le tags or smart bands that get scanned for their Mac address
          • tbowmoT
            tbowmoT
            tbowmo
            I just use the wifi/lan, and check which mac addresses is connected.. If I see my phone on the wifi/lan, I must be at home..
            Depends on the capabilities of your router / AP's though..
            YveauxY 1 Reply Last reply
            • tbowmoT tbowmo
              YveauxY
              YveauxY
              @tbowmo recent Android (and probably ios too) disables wifi when the phone is at rest for some time. You aren't able to distinguish between phone at rest and phone away...
              I had to give up this route...
              sundberg84S tbowmoT 2 Replies Last reply
              • YveauxY Yveaux
                @yveaux i use tasker and wifi change so when I connect/disconnect to my home wifi I send a command. Works great but I understand the difficulty with ping.
                dbemowskD 1 Reply Last reply
                • sundberg84S sundberg84
                  dbemowskD
                  dbemowskD
                  @sundberg84 if what @Yveaux says is correct, wouldn't the phone constantly connect and disconnect and trigger tasker?
                  • dbemowskD dbemowsk
                    @dbemowsk it doesn't... I don't know if there is a delay in tasker so the wifi comes online before. This works great for me.
                    Edit; There is both "wifi near" and "wifi connected" in tasker and this might be the difference. In using "wifi near"
                      dbemowskD
                      dbemowskD
                      @sundberg84 I have tasker on my phone. I will have to try this. I had some issues on one of my previous phones so I didn't use tasker as much as I thought I would. I woner if it will work better on my Samsung Galaxy S8+. It would also be nice if I could get geofencing working too.
                      • zboblamontZ zboblamont
                        Michael_KM
                        Michael_KM
                        Michael_K
                        @zboblamont
                        BT sounds good. But, I don't exactly want to use my phone's BT (would have to keep it on).
                        Perhaps there's some kind of BT device I can put in my car (powered when running), and connect to something that can talk to my HA system.
                        @sundberg84
                        I don't really like the geofence method -- I rarely have location turned on.
                        @tbowmo
                        Actually, that's what I have now. Tasker watches for when my phone's wifi connects and disconnects from my LAN, and notifies my HA system (which has a Tasker plugin). But, as @Yveaux mentioned, it's not quite ideal.
                        @dbemowsk
                        I think that Tasker knows the difference between 'wifi radio on/off' and 'connected/disconnected from and near/not near LAN'.
                        • wallyllamaW
                          wallyllamaW
                          wallyllama
                          wrote on last edited by wallyllama
                          Would somesort of passive rfid tag attached to your keychain work?
                          Edit - a quick google search for keyfinder came up with a variety of bluetooth/gps tags, some in bulk for under $2 USD. Probably come with an app, but that could likely be subverted into something mysensors compatible.
                          • YveauxY Yveaux
                            tbowmoT
                            tbowmoT
                            tbowmo
                            @yveaux
                            I'm pretty sure that I can see new phones (both iPhone X and Samsung galaxy s9 devices) on my access point, even if they haven't been used for a while.
                            But I haven't used the presence detection the last couple of years.
                            • wallyllamaW wallyllama
                              Michael_KM
                              Michael_KM
                              Michael_K
                              @wallyllama
                              Passive RFID doesn't have the required range (a max of ~1 m?)
                              • Michael_KM
                                Michael_KM
                                Michael_K
                                Well, I have an idea that might work!
                                Attach this to an Arduino. (Note that there's also a UART version.) Then, all I need is a Bluetooth transponder beacon tag (which I'd leave in the car).
                                Conveniently, I'd still need MySensors to implement this!
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @Michael_K
                                  That only detects if your car is there or not.. If you take your bike, or just walk to a bus stop, then it won't detect your presence :)
                                    So far the cheapest solution I found is using an esp32 that scans for nearby BT devices (look at the Andreas Spiess video on his channel) but I don't know if it will be compatible with mysensors
                                      YveauxY
                                      YveauxY
                                      @gohan said in At home / away?:
                                      But then you have to place quite a lot of receivers to cover your whole house, I assume?
                                      gohanG 1 Reply Last reply
                                      • wallyllamaW
                                        wallyllamaW
                                        wallyllama
                                        I'm going to go a bit conceptual here, riffing on some ideas that I believe I got from @dbemowsk. A multi-pronged approach may be useful here, maybe bt for the car and bicycle, amount of time since any PIR device triggered, time of day, etc. Then using the "smarts" of a smarthome a reasonable estimate of home/away can be gained.
                                        I dont think an A.I. like the googazon has is required, but something smarter than a single node might be apropriate.
                                        • YveauxY Yveaux
                                          @yveaux correct
