  3. SerialGateway Standalone not working
serialgatewaypro minidebug mode
14 Posts 5 Posters 7.3k Views 1 Watching
  • jendrushJ
    jendrushJ
    jendrush
    Are you using serial gateway sketch, and example sketch in the same version?
    • warawaraW
      warawaraW
      warawara
      Yes. I have installed the libraries and examples according to the tutorial on the site.
        You seem to have done some extensive testing. Especially if you get the RF24 ping examples working.
        Enabling debug mode on gateway will show more information when an actual radio message is picked up.. So it could be working (but does nor receive anything).
        Could you perhaps try the 1.4 development branch?
        • warawaraW
          warawaraW
          warawara
          @Hek I was already starting with some tests with the 1.4 development branch.
          Just finishing my initial tests. Don't know why, but the development branch is working perfect!
          hekH 1 Reply Last reply
          • warawaraW warawara
            @warawara
            Both the development branch and the ping-examples uses shockburst mode of the NRF24l01.
            • warawaraW
              warawaraW
              warawara
              Then it looks like that did the trick for me.
              • warawaraW
                warawaraW
                warawara
                wrote on last edited by warawara
                @hek is it possible to use shockburst mode in the master branche with some kind of config setting?
                  @warawara
                  It might be, but why?
                  • warawaraW
                    warawaraW
                    warawara
                    So i can use the master branche instead of the development.
                    • B
                      B
                      Bandra
                      @warawara , the development branch is very stable. At this point there is no reason not to use it. It is superior in every way to 1.3.
                      • B Bandra
                        @Bandra well, the protocol still changes every now and then, so be prepared to update your sensors and gateway when updating the library!
                        B 1 Reply Last reply
                        • YveauxY Yveaux
                          B
                          B
                          Bandra
                          @Yveaux
                          True. The library is changing constantly (for the better!).
                          I've not encountered any major bugs in the 1.4 beta libraries that I've tried. So if the OP was just starting out then there's value in pulling down the latest 1.4 (which should be quite stable) and starting their sketches from there. Once 1.4 goes to production, then upgrading sketches will be much easier from 1.4b -> 1.4 than from 1.3 -> 1.4.
                          • warawaraW
                            warawaraW
                            warawara
                            I'm aware of the superiority of 1.4. Because I just started with building my custom controller I will go with the development branch for now. I really like the new protocol so far.
                            I'm using very basic arduino sketches at the moment. The only thing I'm worried about is my custom controller that I'm building in Node-Red. Hopefully the feature changes will not have to much impact on that part.
