  3. How to make sense of Struct data received from Arduino in RPi via NRF24?
arduinoraspberry pirf24
2 Posts 2 Posters 1.1k Views 2 Watching
  • N
    N
    nrf24_is_hard
    Hi guys,
    I know that for a simple transmission e.g. humidity and temperature, the Arduino can simply fit these into a float array and send it to the RPi.
    The RPi can then execute the following code snippet to get the value:
    DataBytes=8
    receivedMessage=bytearray(DataBytes)
    radio.read(receivedMessage,radio.getDynamicPayloadSize())
    data = struct.unpack('ff',receivedMessage)
    humidity=data[0]
    temperature=data[1]
    Arduino snippet:
    struct values{
    char name[15];
    float temp;
    float humi;
    float light;
    float soilMoist;
    float soilTemp;
    float gasSensor;
    float pirSensor;
    struct values DataToSend;
    DataToSend.temp=dht.ReadTemperature();
    //continue storing data in DataToSend
    radio.write(&DataToSend,sizeof(DataToSend))
    My question is now, how would I send this struct from the Arduino to the RPi with a similar method like the float array?
    OldSurferDudeO 1 Reply Last reply
    • N nrf24_is_hard
      Hi guys,
      DataBytes=8
      humidity=data[0]
      temperature=data[1]
      Arduino snippet:
      struct values{
      char name[15];
      float temp;
      float humi;
      float light;
      float soilMoist;
      float soilTemp;
      float gasSensor;
      float pirSensor;
      OldSurferDudeO
      OldSurferDudeO
      OldSurferDude
      @nrf24_is_hard When I sent data between an Aduino and the RPi I discovered that I have to make the the receiving and the sending structs the same size AND the variables be on 4 byte boundaries. Change your char name[15] to char name[16]
      Another challenge is that the number of bytes of type int are different. If I remember correctly, Arduino Uno is 2 bytes and RPi is 4 bytes.
      To make matters worse, some compilers make the least significant byte the first byte of a word and others make it the last byte of a word. eg, sending the value 1 would be received as 16777216 (0x00000001 vs 0x01000000)
      There are a lot more gotcha's ;)
      OSD
