  3. IOBroker
  4. [solved] Problem with ioBroker and MySensors 2.0
Scheduled Pinned Locked Moved IOBroker
20 Posts 5 Posters 9.2k Views 6 Watching
  • stefaanvS
    stefaanvS
    stefaanv
    wrote on last edited by hek
    Did any of you manage to make ioBorker run with a Mysensors 2.0 serial gateway ? It doesn't work for me. I see the serial messages in the log, but nothing in the States list. When I activate the "Inclusion" mode, it is deactivated all by itself.
    The few tips I get from the ioBroker forum don't make any difference.
      That's weird. The serial protocol hasn't changed between the 1.5->2.0 version.
      stefaanvS BluefoxB 2 Replies Last reply
        stefaanvS
        stefaanvS
        stefaanv
        @hek
        According to the ioBroker people, it's definitely because of 2.0. Here is the link to the forum. http://forum.iobroker.net/viewtopic.php?f=12&t=3577
        Looking at the logs, it seems the adapter has a problem to find the beginning of the MySensors messages. Did something change wrt end-of-line charcters ?
          Hmm. do you have the possibility to compare the serial log on your gateway when running 1.5/2.0? Might help to determine what goes wrong.
          • stefaanvS
            stefaanvS
            stefaanv
            OK. Will take some time, I'll have to recompiler the 1.5 version. It'll be interesting to see if the 1.5 version works with ioBroker out of the box.
            • mysensors-6043M
              mysensors-6043M
              mysensors-6043
              Hi, I have iobroker running on a rasPi3 and an instance of mysensors configured. This is working so far. On a nodeMCU, mysensors 2.0 is used. I can pass data between.
              cheers
                BluefoxB
                BluefoxB
                Bluefox
                @hek Hello, I am the developer of ioBroker and adapter of mySensors for ioBroker. One of the user has a Problem with the sketch. And I automatically too. Accordingly to log output:
                2;1;1;0;0;23.5
                1;8;1;0;2;0
                1;7;1;0;39;-12.17
                1;255;3;0;0;75
                1;5;1;0;36;1
                1;2;1;0;1;63.38
                1;2;1;0;0;12.87
                1;2;1;0;38;12.56
                1;2;1;0;39;-43.80
                1;1;1;0;23;17.69
                1;255;3;1;0;1475773988
                0;255;0;0;18;2.0.0
                0;255;0;0;18;2.0.0
                (from bottom to top) there is no representation messages about datapoints. And I thought, that this information is required to describe the received information. In my driver I send "'0;0;3;0;19;force presentation'" message to receive the representation information jsut after connection esteblishment.
                Why the sketch do not send representation info? There is no use on data without to know the name and configuration for that.
                  Is it from a separate node or sensors attached to the gateway the presentation is missing?
                  Do you have the sketch?
                  Which version on the node/gateway?
                  • BluefoxB
                    BluefoxB
                    Bluefox
                    Accordingly to http://forum.iobroker.net/viewtopic.php?f=12&t=3577&start=20#p36227 he has 2.0 Serial with
                    Seeeduino for the gateway (serial)
                    Seeeduino for the chicken shed
                    Sensebende for the temperature sensor
                    Raspberry pi 2 and 3 for the controller
                    BTW, is it not the good idea to print the version out in log? What is this? 0;255;0;0;18;2.0.0
                      Might be best to ping @stefaanv here...
                      How does the log look on the node where the presentation messages is sent from?
                      Do you get failed transmissions?
                      • BluefoxB
                        BluefoxB
                        Bluefox
                        And this one must be a sketch: http://forum.iobroker.net/viewtopic.php?f=12&t=3577&start=20#p36212
                          Ok, it sends 9 presentations in a row.... Might be too much depending on how the radio is powered and decoupled.
                          Introducing a wait(50) between each presentation message could resolve the problem.
