  3. 💬 Easy/Newbie PCB for MySensors
mysensorsbatteryeasynewbiepcbmysx
716 Posts 111 Posters 700.4k Views 93 Watching
  • sundberg84S sundberg84
    @mickecarlsson - not on the RFM69 version, no. PCBway has updated the NRF24 version so a good sign.
    Something went wrong with the update of the RFM69 version so I had to activate it 21hours ago:
    Lets hope PCBway picks this up today.
    mickecarlsson
    @sundberg84
    OK, good news. I will check it tomorrow and hopefully order a batch (or two).
      mickecarlsson
      Still no rev 6 on itead or pcbway for rfm69 version :-(
      • M mickecarlsson
        @mickecarlsson no something went wrong so Rev 5 is ok to order! This is easy rev 10!
        • ร
          ร
          รอเรือ
          wrote on last edited by รอเรือ
          #584
          Hello @sundberg84
          What if feeding a Pro Mini 3.3V (EasyPCB Nrf24l01+ edition rev 10) with regulated power on RAW. (I have 5 VDC). I guess I can feed the radio via the VCC terminal instead of using an external voltage regulator. Can the EasyPCB be used in such a setup?
          Edit: To answer my own question. I should RTFM :facepunch:
          It states clearly that:
          "(If you are using regulated 3.3v, use 5v instructions but skip the voltage regulator and bypass this with a jumper between Vin and Vout"
          Thanks anyway!
          franz-unixF 1 Reply Last reply
            mhkid
            wrote on last edited by mhkid
            #585
            This post is deleted!
            • ร รอเรือ
              Hello @sundberg84
              Thanks anyway!
              franz-unixF
              franz-unixF
              franz-unix
              @รอเร-อ I have a similar need, but not exactly the same.
              My power route is:
              18650 Lipo (2.7 - 4.2 V) -> TP4056 (charger) -> Booster (5V) -> Raw pin of pro mini 3.3V -> Vcc of pro mini 3.3V -> Radio (NRF24)
              In my case the easy newbie pcb is not directly suitable because the Vout of the Booster is connected to Vcc instead of raw.
              So my idea is to use a modified version of the easy newbie pcb with the schematic posted here
              in order to have more flexibility in the power options.
              Actually I don't have the skills to design a pcb, but maybe, if the idea is good, someone else could design it.
              This schematic is compatible with all the power options actually supported by the easy newbie pcb, and supports also new possibility, simply changing a couple of jumpers
              • Nca78N
                Nca78N
                Hello @franz-unix, can't you just bend the output pin of the booster at 90° and solder a wire from it to the raw pin ?
                • franz-unixF
                  franz-unixF
                  franz-unix
                  @nca78 Yes it should work.
                  If I connect the output of the tp4056 to the gnd and reg input of the screw terminal of the easy newbie pcb and then I run a wire from the Vout of the booster to the raw input of the screw terminal, the final result is also quite clean and it is not necessary to solder the wire directly on the pro mini.
                  I think that, in this case, the reg jumper must be NOT shortened.
                  • Z
                    Z
                    zelen
                    I ordered 10 PCBs using "Order from PCBWay" button. It only asked me about PayPal card and din't require any registration on PCBWay. So, everything looks good, PayPal transaction is completed. Can somebody tell me please how can I track it? Probably I'm missing tracking option somewhere... Thank you!
                    P.S.
                    Cant wait to try it out. :)
                    • Z zelen
                      P.S.
                      @zelen I'm not sure. You didn't receive any email? I normally get a email once they are finished and shipped with tracking.
                      Z 1 Reply Last reply
                      • Z
                        Z
                        zelen
                          Z
                          Z
                          zelen
                          @sundberg84 thank you for clarification. I expected email right after making an order. So, I will wait for finishing production and shipment.
                          • H
                            H
                            Harrdy
                            I use some of old rev8 boards. I have noticed that I use a ceramic capacitor instead of an electric capacitor compared to the images for the battery measurement. Does it matter? Or should I replace the ceramic capacitor (104) with an electric capacitor?
                            sundberg84S gohanG 2 Replies Last reply
                            • H Harrdy
                              @harrdy should work just fine.
                              • H Harrdy
                                @harrdy remember to take a few readings and average out the battery value
                                • manosM
                                  manosM
                                  manos
                                  Hello @sundberg84, I would like to buy the Easy/Newbie PCB for MySensors but I have a few questions
                                  I want to use it the 5V Arduino Pro mini not the 3V version
                                  I also want to use the battery monitor
                                  Is it ok or should I modify "something"
                                  Also all the pcbs have the battery "expansion: or not?
                                  Thanks, Emmanuel
                                    Why would you want to use the 5v arduino on batteries?
                                    • manosM manos
                                      Thanks, Emmanuel
                                      @manos
                                      Then you need to use the nrf24l01+ version, that works fine - the RFM69 version needs a 3.3v Pro Mini only.
                                      As @gohan said - don't use batteries on a 5v node. Use a 3.3v because it will use up your batteries very quickly. See the guides i have on openhardware for different modes on my PCB.
                                      "something" is hard to understand, you can modify i many different ways depending on what you want to do. All the basic "modifications" can be found if you read the project page on openhardware.io
                                      manosM 1 Reply Last reply
                                        @manos
                                        manosM
                                        manosM
                                        manos
                                        @sundberg84 thanks for your response
                                        If I don't care about battery consumption can I still view and use the battery monitor to be alarmed when battery is empty?
                                        • manosM manos
                                          @manos yes you can.
