💬 Temperature Sensor
    @Dick this part
    2201 !MCO:SLP:REP
    of the initial log you posted says that the node cannot sleep because it is a repeater.
    This part of the sketch:
      sleep(conversionTime);
    explains that if the node is a repeater, the sleep call must be replaced by wait. If it is not replaced, the temperature sensors will not be ready when getTemp... is called, so the node will not send any values. Domoticz only lists sensors that have sent a value.
  • @mfalkvidd I chaned the Sleep into Wait but the same log in both Domoticz and on my Arduino. I thought it was an easy go but it appear not to be.
  • @Dick Did you change it at both places ( sleep(conversionTime);)?
  • @rejoe2 Yes on both location I replaced the sleep into a wait
  • @mfalkvidd In the Arduino log he Sleep error is not i anymore so that is solved but still no new device in Domoticz
    @Dick if you get the same log on the Arduino as before changing to wait, the sketch upload must have failed. Perhaps your Arduino is broken?
    Edit: Sorry, didn't see your last reply.
    What does the node log say now?
  • @mfalkvidd Ths is what the log says
    0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
    3 MCO:BGN:BFR
    6 TSM:INIT
    7 TSF:WUR:MS=0
    14 TSM:INIT:TSP OK
    16 TSF:SID:OK,ID=12
    18 TSM:FPAR
    59 TSF:MSG:SEND,12-12-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    1016 TSF:MSG:READ,0-0-12,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    1021 TSF:MSG:FPAR OK,ID=0,D=1
    1804 TSF:MSG:READ,20-20-12,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    1851 TSF:MSG:READ,4-4-12,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    2067 TSM:FPAR:OK
    2068 TSM:ID
    2069 TSM:ID:OK
    2071 TSM:UPL
    2075 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2087 TSF:MSG:READ,0-0-12,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2093 TSF:MSG:PONG RECV,HP=1
    2095 TSM:UPL:OK
    2097 TSM:READY:ID=12,PAR=0,DIS=1
    2102 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2111 TSF:MSG:READ,0-0-12,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2119 TSF:MSG:SEND,12-12-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    2128 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2144 TSF:MSG:READ,0-0-12,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2152 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
    2163 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
    2169 MCO:REG:REQ
    2173 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2183 TSF:MSG:READ,0-0-12,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2188 MCO:PIM:NODE REG=1
    2190 MCO:BGN:STP
    2192 MCO:BGN:INIT OK,TSP=1
    @Dick thanks. The node still doesn't send any values so that's why it does not show up in Domoticz.
    My next step would be to manually add serial debug prints at end of setup(), presentation(), and almost everywhere in loop(), to see why it doesn't attempt to send.
  • Very strange.
    I just mad the test and copied the code (out of your post above) to my IDE, compiled and uploaded: No problem, worked fine. Node gets registered by FHEM, sends ID once and Temp regularly as expected. For testing, I used just one DS18B20, but that shouldn't make any difference. (And MySensors lib version 2.2-beta, but that also shouldn't be an issue).
    Btw: what kind of a GW you are using?
    Recently, I came across a situation with a WiFi-GW that absolutely refused to accept new nodes. Using a serial one, everything was fine... Strange thing, too. (The GW itself was ok, there were several other nodes working without any communication problems. the new HW was also ok. Last, the channel was also correct, as all the existing nodes just switched over to the serial GW.... Reflashing that nasty thing also was no solution.)
  • I put some deug lines i it and after uploadig the sketch it stops here (wait conversationtime.)
    setup done.
    2191 MCO:BGN:INIT OK,TSP=1
    fetch sensors.
    fetch sensors.
    fetch sensors.
    fetch sensors.
    fetch sensors.
    fetch sensors.
    fetch sensors.
    @Dick could you try printing the value of numSensors in presentation()? (or in loop, it should have the same value there)
  • @mfalkvidd how can I manage that? sorr for the perhaps stupid qestion?
    @Dick
    Serial.print("Number of attached sensors found by the DallasTemperature library: ");
    Serial.println(numSensors);
  • @Dick best place would be after numSensors = ... in presentation()
    Just to mention that: The Arduino I used already had a node ID (I usually assign it manually). But your problem seems to be something completely different.
