Slim Node Si7021 sensor example
    @rsachoc
    The capacitors are part of the Slim Node design, they have nothing to do with this particular sensor. It's C4 and C5 if you look in the BOM. The one you asked about earlier was just a bad example by me where I had put what had at the time, which was the "C1,2,3" type of cap.
    The caps are sort of belt and braces here. Your node would probably work without them (ie C4,C5), but maybe with a little worse performance.
  • @m26872 thanks, I've now ordered the missing parts, so hopefully once they arrive I'll be good to go.
    UPDATE
    Added the "Notes" part in the first post.
  • Hello @m26872 !
    I really loved your slim node ! Nice job !
    I will probably copy your design and replace the NRF by a RFM69. Actually I work with mini pro but as I don't want to desolder the LED and the regulator it's time to come-back with DIP format ๐Ÿ˜‰
    The power consumption seems the same with the SI7021 and a DHT22 ?
    David.
    @carlierd You're welcome! It's "licensed" Public Domain, so use it as you wish. But of course - please make it open hardware if you come up with something.
    I only measure the sensor nodes total sleep mode consumption and since the DHT22 requires a 3.3V booster (Iq ~90uA) it's hard to tell if it's exactly the same.
  • @m26872 : I don't use booster. You think it's necessary ? 90uA is really important for battery operation.
    For the design off course I will make it open hardware ๐Ÿ™‚
    David.
    @carlierd What's your setup then? The DHT22 is for 3.3-5.5V.
  • @m26872 I have built the Slim Node described above and i am using your exact sketch given above but when i look at the serial monitor, it is printing junk characters i tried different baud rates on the serial monitor but nothing works.
    I am connected to the slim node using FTDI board.
    Any thoughts?
    Thanks for your help.
    @ar91 Did you change baud rate in MySensors config too?
    @m26872 There is another version of the SI7021 board without voltage regulator. This evening I will look up the link on Aliexpress. The boards are smaller then the GY-21 variant.
  • Thanks @m26872, I changed the baud rate on MyConfig.h and it started working.
  • @m26872 My nodes are working correctly for the moment. Actually one is at 2.8v. Perhaps I will have problem when voltage will be lower !
    David.
    @carlierd Probably. That's why I ask what you use. DHT22 connected straight to 2AA will not utilize battery capacity. Higher battery voltage with step down regulator would be better - or maybe without, but with like 3AAs or so.
  • @carlierd With Slim Node running at 1Mhz even with or without booster i am having hardtime making DHT22 work. I even tried different libraries but none of them works at 1Mhz. How did you get it work?
    @ar91 I don't think there's a good reason to go below 8MHz if DHT22 doesn't work much below 3.3V ?
  • @m26872 Perhaps that with a caps I can go very low. I want to have at least one year on 2 AA. Wait and see !
  • @ar91 Hello. I am using the arduino playground lib. No issue with it ! I can post a sketch if necessary.
    David.
  • @carlierd If you could share your code that will be great.
  • @ar91 Please find the code I used in 3 different nodes. The good thing with the playground lib is that there is error message if dialog with DHT22 failed.
    /* Temperature, humidity and luminosity measurements.                                 */
    /* Version     : 1.1.6        */
    /* Date        : 10/01/2016                                                           */
    /* Modified by : David Carlier                                                        */
    /*                            RST |             |  A5                                 */
    /*                            RX  |             |  A4                                 */
    /*                            TX  |   ARDUINO   |  A3                                 */
    /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
    /*            DHT22 --------- D3  |             |  A1                                 */
    /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Light dep. resistor   */
    /*              +3v --------- VCC |             | GND --------- GND                   */
    /*              GND --------- GND |  8MHz int.  | REF                                 */
    /*                            OSC |             | VCC --------- +3v                   */
    /*                            OSC |             | D13 --------- RFM69 (SCK)           */
    /*                            D5  |             | D12 --------- RFM69 (MISO)          */
    /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
    /*                            D7  |             | D10 --------- RFM69 (NSS)           */
    /*                            D8  |             |  D9                                 */
    /* Power = Vcc for LDR.                                                               */
    /* +3v = 2*AA        */
    #include <dht.h>
    #include <MyTransportRFM69.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    #define CHILD_ID_VOLTAGE 3
    #define POWER_PIN 4
    //unsigned long SLEEP_TIME = 850000; // Sleep time between reads (in milliseconds) (close to 15')
    unsigned long SLEEP_TIME = 275000; // Sleep time between reads (in milliseconds) (close to 5')
    //Construct MySensors library
