  3. Pressure Sensor Node send fails.
send failpressure sensornode id
5 Posts 3 Posters 2.7k Views 1 Watching
  • Suresh MaliS
    Suresh MaliS
    Suresh Mali
    I have been trying to build a sensor node for Temp+Baro, and have been unsuccessful since last week. The message fails
    Below is the output from Serial Monitor
    req id
    send: 255-255-1-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=fail:
    sensor started, id=255, parent=1, distance=2
    req id
    req id
    req id
    req id
    Temperature = 18.10 *C
    Pressure = 1074.38 hPa
    Forecast = unknown
    req id
    req id
    req id
    Temperature = 17.90 *C
    Pressure = 1074.37 hPa
    Forecast = unknown
    req id
    req id
    Temperature = 17.80 *C
    Pressure = 1074.46 hPa
    Forecast = unknown
    req id
    req id
    I have researched the forum a lot and tried the below, but no success.
    • Added 10uF caps to both Node and Gateway. Also tried with 100uF caps.
    • Cleared EEPROM.
    • Changed Bootloader.
    • Changed NRF Radio
    • Tried different power source
    I have one more node with Relay and its working fine. So i guess the problem should be with the node. The node is a custom built board with Optiboot. I worked fine a couple of times and now I wont work.
    1_1453856608688_IMG_20160127_0617541-(2).jpg 0_1453856608687_IMG_20160127_061731-(2).jpg
    Log file for MYSController when I had the MYSBootloader and tried updating FW using OTA. 0_1453856213616_MySensors_20160127-053410.log
    I am unable to figure out the problem and seek assistance from the experienced gurus out there.
    Appreciate and help I can get.
    • Suresh MaliS
      Suresh MaliS
      Suresh Mali
      I have also tried other sketch on same node and they work fine.
      • E
        E
        ericvdb
        Is your controller setup to hand out ID's to the sensor nodes?
        What if you set a fixed ID?
        Suresh MaliS 1 Reply Last reply
        • E ericvdb
          Suresh MaliS
          Suresh MaliS
          Suresh Mali
          @ericvdb I tried with MYSController. Set Assign ID to Auto, also tried settings up static ID, but does not seem to work.
          • m26872M
            m26872M
            m26872
            Can you simply connect your baro sensor to relay node and see if something happens? Can you exchange hw/sw with the working (relay) node in any other way? Are both the working node and this one connecting to your repeater node 1 (parent = 1)?
