  3. MH Z19b - Running CO2 sensor on batteries
sensorsco2z19battery sensorz19bbatterymh z19bmh z19co2 sensorsmhz19bbattery poweredmhz19
3 Posts 3 Posters 3.4k Views 3 Watching
  • S
    Siddharth Velappan
    I'm trying to run the MH Z19b CO2 sensors interfaced by a PIC microcontroller, powered by 3.6V batteries.
    I would like to get the most out of the battery life. So, I have used a transistor and a GPIO pin from PIC to control the power supply to the CO2 sensor programmatically.
    Please find below, the pseudo code of the programming logic I had used to take CO2 measurements from the MH Z19b sensor. I would like to know if this logic will provide me valid measurements. I am trying to measure the CO2 concentration once in every 15 minutes.
    start_PIC();
    while(true) {
        MHZ19_power_on();
        PIC_sleep(120 seconds);
        /** Till 120 seconds, CO2 sensor was giving 400ppm and only after that I started getting realtime values **/
        MHZ19_get_CO2_concentration_value();
        MHZ19_power_off();
        PIC_sleep(900 seconds);
    • alowhumA
      alowhumA
      alowhum
      These type of sensors often have a warm-up time, often measured in minutes. The datasheet will tell you. If you don't let it warm up you will get poor readings.
      • B
        B
        bitttttten
        Hi @Siddharth-Velappan
        The warmup time of the MH Z19b is 3 minutes. So 2 is probably fine, but you could probably do 3 just in case. Although 2 would save your more battery time.
        Do you mind explaining your setup a bit more? I would love to do something similar but I do not know where to get started with the PIC microcontroller!