    MySigningAtsha204Soft signer;
    MyHwATMega328 hw;
    MyTransportRFM69 transport;
    MySensor gw(transport, hw, signer);
    dht DHT;
    MyMessage msgLum(CHILD_ID_LIGHT, V_LEVEL);
    MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
    /* Initialization        */
      //Get time (for setup duration)
      #ifdef DEBUG
        unsigned long startTime = millis();
      //Start MySensors
      gw.begin();
      //Send the Sketch Version Information to the Gateway
      gw.sendSketchInfo("GHAS sensor", "1.1.5");
      //Register all sensors to gw (they will be created as child devices)
      gw.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
      //Delay for DHT22
      delay(1500);
      //Print setup debug
      #ifdef DEBUG
        int duration = millis() - startTime;
        Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
    /* Main loop        */
      //Get time (for a complete loop)
      #ifdef DEBUG
      //Power on
      powerOnPeripherals();
      //Get DHT22 data
      int dht22Result = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
      switch (dht22Result)
        case DHTLIB_OK:
                    //Serial.println("OK,\t");
        case DHTLIB_ERROR_CHECKSUM:
                    #ifdef DEBUG
                      Serial.println("Checksum error,\t");
        case DHTLIB_ERROR_TIMEOUT:
                    #ifdef DEBUG
                      Serial.println("Time out error,\t");
        case DHTLIB_ERROR_CONNECT:
                    #ifdef DEBUG
                      Serial.println("Connect error,\t");
        case DHTLIB_ERROR_ACK_L:
                    #ifdef DEBUG
                      Serial.println("Ack Low error,\t");
        case DHTLIB_ERROR_ACK_H:
                    #ifdef DEBUG
                      Serial.println("Ack High error,\t");
        default:
                    #ifdef DEBUG
                      Serial.println("Unknown error,\t");
      //Get temperature and humidity
      float temperature = 0;
      float humidity = 0;
      if (dht22Result == DHTLIB_OK)
        temperature = DHT.temperature;
        humidity = DHT.humidity;
      //Get power before luminosity to use real voltage
      float realVoltage = getVoltage() / 100.0;
      int batteryPcnt = realVoltage * 100 / 3.0;
      if (batteryPcnt > 100) {batteryPcnt = 100;}
      int lux = computeIlluminance(realVoltage);
      //Power off
      powerOffPeripherals();
      //Send data to gateway
      gw.send(msgLum.set(lux));
      gw.send(msgVolt.set(realVoltage, 2));
      //Print debug
      #ifdef DEBUG
        Serial.print(temperature, 1);
        Serial.print(" degC");
        Serial.print("   ");
        Serial.print(humidity, 1);
        Serial.print(" %");
        Serial.print("   ");
        Serial.print(lux);
        Serial.print(" lx");
        Serial.print("   ");
        Serial.print(realVoltage);
        Serial.print(" v");
        Serial.print("   ");
        Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
        Serial.flush();
      //Sleep
      gw.sleep(SLEEP_TIME);
    /* Allows to compute illuminance (in LUX) from LIGHT_SENSOR_ANALOG_PIN.               */
    int computeIlluminance(float realVoltage)
      //Get luminosity
      int luminosity = analogRead(LIGHT_SENSOR_ANALOG_PIN);
      //Calculating the voltage in the input of the ADC
      double voltage = realVoltage * ((double)luminosity / 1024.0);
      //Calculating the resistance of the photoresistor in the voltage divider
      double resistance = (10.0 * realVoltage) / voltage - 10.0;
      //Calculating the intensity of light in lux and return it
      int illuminance = 255.84 * pow(resistance, -10/9);
      return illuminance;
    /* Allows to get the real Vcc (return value * 100).                                   */
    int getVoltage()
      const long InternalReferenceVoltage = 1056L;
      ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
      delay(50);  // Let mux settle a little to get a more stable A/D conversion
      //Start a conversion
      ADCSRA |= _BV( ADSC );
      //Wait for it to complete
      while (((ADCSRA & (1<<ADSC)) != 0));
      //Scale the value
      int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
      return result;
    /* Allows to power ON peripherals.                                                    */
    void powerOnPeripherals()
      //Power-up
      pinMode (POWER_PIN, OUTPUT);
      digitalWrite (POWER_PIN, HIGH);
      delay(1);
    /* Allows to power OFF peripherals.                                                   */
    void powerOffPeripherals()
      //Power off
      digitalWrite (HUMIDITY_SENSOR_DIGITAL_PIN, LOW);
      digitalWrite (POWER_PIN, LOW);
      pinMode (HUMIDITY_SENSOR_DIGITAL_PIN, INPUT);
      pinMode (POWER_PIN, INPUT);
    Hope it helps !
    David.
  • @carlierd Thank you very much. I really like your comment on the top ๐Ÿ‘
  • Progress!
    http://imgur.com/zRvXvrN
    http://imgur.com/KpB7daz
    A question though. To get to this point, I copied the pictures posted above, but where do I now add these resistors?
    http://imgur.com/6mKJcgE
    Also, if I want to add a 2AA battery cage, where do I connect the red and black wires to?
    Thanks! And sorry for the newb questions!
    @rsachoc What you show are not resistors, they look like capacitors. 104 means 100nF (I think). Can you measure their value ?
