  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.4k Views 18 Watching
  • carlierdC
    carlierdC
    carlierd
    I am using RFM69. No fake as it's working perfectly at other frequency.
    @GertSanders
    I tried three different configurations:
    • 16 MHz with crystal
    • 8 MHz internal
    • 1 MHz internal (with some st=fail)
    I measured power consumption in sleep mode and found that it's very close to 4uA with all configurations. So why using the 1 MHz ? Do you have better consumption when using 1 MHz ?
    The best configuration for me will be the 8 MHz internal as it avoid to used the crystal.
    David.
    GertSandersG S 2 Replies Last reply
    • carlierdC carlierd
      @GertSanders
      • 8 MHz internal
      David.
      GertSandersG
      GertSandersG
      GertSanders
      @carlierd
      In sleep mode it does not matter which frequency is used. The watchdog timer runs off its own clock and that is the same for all three cases. The fact that you get around 4 uA is just because you still have a watchdogtimer running. With full deep sleep and complete shutdown of the radio we should see 1-2 uA if external pullup of more then 2MOhm is used.
      The mcu frequency is important for the active time. Higher frequency means faster startup and faster completion of tasks.
      8Mhz is a good compromise as the internal oscillator is less powerhungry then fullswing crystal.
      And you need less parts.
      carlierdC 2 Replies Last reply
        @GertSanders
        • 8 MHz internal
        David.
        Samuel235
        @carlierd, all that i can say is; do not rely on serial communication working. I'm running my custom made node on 8MHz internal, can use the serial monitor but i can not upload via serial. Only ISP uploads using programmer.
        MySensors 2.1.1
        GertSandersG carlierdC 2 Replies Last reply
        • S Samuel235
          GertSandersG
          GertSandersG
          GertSanders
          @Samuel235
          I have no issues with ftdi uploads at 8Mhz internal and 38k upload speed on my nodes. Even for 25k byte sketches.
          S 1 Reply Last reply
          • GertSandersG GertSanders
            @Samuel235
            Samuel235
            @GertSanders said:
            @Samuel235
            I've been told that it should work but atmel do not advise it or support it apparently. There are chances that it wont work and mine doesn't. I had the discussion regarding it in my nodes topic but the conversation just dropped off and went stale.
            MySensors 2.1.1
            • S Samuel235
              @GertSanders said:
              @Samuel235
              GertSandersG
              GertSandersG
              GertSanders
              @Samuel235
              That depends on the upload speed. At higher speeds the error on the frequency of the internal oscillator gets more important. It can be off by several percent (from 8mhz) and then avrdude can fail. I have experimented with 9600 baud and there the deviation of the internal 8mhz has to be severe before the serial uploads starts to feel the effect.
              So try using a 8Mhz boot loader prepared for an 9600 baud upload.
                @Samuel235
                Samuel235
                @GertSanders, i did do, that's the latest solution i tried. No joy.
                MySensors 2.1.1
                  @carlierd
                  carlierdC
                  carlierdC
                  carlierd
                  @GertSanders Thanks for explanation. It confirms what I imagine !
                  I am using a 10MOhm resistor but not the full deep sleep as I want to periodically send the battery.
                  I will try it because 1-2 uA is very low ;)
                  • S Samuel235
                    carlierdC
                    carlierdC
                    carlierd
                    @Samuel235 No issue to with the FTDI.
                    I just found a small problem due to the Arduino IDE. As I often change board (from UNO to different bootloader) I discover that the menu is sometime not coherent with the real setting. So I found that selecting two or three times board parameters (including port) is the solution to avoid communication issue.
                    • S Samuel235
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @Samuel235
                      Would you want to try a bootloader with an upload speed of 4800 ? I can make that for 8Mhz if you want (just to test)?
                        @Samuel235
                        Samuel235
                        @GertSanders, that would be fantastic if you wouldn't mind. Its for my in wall light switch custom made node that you're following. Thanks you, much appreciated.
                        MySensors 2.1.1
                        GertSandersG 2 Replies Last reply
                        • S Samuel235
                          GertSandersG
                          GertSandersG
                          GertSanders
                          #74
                          @Samuel235
                          here is the boot loader in 2 versions: one will flash port PB0 and the other does not.
                          You need to use the following fuse settings in the board file:
                          bootloader.low_fuses=0xE2
                          bootloader.high_fuses=0xDE
                          bootloader.extended_fuses=0x06
                          1_1458903521561_optiboot_atmega328_08M_004800_NOLED.hex
                          0_1458903521561_optiboot_atmega328_08M_004800_B0.hex
                          I saw that you use high fuse 0xDA
                          I'm assuming you use a boot loader larger then 512 bytes. Optiboot fits inside 512 bytes, so we need to define a space of 256 words (1 word = 2 bytes in AVR 8bit).