                          • BluefoxB
                            BluefoxB
                            Bluefox
                            I have this one log from him:
                            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=2,c=1,t=1,pt=2,l=2,sg=0:0
                            2;1;1;0;0;23.5
                            0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.5
                            1;8;1;0;2;0
                            0;255;3;0;9;TSP:MSG:READ 1-1-0 s=8,c=1,t=2,pt=1,l=1,sg=0:0
                            1;7;1;0;39;-12.17
                            0;255;3;0;9;TSP:MSG:READ 1-1-0 s=7,c=1,t=39,pt=7,l=5,sg=0:-12.17
                            1;255;3;0;0;75
                            0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:75
                            1;5;1;0;36;1
                            0;255;3;0;9;TSP:MSG:READ 1-1-0 s=5,c=1,t=36,pt=2,l=2,sg=0:1
                            1;2;1;0;1;63.38
                            0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=1,pt=7,l=5,sg=0:63.38
                            1;2;1;0;0;12.87
                            0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=0,pt=7,l=5,sg=0:12.87
                            1;2;1;0;38;12.56
                            0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=38,pt=7,l=5,sg=0:12.56
                            1;2;1;0;39;-43.80
                            0;255;3;0;9;TSP:MSG:READ 1-1-0 s=2,c=1,t=39,pt=7,l=5,sg=0:-43.80
                            1;1;1;0;23;17.69
                            0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=23,pt=7,l=5,sg=0:17.69
                            0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=0,pt=0,l=10,sg=0:1475773988
                            0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=0,pt=0,l=10,sg=0,ft=0,st=ok:1475773988
                            0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=1,pt=0,l=0,sg=0:
                            0;255;0;0;18;2.0.0
                            0;255;0;0;18;2.0.0
                            0;255;3;0;9;TSM:READY
                            0;255;3;0;9;TSM:GW MODE
                            0;255;3;0;9;TSM:RADIO:OK
                            0;255;3;0;9;TSM:INIT
                            Is the information you required there?
                            • BluefoxB
                              BluefoxB
                              Bluefox
                              Where can you see that?
                              It is really strange I have my answer ready and wait for 2 minutes to send it out. In this time you answer on my previous question and my answers looks silly because the it is old.
                              • BluefoxB
                                BluefoxB
                                Bluefox
                                I do not understand, should ioBorker use wait(50) or Sketch? (I guess sketch, but to be sure)
                                  In the sketch.
                                  stefaanvS 1 Reply Last reply
                                    In the sketch.
                                    stefaanvS
                                    stefaanvS
                                    stefaanv
                                    @hek
                                    We're making progress. I'm already seeing both nodes in ioBroker Objects tree. The sensebender node also reports temperature and humidity.
                                    0_1476000444616_upload-383148d2-26ea-402a-a4a9-8258a2fa346b
                                    Still, none of the measurements from the chicken shed node get through. Underneath is the log from this node, hope you can make any sense of it. I see a lot of FPAR:FAIL's, hope this is something that can be solved.
                                    Stefaan
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSP:ASSIGNID:OK (ID=1)
                                    TSM:FPAR
                                    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    TSM:INIT
                                    TSM:RADIO:OK
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSM:FPAR
                                    TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                    TSP:MSG:PAR OK (ID=0, dist=1)
                                    TSM:FPAR:OK
                                    TSM:ID
                                    TSM:CHKID:OK (ID=1)
                                    TSM:UPL
                                    TSP:PING:SEND (dest=0)
                                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                    TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                    TSP:MSG:PONG RECV (hops=1)
                                    TSP:CHKUPL:OK
                                    TSM:UPL:OK
                                    TSM:READY
                                    Kippenhok_4
                                    Motor stopped at 60735
                                    application started
                                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=ok:
                                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                    !TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                                    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=fail:0
                                    TSP:MSG:READ 0-0-1 s=255,c=3,t=0,pt=0,l=10,sg=0:1476000019
                                    TSP:MSG:ACK msg
                                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=0,pt=0,l=10,sg=0,ft=2,st=ok:1476000019
                                    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=fail:Kippenhok
                                    !TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0
                                    !TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=16,pt=0,l=0,sg=0,ft=2,st=fail:
                                    !TSP:MSG:SEND 1-1-0-0 s=2,c=0,t=30,pt=0,l=0,sg=0,ft=3,st=fail:
                                    !TSP:MSG:SEND 1-1-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,ft=4,st=fail:
                                    !TSP:MSG:SEND 1-1-0-0 s=4,c=0,t=7,pt=0,l=0,sg=0,ft=5,st=fail:
                                    !TSM:UPL FAIL, SNP
                                    TSM:FPAR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    Request registration...