  • @carlierd Are you running your Atmega at 1Mhz, Because I tried to use your sketch and i am getting "Checksum Error".
  • @GertSanders indeed they are capacitors (silly me) - apparently they are 0.1uf - the black one I have already soldered is 4.7uf
    No, I am working at 8 MHz (internal). Perhaps your DHT is out of order ? You try with another one ?
    David.
  • Bump, can anyone advise on how I got about finding out where I need to solder the resistors on? So far I've just soldered the 4.7uf capacitor, as can be seen from the pics. But I'm struggling to find out where I need to solder the other capacitor's I have (from the BOM).
    @rsachoc C1,C2,C3 are clearly marked at top layer silkscreen. You'll see them in the middle of the uC socket if you look at your 2nd picture in you last post above. C5 is visible next to the 4.7u cap, in the 3rd picture of my first post in this thread.
    First picture in first post of this thread should be enough. Connect (+) to Vcc and (-) to Gnd.
  • Thanks, apologies, I really should have looked at my board, I was searching for the answer in the main slim node thread and I think i was looking at older boards and couldn't for the life of me find where C3 is!
    @rsachoc I'm sorry, I know I need to update those old pictures.
  • @m26872 no problem, not your fault at all, mine for being a newbie. So much so that my first attempt resulted in me soldering the capacitor to the wrong hole, so I've had to abandon my first attempt. You live, you learn, next time I'll double check.
    @rsachoc Yes. Double check polarity of the 4.7uF cap.
  • Hi all, again.
    I have now successfully built (I think) the slim node, but without the 7021 temp sensor. Because this is the most expensive part of the device and because I find desoldering a challenge, but mainly because I'm waiting for it to arrive from China, can I try and upload the bootloader and sketch without the sensor attached?
    If so, I had a couple questions from reading through this thread and the slim node thread. Firstly, uploading the bootloader, can this be done with the FTDI adaptor or do I need to follow the bit described in the slim node thread and attempt it using AVR studio? Secondly, once that is done, is it just a matter of uploading the sketch provided above?
    Also, I wanted to confirm a few things on attaching the si7021 temp sensor. From what I can see, SOA (SDA) on the si7021 goes to A4 and SCL goes to A5. Also, GND goes to GND on the board (rightmost set on pins bottom right when FTDI is at the top) and VIN goes to VCC (just next to GND on the board)?
    Thanks in advance.
    Yes, you should be able to get far without the sensor. Send something over MySensors net and view debug prints. Or make some simple sensor like a reed switch.
    Yes, Avr Studio or Uno as ISP.
    Yes, but if you don't connect a Si7021 I would go for some other simple test sketch to avoid any Si7021 library startup issues.
    Yes.
  • Folks, a word of caution, for people that are attempting this for the first time, please burn the bootloader before you solder everything, as silly me, I built the entire thing (without the si7021) and now I'll need to bin it because the ATMega is soldered to the board and I've no way to load the bootloader soldered to the board!
    Ah, the life of a newbie ๐Ÿ˜
    I think what I'll do is once I've actually got a working board, I'll do a newbie writeup so that people don't make the same mistakes as me.
    First Attempt In Learning ๐Ÿ™‚ A writeup would be awesome.
    @rsachoc Why don't you just solder some wires to pins you need ? The "in cicuit serial programming" concept would let you do it with almost anything attached.
    I might as well attempt that! I'm waiting for a breadboard, so I'll try and attempt it when that arrives.
  • Some of my tips (noob alert) that I've gathered in my travels so far for this temp Slim node
    1. Burn the bootloader onto the ATMega328 first! (here is a guide for Arduino as ISP)
    2. Check the capacitor polarity before you solder it (the 4.7uF electrolytic capacitor, the others don't matter)
    3. I prefer using strips for the Atmega (see here) as you'll have more clearance for the capacitors which sit underneath (there is a caveat to this however, in that if you're not sure if you've got/burnt a bootloader onto the ATMega, using strips there is no going back, whereas with the chip socket, you can remove the ATMega). Update I think, for me anyway, if you're confident that the ATMega has been bootloaded successfully, I still prefer strips, however if you're unsure what you can do is use the socket and just sit it higher in it's position to get a decent clearance.
    4. The bill of materials (BOM) is here and also helps with figuring out which pieces go where
    5. Solder the capacitors, wires for Si7021 (with si7021 attached) and FTDI pins to the board first, then the strips + AtMega328p (see below), then the NRF last to the board. I found that the FTDI pins facing straight up were best for the box I was going to put it in
    6. Solder the strips to the ATMega first, then to the board
    7. Check the size of the box/fitting you are going to mount this in before you do all the above!
    8. Check that you are putting the ATMega chip the right way on the board, the notch should be facing the pins for the FTDI.
    9. Check continuity of the pins from the ATMega to the board pins underneath, I found the ATMega to strips were the most difficult to solder, and after I tested continuity I found a single pin which didn't have connection, so I added some more solder to this pin.