  • @mfalkvidd I tried it in Presentation() and in Loop() inboth no results in the log (copied it as you advised me how to do. so no result bisible). it is getting complex I think!
    6 TSM:INIT
    7 TSF:WUR:MS=0
    14 TSM:INIT:TSP OK
    16 TSF:SID:OK,ID=12
    17 TSM:FPAR
    452 TSF:MSG:READ,0-0-12,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    457 TSF:MSG:FPAR OK,ID=0,D=1
    561 TSF:MSG:READ,20-20-12,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    2066 TSM:FPAR:OK
    2067 TSM:ID
    2068 TSM:ID:OK
    2070 TSM:UPL
    2074 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2086 TSF:MSG:READ,0-0-12,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2092 TSF:MSG:PONG RECV,HP=1
    2094 TSM:UPL:OK
    2096 TSM:READY:ID=12,PAR=0,DIS=1
    2101 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2110 TSF:MSG:READ,0-0-12,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2118 TSF:MSG:SEND,12-12-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    2127 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2142 TSF:MSG:READ,0-0-12,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2151 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
    2161 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
    2168 MCO:REG:REQ
    2172 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2181 TSF:MSG:READ,0-0-12,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2186 MCO:PIM:NODE REG=1
    2189 MCO:BGN:STP
    setup done.
    2190 MCO:BGN:INIT OK,TSP=1
    fetch sensors.
    fetch sensors.
    fetch sensors.
  • How are your sensors wired? Parasitic or 3 wires?
    Sounds like a broken sensor, wrong wiring or a lot of sensors (to much for the pullup used).
    Ok. I give up. If the node isn't executing the serial prints I know no way of troubleshooting.
  • @mfalkvidd I ony can tell "thanksfo the support ad you time" . Have a nice wekend!!!
  • I have been frustrated with this for weeks now. Today I notice that void loop is not closed with a curly brace and if I add one it does not compile.
    So what black magic is going on here?
    I have been trying to get sensor readings every 2 mins and battery every half hour. But whatever I try it still gives temp every minute and battery at once a minute too. No wonder my batteries are draining so fast.
    @skywatch the curly braces were discussed and explained earlier in this thread.
    Could you post your sketch and the debug output of your node?
  • @mfalkvidd
    Thanks for fast reply! See code below. If you don't see problem there I will debug tomorrow. The battery time is set for 90sec to test, but is taking 18mins between sends!
    #define MY_RF24_PA_LEVEL (RF24_PA_LOW)
    #define MAX_ATTACHED_DS18B20 3
    #include <OneWire.h>
    int batteryPcnt = 0;
    unsigned long SLEEP_TIME = 117000; // Sleep time between reads (in milliseconds)
    int numSensors = 0;
    const long interval = 90000;
    unsigned long previousMillis = 0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0, V_TEMP);
    void before()
      sensors.begin();
      analogReference(INTERNAL);
      sendSketchInfo("HW/CH", "0.4");
      for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
        present(i, S_TEMP);
      // get the battery Voltage
      if (currentMillis - previousMillis >= interval) {
        batteryPcnt = sensorValue / 10;
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
    #if COMPARE_TEMP == 1
          send(msg.setSensor(i).set(temperature, 1));
          lastTemperature[i] = temperature;
      int8_t sleep(1, FALLING, SLEEP_TIME);
    @skywatch doing what you want is a bit hard since millis won't update while the node is in power save mode (sleeping). But this should do it:
    set SLEEP_TIME = 2 * 60 * 1000 // 2 minutes
    and change
    to
    unsigned int batteryReportFactor = 30*60*1000ul/SLEEP_TIME; // Only report battery every x SLEEP times (x=15 with current values)
    unsigned int timesSlept = 0;
      if (timesSlept < batteryReportFactor) {
        timesSlept++;
        timesSlept = 0;
    I don't understand why you're using interrupt to sleep though.
  • @mfalkvidd said in 💬 Temperature Sensor:
    Thank you very much for helping out with this! - I will try it today if I can. I guess I could use the same principle to send sensor data every 2 minutes instead of every 1 minute and further reduce battery draw. I know the DS18B20 sensors are correctly going into sleep mode, but the node itself is still using too much juice.
