💬 RFM69 Serial GW (ATMEGA328P)
Nice!
The cp2102 is a good choice: you can upload at a faster speed than you can with an FTDI.
I studied this question and knew that FTDI is more faster than CP2102....
I chosed CP2102 mainly for the low component count which is needed to create a simple usb to serial converter. The baudrate is sufficient enough for the most of the projects imho.
@mtiutiu said in
MySensors RFM69W serial GW:
As for me, i chose CP2102 because he has On-chip voltage regulator 3.3V.
I won't rely on the integrated voltage regulator because usually it's not capable to supply high currents. As I've seen on other USB to serial converter chips the current capability of the integrated voltage regulator is about 50mA or so(maybe some can provide up to 100mA). Anyway if using NRF24l01 radios and small current LEDs then maybe it won't be an issue but I wouldn't count on it on the long term. Radio module + microcontroller + LEDs + other components can reach the 50mA limit especially when using RFM69W or HW variant. Now I know that the TX period may be short and only the average drawn current matters in the end but still I won't take it to the near limits. Just my 2 cents here.
@mtiutiu
I agree. According to the schematic, you do use the MCP1703A-3302 as a voltage regulator, which is rated to 250ma. It seems that many problems are easily avoided when there's a more than ample power source.Also, for whatever reason, the Arduino IDE doesn't seem to support the highest baud rate that's apparently possible with the FTDI. It does though with the CP2101.
Today I managed to finish this project: hardware assembly and initial serial gw sketch upload and I get I_GATEWAY_READY from serial console so everything seems to be in order. I need to perform some more tests though with some nodes attached and see the messages coming in and out but so far it seems very promising. I didnt' soldered the LEDs yet but that's not so important for now :simple_smile: .
CP2102 usb to serial converter chip working(first line from usb devices listing):
mtiutiu@mtiutiu-H67MA-USB3-B3 ~/Work/AVR_Playground/sensors_network/project/SerialGateway $ lsusb Bus 002 Device 015: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 005: ID 045e:0779 Microsoft Corp. LifeCam HD-3000 Bus 001 Device 004: ID 1bcf:0005 Sunplus Innovation Technology Inc. Optical Mouse Bus 001 Device 003: ID 046d:c31c Logitech, Inc. Keyboard K120 Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Code uploading using arduino serial bootloader POC:
mtiutiu@mtiutiu-H67MA-USB3-B3 ~/Work/AVR_Playground/sensors_network/project/SerialGateway $ platformio run --target upload [Tue Feb 14 17:48:38 2017] Processing pro16MHzatmega328 (upload_protocol: arduino, build_flags: -I./lib/MySensors, lib_ignore: MySensors, board_f_cpu: 16000000UL, platform: atmelavr, board: pro16MHzatmega328, framework: arduino) ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Verbose mode can be enabled via `-v, --verbose` option Collected 69 compatible libraries Looking for dependencies... Library Dependency Graph |-- <SPI> v1.0 Looking for upload port... Auto-detected: /dev/ttyUSB0 Uploading .pioenvs/pro16MHzatmega328/firmware.hex avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e950f (probably m328p) avrdude: reading input file ".pioenvs/pro16MHzatmega328/firmware.hex" avrdude: writing flash (13122 bytes): Writing | ################################################## | 100% 3.96s avrdude: 13122 bytes of flash written avrdude: verifying flash memory against .pioenvs/pro16MHzatmega328/firmware.hex: avrdude: load data flash data from input file .pioenvs/pro16MHzatmega328/firmware.hex: avrdude: input file .pioenvs/pro16MHzatmega328/firmware.hex contains 13122 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 3.00s avrdude: verifying ... avrdude: 13122 bytes of flash verified avrdude: safemode: Fuses OK (E:00, H:00, L:00) avrdude done. Thank you
MySController serial gw connection and startup ok message:
Serial gw is working. Tested with real MySensors nodes and it's working properly. Now regarding stability and such - well...that only time will tell us.
Hello, what is the goal of the TXB0104, it's the first time that i see him in a project ?
It's a logic level voltage converter. The MCU runs at 5V so the logic level voltage that it uses on the SPI port which connects to the RFM69W use 5V too. But the RFM69W module runs at 3.3V and it's not 5V tolerant on its SPI port pins.
The purpose of that IC is to convert voltage levels on the SPI lines forward and backward (from 5V to 3.3V and vice versa) in order to not damage the RFM69W chip.