    10. Don't forget the resistor at R1 (I soldered this to the underside of the board, less by choice and more by the fact that I forgot about it, but I guess the preference would be the same side as the capacitors)
    11. I strongly advise buying the 3.3v ready si7021 temp sensor (here) as the modification to the 5v version is quite difficult for a newbie (the components are quite small) and you'll probably mess it up like I did.
    General soldering tips
    12) Practice soldering first, some of the joins are a little challenging and it took me a few attempts to get the hang of it
    13) Get a decent size tip, my first was a bit large
    @rsachoc As a great man once said: "most bananas grow bent, and yet everyone loves them. There is nothing strange about the diversity of routes to success"
  • Thanks all, I'm sure I will be adding to it, as I'm now trying to compile and upload the sketch. However, I'm getting the following error:
       #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    exit status 1
    Error compiling.
    I'm using the W5100 MQTT gateway sketch (which I believe is on the development branch), so I'm not sure if that's what's causing the error? I've tried deleting the Arduino IDE, the mysensors development branch from my PC, and reinstalling and redownloading the mysensors dev branch, but the same thing happens?
  • OK, so it seems that it was because I was using the dev branch that I'm getting that error. I switched over to stable and the sketch compiles, although I do get a warning.
    But I also can't upload the sketch above:
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x18
    I noted above that something needed to be changed in terms of the baud rate, mine is set at 115200 in myconfig.h and I can't seem to find a reference in mysensor.h
    @rsachoc I sorry, but there seems to be an error in the sketch in the first post. Baud rate should be 9600 everywhere if you use the common Slim Node fuses and bootloader. Upload (board.txt), MyConfig.h (not MySensor.h since v1.5), Debug-prints and Arduino IDE serial monitor.
  • Thanks, I've updated the sketch that I downloaded, also myconfig.h so that should be good. What do I need to select in the Arduino IDE for board type? I searched in the slim node thread and didn't see a reference to any changes?
    @rsachoc No changes. It is that boards.txt entry you should use.
  • Hmmm ok, that's what I thought...still no luck, I've modified the boards.txt with the text from the slim node thread, and now it still has the same error message.
    To confirm, my FTDI adaptor is attached to the board pins as follows:
    FTDI <-> board
    GND <-> first pin (i.e bottom left of board when looking at board laying long side horizontal and NRF radio on the other side)
    CTS <-> board marked GND
    PWR <-> board marked VCC
    TXO <-> next up i.e. 4th pin
    RXI <-> next up i.e. 5th pin
    DTR <-> next up i.e. last pin
    Other than that, I guess it may be something wrong with the way I made the board? If so, what's the best way to troubleshoot? Could it be a bad bootloader flash? Is there a way to check if the ATMega has a bootloader?
    edit in fact, it could be because I don't have the Si7021 connected? Could this be the reason a sketch is not uploading successfully? ๐Ÿ˜Ÿ
    @rsachoc Start simple. Try on a board without nRF and sensors. Remove everything in the sketch and make it to just print "Hello world" back to serial monitor.
  • Thanks, I haven't actually built a new node, but have been double checking everything on my current node. One thing I wanted to confirm, the 4.7uf capacitor, does the negative leg have to be on the corner of the board, as this is the way I have it currently? I think looking at the board layout in the main slim node thread, it should be the positive leg on the corner and the negative leg on the side of the board (the short side of the board)?
    @rsachoc I don't have it in front of me rigth now... but, there should be an arc and a super-small "+"-sign next to the positive pad. Maybe it just look like a dot.
  • Ok so that may be the problem then! Let me solder it the right way and see if that helps otherwise I'm going to create a bare bones slim mode as suggested
    edit to confirm the positive leg of the capacitor goes to the positive marked plus sign hole on the board?
  • OK so I changed the polarity of the 4.7uf capacitor and I'm still receiving the same error. So I built a barebones one without sensor and without NRF. I am still getting the same error when uploading the sketch via the FTDI adaptor. I tried uploading a sketch to a Sensebender I have and it worked fine, so that rules out the FTDI adaptor.
    Some pics in case someone can spot something obvious.
    http://i.imgur.com/1SV0qO2.jpg
    http://i.imgur.com/mUp87hB.jpg
    http://i.imgur.com/oCqcDpo.jpg
    So I can only think that it must be related to the ATMega bootloader? In the how to burn a bootloader thread, I received the following when trying to burn the bootloader, so I assumed it uploaded correctly?