    There is nothing in the API about this, would be nice if it were added as I don't think I will be the only person with such requirements. Also, what does sleep actually do and are there further things I could do to reduce the power use?
    That is because I haven't finished this node yet.... I am working on it systematically and in future a water leak detector will be added. But only when this part is working correctly and I have good battery life from the node.
    @skywatch said in 💬 Temperature Sensor:
    Good point. I have added a note on https://www.mysensors.org/download/sensor_api_20#sleeping
    It does a lot of things, but basically it puts the radio and the Arduino in power save mode and uses the Arduino's watchdog timer to roughly keep track of time (exact timing is not possible because exact timing requires power, and power save mode is all about saving power).
    https://www.mysensors.org/build/battery has the official MySensors recommendations on how to save power in battery-operated nodes.
    If you want to dive deeper, start with https://www.gammon.com.au/power
    I'd use the sleep time to 2 minutes and then simply set a counter that every 15 loops of the code sends battery status and resets the counter. Imho 2 minutes are quite often for battery life.
    @gohan wasn't that what I did?
  • This can't be right, can it???
    (http://imagebucket.net/7mtp8rcnqss2/BattGraph.jpg)
    @mfalkvidd I'm on mobile, I didn't read the code 😇
    @skywatch it looks normal. The precision is probably 1% and the real value close to 100.5%, so sometimes it will be rounded to 101% and sometimes to 100%.
    @gohan hek has added a great feature that I use a lot on mobile. Click the code box once to maximize it. Super neat!
  • @mfalkvidd,
    Did you notice the time line on the bottom of the image. I thought it was supposed to send data once every 30 mins. Seems that something isn't right or I am looking at it from the wrong angle.....?
    @skywatch I'm not that versed in c/c++ arithmetic, but I suspect the calculation might overflow. Could you add a debug print to see the value of batteryReportFactor?
  • OK I'll do that - seems to be sending battery info every minute still though- strange!
    @skywatch could you post the entire sketch also, to check if something fishy has crept in?
  • Here is the sketch, debug will be later today I hope....
    unsigned long SLEEP_TIME = 2 * 60 * 1000; // 2 minutes Sleep time between reads.
    int numSensors = 0;
    bool metric = true;
    unsigned int batteryReportFactor = 30*60*1000/SLEEP_TIME; // Only report battery every x SLEEP times (x=15 with current values)
    void before()
      sensors.begin();
      sendSketchInfo("HW/CH", "0.5");
        present(i, S_TEMP);
        timesSlept++;
        timesSlept = 0;
    @skywatch code looks good to me. What type of Arduino are you using?
  • I am using a pro mini 3.3v 8MHz. I would ideally like to get a 1MHZ bootloader onto it but the last try stopped the temperature sensors sending data (although battery levels were still sent!)..... Hope it helps.
    @skywatch could you also print the return value of the sleep function. Maybe that interrupt is triggering it so it returns early?
  • Sorry for the dealy, I have had a week of plumbing problems at home - yuck! 😞
    So, I came back fresh to this and noticed that I had put the interrupt into the code ready for the water leak sensor (apt considering this weeks activities!) - BUT, I had not assigned the pin nor initialised it in the code. So maybe it was floating and giving random triggers?
    I tested by changing from int8_t sleep(1, FALLING, SLEEP_TIME); to int8_t sleep(SLEEP_TIME); but now I get battery level sent every single second! - This is making me crazy......
    The log for the gateway has the following.....
    Sep  3 07:00:37 HAAS rsyslogd-2007: action 'action 17' suspended, next retry is Sun Sep  3 07:02:07 2017 [try http://www.rsyslog.com/e/2007 ]
    Sep  3 06:26:28 HAAS rsyslogd0: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/0 ]
    Sep  3 06:26:28 HAAS rsyslogd-2359: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/2359 ]
    Not sure what the above is all about. Nor the below....
    7:15:45 HAAS dhcpcd[474]: eth0: Router Advertisement from fe80::3291:8fff:fe06:64bc
    But here is sending data every second.....
