  3. How to send updated V_TEXT/S_INFO to controller?
domoticzvtextmysensors 2.0.0sinfo
8 Posts 3 Posters 4.8k Views 4 Watching
  • micahM
    micahM
    micah
    I'm working on an alarm clock... my controller is Domotiocz. I'm using a text sensor to send the alarm time to my arduino.... the following post helped me get it all working properly -> lcd-clock-and-text-sensor-node-with-new-v_text
    My clock also has buttons (like a traditional alarm clock), I've written all the code to change the alarm using the buttons.
    Now I want to send the new alarm time set on the arduino to the controller (Domoticz), and have the text sensor updated. I thought this would simply be a send(....) command, but I can't get it working.
    Here is a sub-set sample code of what I thought I needed to do to send the update (I'm on mysensors 2.0.*)
    #define MY_NODE_ID 9
    #define cID_ALARM_TIME 1
    MyMessage MySensors_MSG_Alarm1_Time(cID_ALARM_TIME, V_TEXT);
    	request(cID_ALARM_TIME, V_TEXT);
    void presentation()  {
    	sendSketchInfo("WakeUp Clock", "0.0.1");
    	present(cID_ALARM_TIME, S_INFO, "Alarm Time", true);
    	int newHour = 12;
    	int newMinute = 45;
    	String val = String(newHour) + "." + String(newMinute);
    	send(MySensors_MSG_Alarm1_Time.set(val), true);
    	if (message.type==V_TEXT) {
    		if (message.sensor == cID_ALARM_TIME){
    			// Here is where the return value comes from Domoticz when requesting the V_TEXT
    When I run it I get the following console message....
    35287 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=47,pt=1,l=1,sg=0,ft=0,st=OK:1
    35297 TSF:MSG:READ,0-0-9,s=1,c=1,t=47,pt=1,l=1,sg=0:1
    35302 TSF:MSG:ACK
    and then my controller (Domoticz) updates the text sensor to the value of 1
    I'm very confused, please help :)
      You should not use the String class in a Arduino environment (google why).
      The send function takes a char buffer. If you need to append/copy things into it, use strcpy or memcpy.
      http://www.cplusplus.com/reference/cstring/strcpy/
      mfalkviddM micahM 2 Replies Last reply
        @hek not strncpy? http://www.cplusplus.com/reference/cstring/strncpy/
          @mfalkvidd
          Sure, if you'd like some more control over things :)
            @mfalkvidd
            @hek otherwise you might end up in this thread https://forum.mysensors.org/topic/5212/why-ioyt-matters
            Edit: well not centrally bricked but owned and part of a botnet
              micahM
              micahM
              micah
              @hek
              Ok, I think I understand what you are saying, but I can't figure out the implementation.
              This didn't work
              char temp_Msg[3];
              strcpy (temp_Msg, char("1"));
              strcpy (temp_Msg, char("."));
              send(MySensors_MSG_Alarm1_Time.set(temp_Msg), true);
              or this
              char temp_Msg[3];
              strcpy (temp_Msg, "1");
              strcpy (temp_Msg, ".");
              or this
              char temp_Msg[3];
              strcpy (temp_Msg, '1');
              strcpy (temp_Msg, '.');
              But this does work (message is sent and loaded into Domoticz)
              send(MySensors_MSG_Alarm1_Time.set("1.1"), true);
              What am I not understanding?
                wrote on last edited by hek
                  char buf[20];
                  strcpy (buf,"Hello ");
                  strcat (buf,"world");
                  strcat (buf,"!");
                micahM 1 Reply Last reply
                    char buf[20];
                    strcat (buf,"!");
                  micahM
                  micahM
                  micah
                  @hek
                  Oh, I didn't know I needed to use both.
                  Well I tried a million combinations after seemingly reading everything on the subject, and I still couldn't get {int + char + int} converted into a char[] using strcpy and strcat
                  for some reason my brain is just not wrapping itself around the concept today... maybe I'll come back to it tomorrow.
                  In the mean time, I tried the following and it worked.
                  char buf[20];
                  sprintf(buf, "%d.%d", Alarm1_Time_Local[0], Alarm1_Time_Local[1]);
                  send(MySensors_MSG_Alarm1_Time.set(buf), true);
                  I've read that using sprintf increases the size of your sketch... but for now I'm fine with it, since it works and I can move on to being creative and productive.. lol