    C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/bin/avrdude -CC:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
             System wide configuration file is "C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf"
             Using Port                    : COM5
             Programmer Type : STK500
             Hardware Version: 2
             Firmware Version: 1.18
             Topcard         : Unknown
             Vtarget         : 0.0 V
             Varef           : 0.0 V
             Oscillator      : Off
             SCK period      : 0.1 us
    avrdude: erasing chip
    C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/bin/avrdude -CC:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -Uflash:w:C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:i -Ulock:w:0x0F:m
    avrdude: verifying ...
    avrdude: reading input file "0x05"
    avrdude: verifying efuse memory against 0x05:
    avrdude: load data efuse data from input file 0x05:
    avrdude: input file 0x05 contains 1 bytes
    avrdude: reading input file "0xDE"
    avrdude: verifying hfuse memory against 0xDE:
    avrdude: load data hfuse data from input file 0xDE:
    avrdude: input file 0xDE contains 1 bytes
    avrdude: verifying lfuse memory against 0xFF:
    avrdude: load data lfuse data from input file 0xFF:
    avrdude done.  Thank you.
             Using Port                    : COM5
             Hardware Version: 2
             Topcard         : Unknown
             Vtarget         : 0.0 V
             Varef           : 0.0 V
             Oscillator      : Off
             SCK period      : 0.1 us
    avrdude: reading input file "C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex"
    avrdude: writing flash (32768 bytes):
    avrdude: 32768 bytes of flash written
    avrdude: verifying flash memory against C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:
    avrdude: load data flash data from input file C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:
    avrdude: input file C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex contains 32768 bytes
    avrdude: 32768 bytes of flash verified
    avrdude: reading input file "0x0F"
    Writing | ################################################## | 100% 0.02s
    avrdude: verifying lock memory against 0x0F:
    avrdude: load data lock data from input file 0x0F:
    avrdude: input file 0x0F contains 1 bytes
    @rsachoc Looks like you're missing the R1 resistor?
  • @m26872 well that is probably it! I didn't even realise I needed that, oops! Sorry ๐Ÿ˜ž ! Let me try and get one (I think I have some already) and get soldering
  • It lives! Well the one node I created does at least! I'll troubleshoot it, but the problem was the R1 resistor, which I (noobishly) forgot about! But very pleased, and thanks to m26872 especially and everyone else who helped.
    I've updated the lessons learn post too!
  • I just received my non-3.3v Si7021, and have now updated the lessons learnt post, as this board is tiny and I managed to mess up the soldering completely. Ordered the 3.3 ready version now, another month wait...
    /*                            RST |             |  A5                                 */
    /*                            RX  |             |  A4                                 */
    /*                            D8  |             |  D9                                 */
    /* +3v = 2*AA        */
    #include <dht.h>
    #define POWER_PIN 4
    MyHwATMega328 hw;
    dht DHT;
      #ifdef DEBUG
      //Start MySensors
      gw.begin();
      //Delay for DHT22
      delay(1500);
      //Print setup debug
      #ifdef DEBUG
    /* Main loop        */
      #ifdef DEBUG
      //Power on
      //Get DHT22 data
        case DHTLIB_OK:
                    #ifdef DEBUG
                    #ifdef DEBUG
                    #ifdef DEBUG
                    #ifdef DEBUG
                    #ifdef DEBUG
        default:
                    #ifdef DEBUG
      float humidity = 0;
      //Power off
      //Print debug
      #ifdef DEBUG
        Serial.print("   ");
        Serial.print(" %");
        Serial.print("   ");
        Serial.print(lux);
        Serial.print("   ");
        Serial.print(" v");
        Serial.print("   ");
        Serial.flush();
      //Sleep
      //Get luminosity
      return illuminance;
    int getVoltage()
      //Scale the value
      return result;
      //Power-up
      delay(1);
      //Power off
    Hope it helps !
    David.
    So the DHT22 works at 1MHz with 2 AAs and your code youยดve posted? No physical differnces?
  • So I think I've finally got everything up and running! This is what I'm getting at the serial monitor in the IDE:
    Serial started
    Voltage: 3359 mV
    send: 132-132-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 132-132-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
    send: 132-132-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-132 s=255,c=3,t=15,pt=0,l=2,sg=0:
    sensor started, id=132, parent=0, distance=1
    send: 132-132-0-0 s=255,c=3,t=11,pt=0,l=15,sg=0,st=ok:EgTmpHumBat5min
    send: 132-132-0-0 s=255,c=3,t=12,pt=0,l=10,sg=0,st=ok:1.0 151106
    send: 132-132-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 132-132-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok:
    Node and 2 children presented.
    What I'm trying to figure out is where the temp and humidity reading are so I can get them into MQTT/OpenHab. Looking at the output, I can't see which one is the temp, humidity or battery level?
    @rsachoc Is that all you get? Please also set sleep_time to 15000 for debug, if you haven't already done it.
  • @m26872 thanks, I've set that, no change even after more than 15seconds and debug set.
