Sensebender Micro
    @epierre said:
    is that because I don't have a 1.5 serial gateway ?
    Gateway version shouldn't matter if you get this message at startup of node.
    I have the socket and the FTDI on the same side so I may avoid the above ?
    I don't understand what you mean.
    what should I do from there ?
    this was related to the electric perturbation with headers close to the radio
    @epierre Can you confirm the settings you used in the IDE to program it? Are you sure there are no solder bridges where you soldered the radio or socket for the radio? Have you tried powering it with a couple of AA batteries after you uploaded the sketch?
    Al
    Today I integrated my first 2 sensebender micros into my homeautomation and they almost worked out of the box. I like this board really much! Good work, I will order more!
    Pitfall:
    When updating the mysensors lib from 1.4.x to 1.5 the sensor failed to get an id from the controller which btw was still running on 1.4.x.
    After having done all the things like "clearing eeprom", "soldering a capacitor to the radio" and so on... I noticed that I changed the RF_CHANNEL from the default 76 to some other value in MyConfig.h some months ago (probably for some paranoia reason).
    When updating to lib 1.5 the sensor sketch got the 76 while the gateway still used the other one and so the communication between both failed. After changing the radio channel to the one the controller uses, everything worked very quickly!
    Probably this post helps someother guy who fell into the same trap.
    My sense bender works perfect when sending directly data directly to serial gateway (vera 5), however when I move it out of range to the serial gateway and want it to connect to my repeater node it does not want to discover the repeater node. Anyone else had this problem?
    Remember that it takes a few ( ~5) failed transmits until it searches for a new parent node.
  • @johnr
    Is your repeater node still on MySensors 1.4? I had a similar problem and upgrading to 1.5 solved it.
  • You are probably right. I did not realise sense bender was pre loaded with 1.5
    I think easiest for me would be to downgrade sense bender to 1.4 is it possible?
    Sensebender is still on 1.4, as we haven't prepared new firmware for it yet.
    Mysensors 1.4 and 1.5 should be compatible with each other, right @hek ?
    Yes, it should.
    But as @Dewalt says, there was a bug in repeater functionality. So upgrading the repeater is a good tip.
  • Upgrading repeater to 1.5 solved this issue. Thanks for the quick help. 1.4 sensors communicate OK with the 1.5 repeater as far as I can see right now.
  • I try to make a 3D box for SenseBender Micro with CR123 battery.
    Screenchot :
  • first print test : IMG_20150921_230740.jpg
    @Fabien
    Nice work, what is the dimensions of the enclosure?
  • @mvader said:
    question about the default sketch for this board.
    if i read correctly
    // How many milli seconds should we wait for OTA?
    #define OTA_WAIT_PERIOD 300
    #define FORCE_TRANSMIT_INTERVAL 30
    if temps don't change more than .5 i shouldn't see a transmit but once every 30 minutes
    i have 2 running right now
    and both send temp and humidity every 1-2 minutes and the numbers are the same or in some cases only different by .1
    i have it set to .5 so the question is
    1. why does it transmit every minutes when the temp and humidity are the same
    2. why is it transmitting even with as little as .1 change
      1 board is running 1.2 and the other is running the 1.3 sketch from git
      Battery however does transmit every 60 minutes as it's supposed to.,
      thx
    @mvader
    Have you tried to hook up a serial connection to your sensebender? It writes the difference from the last transmitted measurement, everytime a new measurement is taken (every minute).
  • @tbowmo 47x37 height : 27
    I will make some improvment (can not test, my printer is in maintenance mode !) and post files for others.
  • @tbowmo said:
    @mvader
    so if i want it to transmit less frequently (save battery?) i would increase the measure interval. correct?
    I have some situations where i want frequent measuring (1 minute), and some where 15 minutes or 30 minutes would do fine.
    @mvader
    Yes, you could save battery, by changing to 10/15 minute check interval..
    But still, the interesting thing is why it transmits every minute.. That's why I would suggest to check the serial output..
    There is an explanation to the problem further up in the thread:
    @gloob said:
    Hello
    needs to be replaced with
    @korttoma
    thanks for helping my memory 🙂
  • @korttoma i did see that. but your saying that is what is causing it to transmit every 1 minute?
    @mvader yes, it is rounding the temperature difference to the nearest degree so the difference is almost always more then the 0.5.
    Just a hint, itead studio is starting a sale with 10% off on all imall items.. So maybe it's time to buy some Christmas presents for the inner geek 🙂
  • Oh no! Lousy timing, I just bought some...
    ... in fact, they arrived today.