                                    !TSP:SEND:TNR
                                    TSM:FPAR
                                    !TSP:SEND:TNR
                                    TSM:FPAR
                                    !TSP:SEND:TNR
                                    TSM:FPAR
                                    !TSP:SEND:TNR
                                    !TSM:FPAR:FAIL
                                    !TSM:FAILURE
                                    TSM:PDT
                                    Init complete, id=1, parent=255, distance=255, registration=1
                                      ... loop ...
                                    !TSP:SEND:TNR
                                    Door Open, Lux 1407.40, luxState 1, camera off, (-)
                                    Battery 12.07V, -11.90mA
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    --NO-- Time = 5, 0:0:5
                                      ... loop ...
                                    !TSP:SEND:TNR
                                    Door Open, Lux 1384.85, luxState 1, camera off, (-)
                                    Battery 12.07V, -11.20mA
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    !TSP:SEND:TNR
                                    --NO-- Time = 10, 0:0:10
                                      Something is not good. It keeps losing parent because it doesn't hear any ack:s sent by the gateway.
                                      Did you put decouple capacitors on both gateway and repeater? Do you use none amplified radios?
                                        stefaanvS
                                        stefaanvS
                                        stefaanv
                                        @hek
                                        Hadn't done any of the decoupling. Will do so next.
                                        However, by moving the controller closer to the shed, The problem is solved !!
                                        0_1476001429124_upload-ffaeb96a-bf60-48e0-a44e-e5bca67cb6d4
                                        Thanks a million for the support !
                                        jopebeJ 1 Reply Last reply
                                        • stefaanvS stefaanv
                                          @hek
                                          jopebeJ
                                          jopebeJ
                                          jopebe
                                          @stefaanv
                                          Hallo, have the same problem.
                                          I cannot see my node in IO-Broker. Read all the threads in this forum and in IObroker.
                                          Same issue with inclusion mode. Don`t know, what else I can do.
                                          I use the original Ethernet-Gateaway-Sketch from MySensors page, the original Temp-hum-sketch from MYsensors page and installed sometimes MYsensors-adapter in IOBroker.
                                          I use the gateway as TCP-client.
                                          What can I do?
                                          Here the seriell protocol:
                                          IP: 192.168.178.56
                                          0;255;3;0;9;TSP:SANCHK:OK
                                          0;255;3;0;9;TSP:MSG:READ 1-1-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          0;255;3;0;9;TSP:MSG:BC
                                          0;255;3;0;9;TSP:MSG:FPAR REQ (sender=1)
                                          0;255;3;0;9;TSP:CHKUPL:OK
                                          0;255;3;0;9;TSP:MSG:GWL OK
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                          0;255;3;0;9;TSP:MSG:PINGED (ID=1, hops=1)
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=11,pt=0,l=22,sg=0:TemperatureAndHumidity
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                          0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.0
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.7
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:19.9
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.6
                                          0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:46.5
                                          The node was switched on all the time. There is a row of "0;255;3;0;9;TSP:SANCHK:OK".
                                          Then I switched the node of and on again. Now came other infos and I can see the temperatur and the humidity, but not before I switchesd off and on.
                                          Strange.
                                          In IObroker there is nothin to be seen.
                                          Perhaps I use the wrong (chnages wrong?) sketch. Ha sanybody a sketch for the gateaway that runs better?
                                          Thank You in advance