    Could it be the way I've connected the si7021? I've got it as follows:
    1. A4 to SDA
    2. A5 to SCL
    3. GND to GND
    4. VCC to 3.3v
  • Maybe I need to add that I'm running the 2.0 MQTT controller? Not sure if that makes a difference? GatewayW5100MQTTClient
    Just had a look what's going on on the controller side, this is what I see
    0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0-beta)
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;read: 132-132-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
    0;255;3;0;9;send: 0-0-132-132 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
    0;255;3;0;9;read: 132-132-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.4
    0;255;3;0;9;Sending message on topic: mygateway1-out/132/255/0/0/17
    0;255;3;0;9;read: 132-132-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
    0;255;3;0;9;Sending message on topic: mygateway1-out/132/255/3/0/6
    0;255;3;0;9;read: 132-132-0 s=255,c=3,t=11,pt=0,l=15,sg=0:EgTmpHumBat5min
    0;255;3;0;9;Sending message on topic: mygateway1-out/132/255/3/0/11
    0;255;3;0;9;read: 132-132-0 s=255,c=3,t=12,pt=0,l=10,sg=0:1.0 151106
    0;255;3;0;9;Sending message on topic: mygateway1-out/132/255/3/0/12
    0;255;3;0;9;read: 132-132-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
    0;255;3;0;9;Sending message on topic: mygateway1-out/132/0/0/0/6
    0;255;3;0;9;read: 132-132-0 s=1,c=0,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;Sending message on topic: mygateway1-out/132/1/0/0/7
    @rsachoc
    My initial guess would be that you get stuck at this line:
    Did you try your Si7021 on some plain arduino first? Just with some simple example code.
  • @m26872 thanks, yes, I guessed that something might be wrong with the sensor, I checked continuity between the board and the sensor and all seemed fine.
    To test on an Arduino, I've honestly very little clue how to do this. Could I utilise the breadboard and Arduino I used to flash the AtMega?
    @rsachoc The "very little clue" is a good reason to play around and learn some. ๐Ÿ˜ƒ
    You should not use a 5V Uno directly to sensor without voltage regulator and logic level converter. The Si7021 spec is 1.9-3.6V.
    If you don't have a Arduino Pro Mini 3.3V, I suppose your best option is the SlimNode you already got. Try it at least at 8MHz (use suitable fuse settings, bootloader and baud rate), of course external crystal if you have.
  • The most SI7021 coming from ebay are with voltage regulator and level shifter. I searched for a raw version and there are only very few... If you are not sure, post a link or a foto.
    @rollercontainer Thanks! You're absolutely right. I feel rather stupid not thinking of this. ๐Ÿ˜ž
    So @rsachoc, if you're have some GY-21 like boards still not yet modded like described in first post of this thread, then they should work excellent with your Uno.
  • Thanks both, I have the "pre-modded" si7021, so it's the one that should operate at between the 1.9 and 3.3v. I the Arduino I used to burn the Atmega is a knockoff, so it has both 3.3v and 5v. Let me do some research and see if I can test the si7021 using it.
  • Some pictures anyway!
    @rsachoc Great with pictures! It looks like you haven't enabled the pull-up resistors by filling the solder jumpers in the middle of the board? Like this: https://cdn.sparkfun.com/assets/3/f/6/5/a/52855764757b7f06478b4567.jpg
  • @m26872 oh! I didn't realise I needed to do that, could that be the problem? Do I just need to fill with solder the bit just below where the DA and "-" is?
    @rsachoc It's probably it. And yes, it's rigth there. Make sure all of the three small pads interconnect.
  • @m26872 thanks! No time tonight, but a job for testing tomorrow.
  • You could also use the 328 pullups! I had an unwilling Chinese light sensor (MAX44099) that drew a lot of power either with the VCC on or off. Since it's battery powered that is undesireable.
    I used digitalWrite(SDA, LOW); digitalWrite(SCL, LOW); to tie the bus to ground. When the sensor wakes up, it writes HIGH to those pins and the bus is back online. Used a 500ms wait after this to let the sensors stabilise.
    That sensor is now on a 6ยตA sleep current and a average 128ยตA over 2 hours measured with a 2 minute sleep cycle.
  • Tried it this evening, still no luck, let me see what I can get up to over the weekend.
    @DavidZH True, internal pull-ups (20k?) should probably be enough for the normal i2c use (short wires, low speed, etc). But I wonder if pull-ups are consuming any significant power during passive state like sleeping sensor. Of course it's a good solution in case there're issues preventing the bus from beeing silent. Or worse, pulled down continuously.
    What was your current before the change?
    I think 500ms awake is a lot.
    @rsachoc Crap. Maybe it's something else then.๐Ÿ˜ž
  • I switch them off with a LOW write before the sensor goes to sleep and you're absolutely right about the wait time being very long. In this case I didn't mind because the sensor is powered by a solar panel.
    I can't really remember what the exact value but it was an order of magnitude... I also used the voltage divider way to measure voltage because the Moteino has a regulator on board, so that upped the sleep current a little (10M resistor to keep the current low).
    I went searching because the current went UP when I switched the power to the sensor off before sleep. Gammon.co.au is a very useful source, but I can't remember where I dug this hack up.
