  3. IR Blaster (progress)
99 Posts 32 Posters 89.7k Views 24 Watching
    mscott
    3 to 5 here
    • BulldogLowellB
      BulldogLowellB
      BulldogLowell
      I'm in for a couple too...
      • F
        F
        filipq
        Two for me please.
        • DrJeffD
          DrJeffD
          DrJeff
          Mark me down for 1!
          • rvendrameR
            rvendrameR
            rvendrame
            one for me!
            ESP8266 GW + mySensors 2.3.2
            Alexa / Google Home
            • G
              G
              gloob
              I would also take 5
              • jheacockJ
                jheacockJ
                jheacock
                I am interested in at least one, maybe two depending on area coverage.
                • blaceyB
                  blaceyB
                  blacey
                  Placed an order for the first prototype boards today... Sourcing from China to U.S. so it will take a while for them to arrive from the fab but I will keep everyone apprised of the progress. That said, here is a render of the protoboard (v0.5) with NRF24L01+ attached to provide a sense of the board's physical size/footprint (thanks to @tbowmo for the NRF24L01+ 3d-shape).
                  • blaceyB blacey
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @blacey do you know of any reliable way to record and play very long code, like HVAC ones?
                    • Q
                      Q
                      Qu3Uk
                      Mark me down for 1 as well.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        #46
                        @Moshe-Livne
                        @blacey made room for an external flash on board, which probably could be used to store IR codes.
                        The flash that he chose is a 64Kbyte (512kbit), so only the first half of the flash is actually used for OTA updates, which leave us 32Kb external flash storrage available for the user.
                          @blacey: very nice design. I think there will be mysensors production for your board as people are interested... And me too, I can't wait to see all sketches and usecases...
                          In future, it will be great as I feel there is a hardware design movement for Mysensors, very interesting.
                          • G
                            G
                            gigaguy
                            If I am understanding this thread correctly. This would be capable of repeating the IR signal, correct? So, if I put one of these in every room. I can use my universal remote or something similar to change the channel on a tv in another room?
                              @gigaguy
                              Yes that could be one possible use-case.
                              Normally (I would imagine) the blaster would pick up your remotes commands and send them to the controller. What you actually do with this information (on the controller side) is up to you. You might wanna send a command to the z-wave controlled curtains to open. Or turn on the lights in certain rooms.
                              Another usecase could be to create a scene (on the controller) that turns on the tv (or fake-fireplace!) at 7pm every evening.
                              I'm thinking of pausing the tv when someone calls (as I've got the ip-telephone integrated in my HA soulution)...
                              • K
                                K
                                kalle
                                Yes there are many possibilies and I like the design of the board (looks great). We have create a similar device (only on a breadboard at the moment), which has also include RF433 receive and transmit function and we can controlled it by voice. Each IR code is stored in a txt file on a SD card (raw code). A bit hard for me to explain it here with words, but I can record a video how it works in real if anyone will see it in action.
                                It has only one disadvantage - you need two Nano or Mini on a PCB board.
                                • K kalle
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @kalle its not that bad with minis costing few $ each....
                                  • K
                                    K
                                    kalle
                                    Ok, here we go a short video demonstration: www.youtube.com/watch?v=y38oIZgV_cU
                                    • HoffanH
                                      HoffanH
                                      Hoffan
                                      at least one for me
                                      • D
                                        Dheeraj
                                        Any one tried using IR transmitter to send IR signal to AC with mini pro ( 328p ) as mysensor node. I know mini pro have limited ram / rom support.
                                        Note: AC remote send long IR signals which may not be completely captured by IR receivers connected to mini pro. may be one try on rasp pi but that's a last resort.
                                        blaceyB 1 Reply Last reply
                                        • blaceyB blacey
                                          My wife and I were in Italy for the past 3 weeks with friends and family so I didn't have much time to work on the IR Blaster actuator. That said, the long flights back and forth from San Francisco to Italy afforded some concentrated time to finalize the design sufficient for public review before procuring a few prototype boards. To goal of this post is to solicit said feedback so "bring it on" after reading the details below.
                                          @Sparkman - The biggest change is the addition of two more IR LEDs given we are now driving the circuit with a MOSFET (thanks @tbowmo) that can handle higher-current loads; this reduces the risk of IR coverage holes and increases the IR LED component options. However, I have not added a barrel connector for external LEDs to the PCB (yet?) because there are still open issues regarding circuit design to accommodate it (would welcome integration ideas).
                                          I also have not laid the traces for A0, A1, and A2 because these are completely optional inputs, the 3 traces are difficult to place given the physical PCB layout and in fact they may not survive the final board.
                                          Everything is in GitHub in case people want to review the details offline.
                                          The PCB design follows - I had to increase the size of the PCB slightly to accommodate the two additional LEDs.
                                          Here are two renders of the board, sans the radio daughterboard:
                                          Finally, here is the version 0.4 schematic.
                                          Schematic v0.4.pdf
                                          I have also developed a MySensor's IR Sensor Array that will enable me to measure the IR radiant intensity from different points in a room under varying ambient lighting scenarios. The test scenario is that an IR Sensor Array controller will illuminate the IR Blaster and then broadcast to all the IR Sensor Nodes to collect an IR measurement over a specified interval and report the IR level results back to the Sensor Array Controller at which point it will turn off the IR Blaster IRs and log the sensor node results for analysis. This should allow me to select IR LEDs to ensure maximum radiant luminosity without any IR coverage holes/gaps across the 180 degree radiance field. As an interesting side note, the development of the Sensor Array found a messaging limitation in the current MySensors.org library that @hek is planning to address in the next major release.
                                          Ciao,
                                          Bruce
                                          SparkmanS
                                          SparkmanS
                                          Sparkman
                                          Sorry for the slow response Bruce, it's been crazy busy at work and a few projects around the house. I have a few days off in a row now so will finish testing. The circuit board design looks great and I'd be interested in a few as well based on current design.
                                          Al