                          • S Samuel235
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @Samuel235
                            For my boot loaders based on Optiboot 6.2, I normally use high fuse set to 0xDE
                            Extract from my boards.txt file:
                            menu.mhz=CPU Speed
                            menu.bod=Brown Out Detection
                            28PinBoard.name=atmega328p based - 28 pin DIL
                            28PinBoard.upload.tool=arduino:avrdude
                            28PinBoard.upload.protocol=arduino
                            28PinBoard.upload.maximum_size=32256
                            28PinBoard.upload.maximum_data_size=2048
                            28PinBoard.bootloader.tool=arduino:avrdude
                            28PinBoard.bootloader.unlock_bits=0x3F
                            28PinBoard.bootloader.lock_bits=0x0F
                            28PinBoard.build.core=arduino:arduino
                            28PinBoard.build.mcu=atmega328p
                            28PinBoard.build.board=AVR_GERTSANDERS28PinBoard
                            28PinBoard.build.variant=28PinBoard
                            28PinBoard.menu.bod.4v3=4V3
                            28PinBoard.menu.bod.4v3.bootloader.extended_fuses=0x04
                            28PinBoard.menu.bod.2v7=2V7
                            28PinBoard.menu.bod.2v7.bootloader.extended_fuses=0x05
                            28PinBoard.menu.bod.1v8=1V8
                            28PinBoard.menu.bod.1v8.bootloader.extended_fuses=0x06
                            28PinBoard.menu.bod.off=Disabled
                            28PinBoard.menu.bod.off.bootloader.extended_fuses=0x07
                            28PinBoard.menu.mhz.8Mi-38K4-D8= 8Mhz - internal - 38K4 - D8
                            28PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.low_fuses=0xE2
                            28PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.high_fuses=0xDE
                            28PinBoard.menu.mhz.8Mi-38K4-D8.build.f_cpu=8000000L
                            28PinBoard.menu.mhz.8Mi-38K4-D8.upload.speed=38400
                            28PinBoard.menu.mhz.8Mi-38K4-D8.bootloader.file=myoptiboot/optiboot_atmega328_08M_038400_B0.hex
                              @Samuel235
                              menu.mhz=CPU Speed
                              Samuel235
                              @GertSanders I used that DA high fuse simply to make sure the default bootloader fitted, however if its too big will it cause issues on serial ipload even if its a very small upload? Could that be the reason?
                              I will try your bootloader without the LED as my module doesn't contain the LED. This is very hard to read from a mobile device so i will attempt this when i get home tonight. Thank you once again for your files and time.
                              MySensors 2.1.1
                                @carlierd
                                carlierdC
                                carlierdC
                                carlierd
                                @GertSanders Hello. I tried the full deep sleep and it's really amazing !
                                I used your 8MHz with internal crystal and B0 led, BOD disabled. RFM69 for radio and just a switch via a 10MOhm resistor.
                                With the switch open: 280nA
                                With the switch close: 580nA
                                Measures done with a uCurrent Gold.
                                So I am sure now that I found the good bootloader for my application. It's simple to install and I can change easily the BOD !
                                Thanks !
                                  Thanks !
                                  GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @carlierd
                                  Great to hear those low consumption numbers.
                                  carlierdC 1 Reply Last reply
                                    @carlierd
                                    carlierdC
                                    carlierdC
                                    carlierd
                                    @GertSanders
                                    Yes, very impressive ! But finally not a lot of difference with the same node using interruption and sleep.
                                    The auto-discharge of AA batteries is really important compare to node consumption.
                                    David.
                                      @Samuel235
                                      menu.mhz=CPU Speed
                                      Samuel235
                                      @GertSanders, I have just managed to make time to remake a node and troubleshoot its upload issues with your suggested solution. So i went a head, got everything made up the minimal version, MCU, caps, and programming headers. I made sure all connections were working fine, they were. I then read the fuses, all fine and dandy. I then burnt your suggested fuses of;
                                      Then the problem came. I lost all contact to the node, tried slowing the clock rate down on AVRDUDE to read it, nothing. I've hooked up my crystal just in case it burnt it incorrectly and thought it had an external crystal, nothing there either.
                                      I'll be honest, i'm a little confused.
                                      MySensors 2.1.1
                                      • S Samuel235
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        @Samuel235
                                        I'm out of ideas myself. I have been using several boot loader versions with the LED on different pins and different upload speeds or clockspeeds, and so far all my boot loaders work on my nodes.
                                        Maybe you should write down step by step what you do, without assuming we know which steps you take, so we can see if the procedure is correct. Other then that it could be a board issue, but then if you already have a working board which allows uploading ???
                                          Samuel235
                                          @GertSanders
                                          Here is the process i have gone through so far:
                                          1. Soldered the MCU in place.
                                          2. Soldered the ISP and FTDI header in place.
                                          3. Soldered the Capacitors and resistor in place.
                                          4. Connected the board to PC through ISP.
                                          5. Checked for continuity through-out the board on all ISP header Pins and corresponding MCU pins.
                                          6. Check for correct voltage on all of the VCC and GND points.
                                          7. Ran a fuse check on AVRDUDE and got back all the default fuses.
                                          8. Checked that your fuses were going to be okay with my board using the fuse calculator.
                                          9. Entered your suggested fuse settings into AVRDUDE and burned.
                                          10. Went to read the fuses (like i always do after burning them to double check they have been applied). Got no answer for the device.
                                          11. Disconnected and connected the board back and read fuses over and over again with no hope with all of the speed options available within AVRDUDESS.
                                          12. Connected a 8MHz external crystal and checked for fuse readings yet again, nothing.
                                          13. Came here to see if you have any idea what has happened.
                                          I didn't even get to the point of choosing one of your bootloaders that you gave me to try, so i'm more than sure it is either a fuse problem or a board problem (which i'm doubtful of since it was working before i burned the new fuse settings).
                                          I haven't soldered the Radio, the radio's capacitor, battery holder, or the screw terminal block. Other than that, everything else has been assembled. The only other hardware thing that it could be, but not sure why it would work until i burnt the fuse settings, is there may be a 4.7uF as one of the capacitors where it should be a 0.1uF. I have replaced the one on the reset line so i can guarantee it is not that one. The only other caps on the board are decoupling/filtering caps.
                                          I do already have one board with the fuses that you saw me use before (which you questioned why i used the size of the boot sector that i did) and that is working perfectly fine. But as you know that is just running a sketch that was uploaded through "Upload using programmer".
                                          MySensors 2.1.1