@mtiutiu said in
MySensors RFM69W serial GW(ATMEGA328P):
Oh ok, and just for know, why we don't power the atmega with 3.3V ?
@tonnerre33
Because at 3.3V the atmega328p mcu can run at max 8MHz as per datasheet. So I wanted it to run at double the speed and for that it needs 5V as per datasheet again. Why at 16MHz? Well because I want the gateway to be more faster in general and to quickly process the incoming messages from the entire radio network.
Thanks a lot, now i know why
And to use higher baudrates for the serial port on the mcu also. To achieve higher baudrates you need a higher mcu clock frequency too.
Does anyone have a BOM for this?
@shabba
Sorry but I don't have one now. When I have time I will generate it. For now I'm busy with the Livolo stuff.
I see C5 on the board has polarity. My ceramic caps seem to have no polarity (no markings on it - https://www.digikey.com/product-detail/en/murata-electronics-north-america/ZRB18AR61E106ME01L/490-10991-1-ND/5321192).
I assume that this is ok and this does not need to be a tantalum cap?Thanks.
Yes it's ok. Just make sure that you have 10V rated capacitors(this board runs at 5V so it's best to stay above that). On the radio side you can use 6V capacitors as it's powered at 3.3V but anyway...it's easier to use just 10V types instead of remembering what goes where imho.
Hi @mtiutiu - Did you ever get a chance to make a BOM? Most of the one @tonnerre33 one makes sense but I only bought two boards so being a little cautious
Thanks!
Any BOM?
I still have these PCBs and want to finish em. Can't source a crystal/resonator of about 5x4 mm.
The majority of the components are 0603 SMD package type (except 2 smd resistors on the usb lines which are not really mandatory and can be replaced with a solder bridge).
There you go (extracted from schematic - I can't do better than this because it involves more work and I don't have time for it, sorry):
a) 9 x 100nF 0603 SMD MLCC capacitors, X5R/X7R (voltage can be 10V and above)
b) 3 x 1uF 0603 SMD MLCC capacitors, X5R/X7R (voltage can be 10V and above)
c) 1 x 10uF 0603 SMD MLCC capacitor, X5R/X7R (voltage can be 10V and above)
d) 1 x 22uF 0603 SMD MLCC capacitor, X5R/X7R (voltage can be 10V and above)
e) 1 x 10nF 0603 SMD MLCC capacitor, X5R/X7R (voltage can be 10V and above)
f) 1 x ferrite bead 0603 SMD blm18he152sn1d
g) 3 x 330 ohm 0603 SMD resistor
h) 1 x 1Kohm 0603 SMD resistor
i) 1 x 10Kohm 0603 SMD resistor
j) 1 x 56Kohm 0603 SMD resistor
k) 1 x MCP1703A-3302 3.3V/0.25A voltage regulator
l) 1 x TXB0104 voltage level converter
m) 1 x ATMEGA328P-MU AVR MCU (QFN32 package)
n) 1 x CP2102 USB to serial (QFN28 package)
o) 3 x 0603 SMD LEDs (your pick here)
p) 1 x ATSHA204A (SOT-23 package)
q) 1 x RFM69W module (your pick regarding working frequency)
r) 1 x ZTTCS16.00MX ceramic resonator
s) 1 x USB A type male connector for PCB and 1 SMD reset switch (I have no exact links for this, sorry)
💬 RS485 Ethernet Gateway
OpenHardware.io • 20 Dec 2018, 14:55 • openhardware.io 9 Oct 2019, 12:05 -
MySensors MQTT gateway and serial rs485 sensor node communication
Development • 5 Aug 2017, 06:31 • ehome 5 Aug 2017, 08:15 -
💬 Arduino Serial Gateway for RFM69HW
OpenHardware.io • 24 Jan 2017, 12:49 • openhardware.io 8 Jun 2017, 10:06 -
Trouble with 115200 baud on 3.3V/8MHz Arduino, like Serial Gateway. Solution: Change baudrate.
Troubleshooting • 1 Jun 2015, 20:00 • Stric 3 Jun 2015, 05:21 -
💬 MySensors Gateway for Raspberry PI
OpenHardware.io • 30 Aug 2017, 09:38 • openhardware.io 27 Apr 2018, 21:49 -
💬 MysX2USB
OpenHardware.io • 20 Mar 2016, 08:04 • openhardware.io 23 Feb 2018, 10:33