    Speaking of which, whilst I got them to run the default sketch, do I actually need a programmer to do anything different, or can this be done OTA (from a Mac) ?
    @akbooer
    The default sketch doesn't support OTA, as it wasn't available in the stable branch at the time of launch
  • @tbowmo Good sales but did not see the Sensebender too bad .
    @hek I've soldered a second unit to compare, same error, I flashed back the sensebender version from the examples and on both I am stuck here: "Sensebender Micro FW 1.2radio init fail"
    Gateway is 1.5 BTW, one radio is from itead the other not.
    1.6.5 version
    same behavior on two units
    not yet but why should that change anything ?
  • Just tried out my first Sensebender...
    soldered pins and battery power...
    turn on...
    led flashes once...
    start inclusion...
    3 devices...
    Vera restarts (actually, it's openLuup running on an Arduino Yún)...
    there they are...
    and updating every minute!
    Thanks so much to all who made this level of sophistication so easy!! (Z-wave was never this simple!)
    Whilst I need a couple of temp/humidity sensors, I also need to reflash one as a 4-switch sensor. Can I do this with an Arduino Uno configured with the ArduinoISP sketch as described here ?
    https://www.arduino.cc/en/Tutorial/ArduinoISP
    Any advice or useful pointers? Thanks.
    @epierre
    What do you use as supply voltage for the thing? What is the output from testmode?
    Did you add a capacitor on the radio module? How did you mount them together? (picture?)
    @akbooer
    Should be doable with an arduino as isp. Another option is to use the serial upload.
  • I am a noob in coding so I need some advice for tuning the sensebender.ino
    current observed problems:
    1. sensor values transmitted every minutes
    2. battery level info seems wrong
    I am running the default senseblender.ino.
    on 1) What I understood in this forum, it should transmit the temp. values only every 30min (or direct when change is >.05). However, I see them arriving in my controller (Domoticz) every minute. What should I change to have it send every 30min?
    on 2) I observe in Domoticz that the battery levels reported (in the Devices section) are inaccurate. For example: one sensebender with 3.2v measured power reports 80, where I would expect round 100 (this one has new batteries). Other sensebenders with still 2.63v report 53. How to calibrate the battery measurement?
    I have been searching this forum, but was unable to find the answer.
    Alternatively, a pointer to a wiki on sensebender.ino that has this explained would work as well.
    @jovo
    The firmware that the sensebender is shipped with is pretty old, compared to the one that's available in the current master branch of mysensors library. A lot have been done to do better transmit control (like, limiting number of transmits etc.)
    About the battery voltage, the sensebender is measuring against an internal vref, which isn't that accurate. I can't remember the specifics at the moment, but it's hidden somewhere in the datasheet. The measurement method has a lot of inaccuracy, but on the other hand it saves external components and power.
    I didn't focus on it, but one could perhaps make some kind of calibration routine, use a known supply voltage and do some internal calculations and store an offset in eeprom.
  • @jovo for battery mesurement it's correct 100% is for 3.3V and 0% for 1.9 V (BOD fuse setting). so for 2.63 you have 52,14 %
    @jovo As @Fabien wrote, the default code puts 3.3 V as 100%. Look for the percentage calculation. You will see that it's basically (vcc - 1900)/14. This makes sense if using a step-up converter where you get 3.3 V. But if connecting directly to two AAs, 100% should be around 3 V. So just replace 14 with 11 in the calculation.
  • Thanks for the comments and suggestion.
    Now I have installed the master branch code from the mys. library.
    Unfortunately no change. Still very frequent updates (under the same circumstances).
    I sense it has something to do with :
    bool tx = force;
    but I am not quite sure where to change it in.
    I will continue my search.....
    @jovo
    There is a small error in the sketch, that falsely converts floats to ints. Look at line 243, it's dividing by 100:
    float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100);
    This should be changed to 100.0 instead. This way the calculation is returning as a float.
    float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
  • @fabian how is the box working out were there any mods and are the stl files ready yet?
  • ok, it seems the aggregated upload is solved with the change from Thomas.
    Now I modify the "14" in "11" as suggested by martin. I have 105% now, but that could be right because I measure 3.1V from my 2 fresh AA's
    The only 'new issue' I discovered is that one sensor actually stops being received updates from due low power. The measured voltage on the batteries is still 2.1V and the battery indicator was at 23%.
    Could it be that I have bad fake radios that don't operate lower then 2.1V? (since there is no other external components added to my setup, I suspect only the radios).
    Sorry, my 3D printer is out of service, I'm waiting for chinese parts ... I will post correct STL files in 1 or 2 weeks.
