  3. ATMega328p 8Mhz internal, standalone, mysensors low power problem
atmega328plow powerstand alonenrf24l01+
11 Posts 4 Posters 6.0k Views 3 Watching
  • T
    torfinn
    Hi ! I have started to upgrade mysensors ( 1.5 ) thats been working for a long time to version 2.1.1 but can't seem to get lowpower working.
    Tried most of the stuff out there like different bootloaders and changing NRF24 chips but I end up with 17mA during transmit and between 2,4 - 3,5mA in sleep mode.
    Tried using other low power libraries like http://www.gammon.com.au/power which works nice but is not compatible with mysensors because some parts are already implemented there I guess. With this library I get sleep mode like 20uA but then again can't get mysensors to work. What's the catch ?
    Anyone else have this problem and hopefully a solution for standalone ATMega 328p ?
    AWIA T 2 Replies Last reply
    • T torfinn
      AWIA
      AWIA
      AWI
      @torfinn I cannot reproduce this. Can you post your sketch?
      • AWIA AWI
        torfinn
        wrote on last edited by AWI
        @AWI
        Here is a minimal sketch I am testing with:
        #define DHT_DATA_PIN 8
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 60000;
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        DHT dht;
          sendSketchInfo("TemperatureAndHumidity", "2.2");
          present(CHILD_ID_HUM, S_HUM);
          dht.readSensor(true);
          sleep(10000);
        AWIA 1 Reply Last reply
        • T torfinn
          @AWI
          DHT dht;
            sleep(10000);
          AWIA
          AWIA
          AWI
          @torfinn nothing wrong with your sketch it should do the trick. Are you sure it worked with low consumption in v1.5?
          (p.s. I put the sketch in your post between code marks for better reading) 0_1490256228810_upload-e508ae50-3ab8-4f21-872d-31cd6ee9f282
            mortommy
            I have 4 sensors (temp/hum and contact switch) powered by 3V coin battery and with the library 1.5.4 they run for a year. I also decided to upgrade them to the library 2.1.1 and I got some issues. For example the binarysqwitchsleepsensor doesn't sleep. I also noticed that the initialization has many messages sending failure and that is a heavy blow for the battery, I went back to the 1.5.4.
            AWIA T 3 Replies Last reply
            • M mortommy
              AWIA
              AWIA
              AWI
              @mortommy that explains something. The 2.x version is more strict in guaranteeing communication is working. There are some tricks to get around it.
              • T
                torfinn
                Thank's for your feedback.
                Did you use the usual gw.sleep command on 1.5.4 or any other lowpower libraries ?
                • M mortommy
                  torfinn
                  Could it be board related ? I am using Arduino 1.8.1. I tried compiling with Ardino Pro / ATmega 328p 8Mhz as stock setup and now using both bootloader and setup from here: https://github.com/MCUdude/MiniCore/blob/master/README.md#boards-manager-installation
                  I was just thinking that maybe some of the command in the mysensors library are disabled if it detects another board setting ?
                  Also anyone know if the pin 2 / IRQ should be used ? Its not connected in my project could it be that mysensors is awakened by this ?
                  • T torfinn
                    torfinn
                    @torfinn RESOLVED:
                    Hi ! I had problem with properly registering on the gateway ( due to chips was used on old version earlier ). After finding this post I tried the https://www.mysensors.org/build/debug#clearing-eeprom and it fixed problem. Looking at 40uA sleeping now :-)
                    • M mortommy
                      torfinn
                      @mortommy Hi ! I decided to go with 2.1.1 on new sensors but still have the old 1.5.4 gw running. Had to change frequency to #define MY_RF24_CHANNEL 125 as the 2.1.1 sensors also registered partialy ( temp not humidity ) on the old 1.5 gw.
                      Also tried out #define MY_REPEATER_FEATURE Disabled this seems to do the opposite what i thought. Radio is never turned off ie. 17mA drain.
                      Added the following to try the lower the init etc. and it improves a little.
                      #define MY_REGISTRATION_FEATURE Disabled
                      #define MY_REGISTRATION_RETRIES 1
                      I think its a serious flaw that if the gw for any case locks up our sensors will drain the battery until it's back online again.
                      tekkaT 1 Reply Last reply
                      • T torfinn
                        tekkaT
                        tekkaT
                        tekka
                        @torfinn said in ATMega328p 8Mhz internal, standalone, mysensors low power problem:
                        This has no effect, the correct approach would be to comment this line:
                        https://github.com/mysensors/MySensors/blob/master/MyConfig.h#L146