    Sep  3 12:46:52 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
    Sep  3 12:46:53 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
    Sep  3 12:46:54 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
    Sep  3 12:46:55 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
    Sep  3 12:46:56 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
    Sep  3 12:46:57 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
    Sep  3 12:46:58 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
    Sep  3 12:46:59 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
    Sep  3 12:47:00 HAAS mysgw: TSF:MSG:READ,5-5-0,s=255,c=3,t=0,pt=1,l=1,sg=0:75
    Will try debug on node next....
  • I.m sure it is a bug in 2.2.0-beta as I have the same issues with another node sending data whenever it changes and not sleeping.
    is there any known problem / bug with version 2.1.* and the Dallas temp sensor? (I found non in the bug tracker and/or forum)
    I updated several nodes from 1.5 to 2.1.1 and now no temp sensor is working. No temp sensor DS18B20 is found by the node, therefore -127.0 is returned to the controller. I checked the wiring - as illustrated in this manual, everything seems right; incl. the pull-up with 4,7 k. I use the modified version of the Dallas-Library included in the examples package, as stated out in this manual.
    Thomas
  • I am not a programmer, but trying to learn by making small projects.
    I am trying to build a arduino/ESP8266 with temp sensor so that at a particular set temp it sends a single to another arduino/ESP8266 with relay to turn on a cooler/heater. if there is a thread on this, please help me find it.
  • @Mohammed-Zaman This seems to be possible, you may find more info wrt your topic using "node to node communication" as a keyword for searching the forum.
    This might be a good starting point: https://forum.mysensors.org/topic/6386/almost-controller-less-mysensors-switch-light-network/8#
  • regarding error:
    C:\Users\Admin\Documents\Arduino\libraries\DallasTemperature/DallasTemperature.h:249:13: error: 'int16_t DallasTemperature::millisToWaitForConversion(uint8_t)' is private
    In the latest version of Miles Burton's the function is public and compiling fine.
    https://github.com/milesburton/Arduino-Temperature-Control-Library
    You can import the Lib as zip.
    You have to remove \ archive the lib: ...\libraries\DallasTemperature
    @sjoerd14 yes, thanks to MySensors user David Ducatel. The change is tracked in https://github.com/mysensors/MySensorsArduinoExamples/issues/20 and https://github.com/milesburton/Arduino-Temperature-Control-Library/pull/72 but we're still waiting for an official release of milesburton's library.
  • Hi, I have few in wall nodes mounted under the light switches. I have two relays and one DS18B20 in each node. When i'm turning light on, switching the relay, the DS18B20 readings jumping about 0.8 degrees celsius up. When I switch off the relay readings back to normal. Anyone have similar problems ? Sensors are away from from node board, relays etc. so it's not about the heat from atmega or relays.
    Is the temperature gradually rising after the relay is activated or it is instantly jumping 0.8°?
  • Jumping 0.8 immediately after switching the relay and sometimes rising very slow during the time when relay is on.
    That makes it quite difficult to figure out the problem. Can you make another node with same setup and see if you get the same results and if you do try unplug the relay and see what happens
  • It's probably a voltage drop from the psu when the relay is engaged and drawing current. That will cause the output voltage to dip slightly.
    If it is only momentary you can add a beefy capacitor across the power supply, but if the readings change for the whole time the relay is on, you really need to replace the relay with something that uses less power (triac/mosfet??) - Or get a more stable power supply with good regulation.
    A final thing might be more noise on the power line with the psu sending more current with the relay on. again a smoothing capacitor would help if this were the case.
    You could also try looking into the wiring and see if the relay cables and the ds18b20 cables are far enough apart, some induction might be going on there between the cables. Also, make sure everything goes back to a single ground point. I can't imagine how an earth loop would cause what you describe, but it's always a good thing to do.....
    Another thought to think about is matbe the magnetic field from the relap power cables are inducing into the sensor cables.
  • Hi
    Can we talk about redundancy please? What if one or more sensor fail on a one-wire bus? Would it make the whole line unusable?
    As part of a central heating MySensorization i would like to have groups of 3 sensors and have some sort of redundancy check.
    Would i be allowed to run multiple one-wire busses on a single arduino?