  • I'm having trouble with the transmission times.
    // How many milli seconds between each measurement 900000 is 15 minutes
    #define MEASURE_INTERVAL 900000
    // How many milli seconds should we wait for OTA? 3000 is 3 seconds
    #define OTA_WAIT_PERIOD 3000
    I would expect a wake up and measure every 15 minutes. transmit if greater than .5 and go back to sleep
    also i would expect a forced transmission every 30 minutes.
    but that doesn't seem to be happening.
    here are my last few transmit times
    4:07pm
    5:59pm
    6:15pm
    6:47pm
    7:50pm
    8:34pm
    9:10pm
    I don't see a static 30 minute transmit.
    (from 4pm to 6pm?) i'm sure the temp and/or hum changed in 2 hours
    any suggestions on what may be wrong?
    default sketch (1.3 from git) but changed the measure intervals
    sensor lib 1.5
    thanks
  • @mvader If your interval between readings is 15 minutes and the force transmit interval is 30, your actual interval is 15minutes * 30 = 7.5hours. Also, see this thread for sleep time accuracy. 15 minutes of sleep can last 16-17 minutes...
    really.. hmm
    so if you look at the default comment
    when MEASURE_INTERVAL is 60000 and FORCE_TRANSMIT_INTERVAL is 30, we force a transmission every 30 minutes.
    That says measure for temp/hum every 1 minute - send if greater than .5 (defined later in the sketch)
    regardless of what goes on send stats every 30 minutes
    can you help me understand why those 2 number would be multiplied together? one shouldn't have anything to do with the other.
    i read that as they are definitions for 2 different process.
    but i may be totally misunderstanding.
    I do buy the sleep accuracy part of it though 🙂
  • @mvader No, it is not 30 minutes, the FORCE_TRANSMIT_INTERVAL counts the number of 'wakeup and take a reading' events, which in the original sketch is every 60 seconds. After 30 wakeup-and-read without a transmit, force a transmit. If you change your FORCE_TRANSMIT_INTERVAL to 2, it will transmit every 30 minutes if the readings do not change more than 0.5.
    The MEASURE_INTERVAL is based upon time (millis) and the FORCE_TRANSMIT_INTERVAL is based upon counting events (wakeup cycles).
    thanks for the clarification! 👍
  • @hek said:
    @gbfromhb
    I need 2 interrupts and would prefer using the external interrupts even though it might work with pin change interrupts. When looking through the forum I saw this answer from @hek but have not found any further reference to how this should be done in order not to disturb any radio functions. Anyone knows?
    I don't know if the radio actually drives the interrupt "output" pin on it's pinheader as default, or if you have to set it up when initializing the radio (@hek might have some input on this part :))
    If it drives the interrupt pin by default, then you need to either cut a trace on the sensebender, or cut / remove the pin in the pinheader on the radio module.
    I think it does actually.
  • @hek Is it needed for the radio to work or can I just cut it (seems odd to attach the radio to D2 if it is not really needed for anything).
    No, it isn't currently used by the MySensors library. It could be used to wake up the board when detecting radio transmissions...
    But keeping MCU sleeping and the radio listening still uses up batteries far too quickly so I guess it's still not an option.
  • @hek @tbowmo Thanks! Cut the radio IRQ pin and soldered a connection to D2. Tested to attach both interrupts and it works using a modified SenseBenderMicro sketch. "The Thing" will when ready be placed in my mailbox (which has mail-in and mail-out doors) and as a bonus report the outside temp, humidity and battery status. Does not solve any of this worlds biggest problems but it is fun 🙂
    one simple quick question, does this board can be used to create door sensors ? I do not need the temp/hum sensors, but I'm interested with the small footprint and the battery optimized board to make smallest door sensors (and some buttons).
    regards,
    @petoulachi
    Yes, it could be made into a door / window sensor.. (I'm planning on doing that myself).
    However, you need to build your own, if you don't want the temperature/humidity sensor on it.
  • @tbowmo
    Well can't I use this board without using the temp/hum sensor ?
    This board is quite small and allows to stack the radio module with minimum place. Also it works at 1Mhz, I guess it's a bit better than an Arduino Pro @ 3.3V ?
    Yes, you can use it without using the temp/hum sensor....
    I just assumed, that as you wouldn't make use of it, you would like to have it removed from the board as well..
  • Well I do, but I think that using a Arduino Pro 3.3V will be less effecient, but maybe I'm wrong ?
    I'm currently using temp/hum/motion sensors with Arduino Pro 5V, but they are not battery powered. Now I need to make very small sensor with battery, and I thought that maybe this sensebender board is my solution ?