    I will be making other battery sensors for inside with a HTU21d and I will post more on those in a 'My Project' mega gallery including measurements. (And dig around in the HTU datasheet for the start up time....)
  • According to the datasheet the absolute maximum time to get ready is 80ms.
  • Thanx! Saves me a trip! ๐Ÿ˜
  • Ok, so I messed up my previous sensor trying to solder the bridge (don't ask...) I have now (I think) soldered it and reconnected it, am now getting the following:
    Serial started
    Voltage: 3359 mV
    send: 132-132-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:0
    send: 132-132-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=fail:1.5.4
    send: 132-132-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
    send: 132-132-0-0 s=255,c=3,t=11,pt=0,l=15,sg=0,st=fail:EgTmpHumBat5min
    send: 132-132-0-0 s=255,c=3,t=12,pt=0,l=10,sg=0,st=fail:1.0 151106
    send: 132-132-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
    find parent
    send: 132-132-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    send: 132-132-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=fail:
    I'm going to try get everything on a breadboard, but now I see fails, what's that all about?
    PS will upload some pics of the soldered bridge...
    @rsachoc google "mysensors st fail"
    I am currently trying to use that red 3.3v module too and it doesn't seem to work. I have the sketch from above running with the "normal" blue module where I remove the voltage converter so that it works at 3.3V without a problem.
    Then I switched to the red one (with these small 3 solderpads connected) and the scl/sda lines switched (the order is different form the blue one) but the program gets stuck at the same position as above (without the st=fail's though). So I assume that
    fails. Does anyone have one of these sensors up and running? Any ideas where the error is? Otherwise I guess I have to stick with the blue ones.
    @LastSamurai
    The red ones are HTU21D and need another library (they are different from the SI7021).
    Use the Adafruit library for this module (look on their site for HTU21D).
  • @GertSanders hmmm I think I'm using that same one as @LastSamurai so I suspect that's the issue? It's the one linked in the first post
    I guess if that's the problem it should have been obvious to me, it even says HTU21D on mine! Silly me!
    @rsachoc
    Either one of these libraries will work with the HTU21D modules.
    Both modules do the same, but have different I2C adresses so you can actually use both at the same time (of you like to compare them), but you need different libraries to call each one.
    @GertSanders Thanks, I don't know why I didn't realize that ๐Ÿ˜‰
    I will try that out tomorrow.
  • @LastSamurai I'm having a go as well at updating the .ino file with the different library, but I'm not a coder so I'm "having a hack" - if you have any luck could you post your code?
    @rsachoc Yes, I actually just tried it out and its working.
    Here is my code for now (just for testing):
    I basically just switched libraries
    by m26872, 20151109
    Changed by LastSamurai
    15052016
    #include <SparkFunHTU21D.h>
    #include <RunningAverage.h>
    //#define DEBUG
    #ifdef DEBUG
    #define NODE_ID 100             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
    #define CHILD_ID_TEMP 0
    #define CHILD_ID_HUM 1
    // #define SLEEP_TIME 15000 // 15s for DEBUG
    #define SLEEP_TIME 300000   // 5 min
    #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
    #define BATTERY_REPORT_CYCLE 2016   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
    #define VMIN 1900
    #define VMAX 3300
    #define AVERAGES 2
    int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
    int measureCount = 0;
    float lastTemperature = -100;
    int lastHumidity = -100;
    HTU21D humiditySensor;
      DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
      DEBUG_PRINT("Voltage: ");
      DEBUG_PRINT(readVcc());
      DEBUG_PRINTLN(" mV");
      delay(500);
      DEBUG_PRINTLN(" *C");
      gw.begin(NULL, NODE_ID);
      gw.sendSketchInfo("TempHumTest2", "1.0 17052016");
      gw.present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
      DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
      raHum.clear();
      humiditySensor.begin();
      measureCount ++;
      batteryReportCounter ++;
      bool forceTransmit = false;
      if (measureCount > FORCE_TRANSMIT_CYCLE) {
        forceTransmit = true;
      // Read and print internal temp
      float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
      DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
      // Check battery
      if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
        long batteryVolt = readVcc();
        DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
        uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
        DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
        batteryReportCounter = 0;
    // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
    // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
    long readVcc() {
    // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
    double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
      unsigned int wADC;
      double t;
      // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
      ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
      ADCSRA |= _BV(ADEN);  // enable the ADC
      delay(20);            // wait for voltages to become stable.
      ADCSRA |= _BV(ADSC);  // Start the ADC
      while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
      wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
      t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
      return (t);   // The returned temperature in degrees Celcius.
     * Parameters
      bool tx = force;
      float temperature = humiditySensor.readTemperature();
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
        gw.send(msgTemp.set(temperature,1));
        measureCount = 0;
        DEBUG_PRINTLN("T sent!");
      int humidity = humiditySensor.readHumidity();
      raHum.addValue(humidity);
      if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
        gw.send(msgHum.set(humidity));
        lastHumidity = humidity;
        measureCount = 0;
        DEBUG_PRINTLN("H sent!");
  • @LastSamurai thanks, progress, I'm getting this now, which means it's working! Finally, a working node from a complete rookie like me!