    @petoulachi to make the pro mini as efficient as the SenseBender, you need to cut some traces on the board. There are forum topics for battery optimizing a pro mini. The SenseBender has these optimizations built in.
  • That's why I think i'm going to go with this senseboard.
    But I want to be sure that some connectors (D3 ?) support interrupts ? The goal is to have the sensor always in sleep mode, and wake up on interrupts only.
    Regards,
  • @petoulachi D3 can be used for interrupt, just tested it and it works.
  • I vote for one cheap Sensebender version without the temp/hum sensor on it. It will be the perfect door/window sensor.
    @nikos1671
    It has been up before, but back then it was decided that we don't save that much (2-3 $ or something like that). It might also be lower production quantities, which also keeps the price up..
  • @tbowmo just curious do you guys know how many of these you've sold?
    I've bought about 15+ 🙂
    @mvader
    Then you've bought almost 2% of them 🙂
    We're deeply grateful for yours and others support of the MySensors project.
  • Ordered 6 board too ! I'm glad to support MySensors project !
  • I've got 3 coming, can't wait to figure out what I'm going to use them for 🙂
    I'm deploying mine all over the house.
    in my attics, garage, shed. bedrooms. etc
    I've attached motion and lux sensors to several of them already.
    I tested / proof of concept adding IR transmitters. but these will likely need to be 5v nano's or something as battery power probably won't work with the IR and staying away waiting for messages from the controller.
  • Got 3 up just using the built in temp/humidity, making sure all looks ok. Will slowly add motion.
    Any suggested motion sensor for these guys?
    I'm using that HC501 PIR
    you can connect to the side pin and use 3v instead of the 5v
    @mvader Can you elaborate how you use 3V on the HC501 ? Which side pin ? Can you post an image ?
  • @GertSanders
    if you look at this image
    on the left side where it says "H" by the 3 pins with the jumper.
    i take off the jumper and connect 3v to the H pin
    works great.
    http://www.bdspeedytek.com/wp-content/uploads/1.1.jpg
    @mvader Thanks !
    My Sensebender node started June 10 is still going strong.
    @hek nice, what tool do you use for logging/graphing? Or is it exported and post-processed?
    @Anticimex
    Datamine for Vera. The actual data is stored to my NAS (mounted from vera).
    @hek cool. Can Vera do that now? Vera lite as well? Though the data miner plugin only could use USB mounts.
    Na, a little hack
    http://forum.micasaverde.com/index.php/topic,14910.0.html
    I've just received my sensebender boards and start playing with it.
    My first goal is to make a door sensor running on battery. I will not use the integrated temp/hum sensor for battery purpose, and use interrupt to have the sensor on sleep the majority of time.
    Looking at the sketch given with temp/hum, I have one question;
    on the loop function, we have
        highfreq = false;
    But I don't really understand this ; highfreq is initialized to true in the declaration, and never again. So, does this clock_prescale_set is call only once, meangin that the sensor will run at 1Mhz all the time ?
    It is the 5 first mesure that are running at normal speed, and then the sensor goes into a "battery efficient" mode ?
    Why waiting for 5 mesure to do so, and not doing it at startup ?
    Thanks for your explanation !
    It's waiting with switching to lower frequency, because it is dumping debug information to the serial port. And when you switch to 1Mhz, the baudrate is "screwed".
    When that's said, my opinion is that there is not much power to save, with switching to 1Mhz. This is because the MCU is sleeping most of the time, with the RC oscillator switched off. I am thinking that the freq. scaling should be removed in the comming releases
  • Oooh so I guess that also explain why I have strange output on the serial using the default sketch ?
    Well, I'll start without touching frequency and see how it behave in the next month. This is the sketch I use (not tested yet !). Sleeping all the time, awake but interrupt. When awake, send the Battery % if different from last mesure.
     * Version 1.0 - Henrik Ekblad
    #include "utility/SPIFlash.h"
    #include <EEPROM.h>
    #include <avr/power.h>
    #define RELEASE "1.0"
    // Child sensor ID's
    #define CHILD_ID_DOOR 1   // Id of the sensor child
    // Sensor messages
    MyMessage msgDoor(CHILD_ID_DOOR, V_TRIPPED);
    // Global settings
    int measureCount = 0;
    int sendBattery = 0;
    boolean highfreq = true;
    long lastBattery = -100;
    boolean oldDoorValue;
     * Setup code
      Serial.print(RELEASE);
      Serial.flush();
      gw.begin();
      Serial.flush();
      gw.sendSketchInfo("Battery Door", RELEASE);
      // sets the motion sensor digital pin as input
      pinMode(DIGITAL_INPUT_SENSOR, INPUT);
      // Activate internal pull-ups
      digitalWrite(DIGITAL_INPUT_SENSOR, HIGH);
      gw.present(CHILD_ID_DOOR, S_DOOR);
     *  Main loop function
      sendBattLevel(false);
      door(false);
      gw.sleep(INTERRUPT, CHANGE, 0);
    void door(bool force)
      sensor_node.sleep(5);
      bool tx = force;
      if (tripped != oldDoorValue)
        tx = true;
        oldDoorValue = tripped;
      if (tx)
         // Send in the new value
         gw.send(msgDoor.set(tripped ?  1 : 0));  // Send tripped value to gw
     * Parameters
      if (force) lastBattery = -1;
      long vcc = readVcc();
      if (vcc != lastBattery)
        lastBattery = vcc;
        // Calculate percentage
        long percent = vcc / 14.0;
        gw.sendBatteryLevel(percent);
    long readVcc() {
    BTW, what is the F() function ? instead of Serial.print("Sensebender Micro FW "); why using Serial.print(F("Sensebender Micro FW ")); ?
    Thanks !
  • Started to solder my 6 sensebender. I've noticed that if I set it to 1Mhz directly, the sensor cannot register itself on the gateway (but unfortunately I dont know why because there's no serial). Putting it at 8Mhz, being detected by the GW with an ID, and I can set it back to 1mhz. Weird.
  • Oh and BTW, which boxes are you using with your Sensebender ? I guess it's maybe the most difficult part of the entire project, finding the perfect box 😄
  • No, finding a box is the easiest part. This is the "box" for my outdoor temperature. 😆
    Wonder how well the hum-sensors work in that enclosure 🙂
  • Hmm, would Gore-Tex work? I will try find a Gore-Tex bag for the next version 🙂
    @Fabien @5546dug
    Hi, any news on this please? I would be good to get a box by Christmas.
    @petoulachi
    The sketch have improved a lot since we released the sensebender, mostly on determining when to power up the radio and transmit. This should save more power. I've got one running with latest development, without hiccups for the last couple of months (it also have Ota fw upgrade enabled by default now).
    So if you are "adventurous" I would recommend to put that into your sensebenders
  • I am adventurous !
    Were can I find the beta version of the sketch ?
  • Thanks !
    I took a look at the sketch, I didn't know there was a presentation() method to implement to present the different sensor's ID; is this new ? when is it called? I guess after setup() ?
    @petoulachi
    That's a part of the development. Things are re-arranged in the sketches, to make things more configurable (from within the sketch itself).
    It will be part of the next release (I don't know when that is happening)
  • Ok, related to MySensors 1.6 tehen, that explain why I never seen this !
  • HI, I'm about to experiment with a modded version of the sensebender and I while looking at the schematics of the original sensebender, I see that the crystal does not have any pf capasitors and not connected to GND. Why is that?
    All other schematics of atmega or any microprocessor I've seen has dual 22pf caps over the crystal and connected to ground.
    @Magnus-Pernemark
    The sensebender was designed to use a 32Khz oscillator for lowpower operation. According to the datasheet (page 33) it is not necessary to have external load capacitors if the crystals datasheet specifies cL below 6pF.
    However, we decided early on that an external crystal is not necessary in our application. So that is why it is not mounted, but the pads are still there, in case someone would use it.
  • @tbowmo Thanks! Yes. I read that it was not needed, but since it said "if you want higher precision" I though that, higher is good, and it would not hurt to place one there. But the crystals I have are 12.5pf so I guess I can't use them, but on the other hand I don't need to buy any other
  • Did someone "test" the humidity precision of the Si7021on the sensbender? Of corse the datasheet says max 3% off but how reliable is that?
    I have other sensors here and they differ by about 10%. So I did a "Salt-Calibration-Test" and there my two sensbenders or better Si7021 are 6% over the reference value. They report 81% and it should be 75%.
    Note: It's my first time that I performed this test and I'm not 100% sure that the (water-salt-ratio) is correct - thats why I'm interested if someone else tested the values?
    @nivoc
    Salt and electronics isn't a good combination, it will cause corrosion of the copper tracks..
    Just to warn you a little bit 🙂
  • @tbowmo Thanks. No worries the electronic won't touch the salt or water. The salt/water is just within the same closed container to bring the enclosed air to exactly 75.3% rel hum (at 25C).
    I followed this howto: But there are many other similar ones.
    http://www.kingofthehouse.com/hygrometer/
  • 163