    Serial started
    Voltage: 3389 mV
    Internal temp: 266.00 *C
    send: 100-100-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
    send: 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-100 s=255,c=3,t=15,pt=0,l=2,sg=0:
    sensor started, id=100, parent=0, distance=1
    send: 100-100-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,st=fail:TempHumTest2
    send: 100-100-0-0 s=255,c=3,t=12,pt=0,l=12,sg=0,st=fail:1.0 17052016
    send: 100-100-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
    send: 100-100-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=fail:
    T: 998.00
    TempDiff :1098.00
    send: 100-100-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:998.0
    T sent!
    H: 118
    HumDiff  :218.00
    send: 100-100-0-0 s=1,c=1,t=1,pt=2,l=2,sg=0,st=ok:118
    H sent!
    Battery voltage: 3359 mV
    Battery percent: 104 %
    send: 100-100-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:104
    I think that the readings are not accurate though, not sure why, but I'll have a go at figuring our why anyway!
    @rsachoc
    Congrats !!!
    @GertSanders Thx a lot for your help! I had no clue about the HTU21D lib.
  • so with the correct library there is no need to solder those 3 spots together!?
    @siod
    The "spots" are there to connect the pullup resistors to the SDA and SCL lines. This is always needed, regardless of the library of the board onto which you connect the sensor board does not provide pullup resistors itself. On a minimal board like the one in this thread, this is not the case, so the pull up resistors are needed.
  • ok, thanks for making it clear for me Gert!!
    update:
    finally found time to build my sensor and it seems to work fine, will do more testing but for now my results are:
    7.5 uA when sleeping, 15,3 mA when working (every 15 minutes for about 2seconds, but I think my cheap multimeter gives bad readings on those spikes, I guess itยดs only around 1 mA)
    seems to be okay, isnยดt it?
    edit:
    I have 2 reed switches attached. I recognized that I have +0,10 mA for each reed switch when activated. So when reed switches are both touching their counterpart I have a sleeping consumption of 0,20 mA. Why is that??
    I'm trying to convert existing Si7021 sensor code from 1.5 to 2.0.0 library. I change the code and then I was getting an error which said:
    Si7021_sensor_MySensors_2.0.0:158: error: 'si7021_env' has no member named 'humidityPercent'
    exit status 1
    Then I chech the Si7021 library, and how I saw there wasn't member 'humidityPercent', but there was a member 'humidityBasisPoints'.
    So I change line from:
    ...to:
      int humidity = data.humidityBasisPoints;
    Then code compiles and I upload it to Slim Node Si7021. I leave sensor and today I checked it log on Domoticz. I have this:
    Temperature looks ok, but Humidity value jumping a lot, thats why I don't want to believe it is true.
    Could someone, who has a 2.0.0 library and Si7021 sensor chech is it same situation? Becose I have only one Si7021 sensor.
    Maybe someone could look also on the code and say if I convert it right?
    Converted code:
    by m26872, 20151109
    #define MY_NODE_ID 5             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
    #define MY_BAUD_RATE 115200
    #include <SI7021.h>
    //#define DEBUG
    #ifdef DEBUG
    #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
    #define VMIN 1900
    #define VMAX 3300
    #define AVERAGES 2
    SI7021 humiditySensor;
      sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
      DEBUG_SERIAL(115200);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
      delay(500);
      raHum.clear();
      measureCount ++;
      // Check battery
      sleep(SLEEP_TIME);
    long readVcc() {
      unsigned int wADC;
      double t;
     * Parameters
      bool tx = force;
      float temperature = data.celsiusHundredths / 100.0;
        measureCount = 0;
        measureCount = 0;
    Thank You!
    @jacikaas where did you get the si7021 library? Take a look at the sensebender sketch for a good reference.
  • @AWI
    I download Si7021 library from here: https://github.com/LowPowerLab/SI7021
    I was heard about Sensbender node, but never look deeper what is in it. I will look at it and try to understand whats in there. I just learning about all that stuff, so it will be good practice ๐Ÿ˜Š
    @jacikaas that's the way to go. The sensebender sketch contains some rather nice best practices for low power. You best replace the si library with the one in the MySensors examples on github.
  • @AWI I try to replace library from this one https://github.com/LowPowerLab/SI7021 to this one https://github.com/mysensors/MySensorsArduinoExamples
    to work it I need to return variable name from:
    to:
    I think this library https://github.com/LowPowerLab/SI7021 was updated, so it is not suitable for this one code. Now I test it again and everything looks fine:
    Temperature and humidity node unregister or stop working repeatedly for about 2 hours (2h25min, 2.20, 1.50...). But after that it start to send data again, for some time and then goes around again. ๐Ÿ™‚ I will try to understand why it happening too.
  • 29
  • 90