    Thanks a lot foryour help
    @ben999 you can have as many onewire buses as you have digital pins. Just add more of these:
  • @mfalkvidd thanks a lot. Yes, that looks good to me. I will have a go.
    The real big question now is about what happens when one or more sensor fails on the line.
    I am not talking about removing a sensor, which doesn't produce any fault.
    My concern is how does a DS18 ends its life under normal operation? Complete shortcut?
    @ben999 I don't think there are any guarantees on how it will fail. If there are, the datasheet should list them.
  • @ben999 I cannot remember WHERE I read it, but if a DS18B20 fails it will either send impossible results when addressed or fail to be addressed at all as it is digitally addressed. Only cable short circuits can pull the entire chain down, as I found out when two socket pins had crossed over (sensor crimped into telephone plugs).
  • @mfalkvidd thank you for the idea. Had a look (boooooring reading for me 😄 ) but no mention to failiure
    @zboblamont you're right. Seems that a faulty sensor return "85" (top of my head). And a "dead" sensor looses its bus address (next sensor on the chain takes its address and so on)
    Thanks a lot gentlemen 🙂
  • @ben999 said in 💬 Temperature Sensor:
    That's not exactly right. Each of the 1-wire devices uses a hardcoded, unique address that can not be changed.
    So if you use the standard sketch with multiple DS18B20, in case of detached or replaced sensors you may get reported the measured temperatures comming from the same physical DS18B20 device under a different ChildID (after node reboot). To avoid effects like that, one has to take additional measures as described here . In short:
    • Use an array with the physical ID's to address them
    • Store a hash-array (done automatically) to identify "known" physical ID's that have once been attached to the bus as well as the ChildID used for MySensors.
  • @rejoe2 oooooooooh great! thanks a lot, exactly what i was looking for !!!
  • @ben999 You are welcome 😀
  • When I try to compile the sketch for an ESP8266 I get an error in DallasTemperature.h which results in an error in OneWire.h
    OneWire.h:108:2: error: #error "Please define I/O register types here"  #error "Please define I/O register types here"
    Is it possible to make the sensor run on an ESP?
  • Hi, I'm having a hard time getting this Temperatursensor to work with Home Assistant. When i start it it doesn't register with the HA. If I use the same hardware and switch out the sensor to a DHT sensor (new sketch of course) then it works out of the box, HA sees the sensor. I've tried changing the Dallas DS18B20, but nothing. If i look at the logs the gateway have no problem with the sensor. Is there something in the code for the sensor that doesn't add up to it being presented to HA in the right way? I'm quite the newbie when it comes to programming.
    Have you tried another controller like mycontroller?
  • @gohan No I have not. I have a RF-Link also connected to the HA and it's working great. As I said, if I use the same hardware that I used to control the Dallas sensor and change the sensor to a DHT sensor the DHT sensor is accepted by HA and shows up as a sensor. That's why I was asking if there is something in the code for the Temperature sensor sketch that has to be changed to be able to present it to HA.
    pls post the code that is not working
  • @gohan Thanks for the quick reply! Well I've use the standard sketch for this Temperatur sensor. This is the code i've got.
    int numSensors=0;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
         present(i, S_TEMP);
      sleep(SLEEP_TIME);
  • Anybody has sketch for sensors dallas DS18b20 with identify it with ID Dallas ?
    And i can change value 16 to more sensors ? Example 20 ?
  • Looking at code example it seems to be sufficient to set bool metric = false to get readings in Fahrenheit, but node still returns readings in C. Any idea why?
    @apl2017 if I'm looking at the same sketch as you are looking at, the metric variable is never used. getControllerConfig() is used to fetch the controller's metric setting instead.
  • @Rene046
    Hi guys
    Hi
    can you advice how to manage Domoticz to display 2 decimals under Temperature sensors page, when following line MsgTemp.set(temperature,2) I can see on arduino serial monitor, mysensors sent 20.75 value, the same value i can see under child item with Hardware tab but not on sensor where 20.75*C is rounded to 20.8. its fine for general log but i want to have stable temperature for heating system. I have added code to count average from last X records like 20 or 40 with 0.25 steps, this stabilize Heating system and protect it against on/off to frequently.
    Additionally when i use JSON it will present proper value under sensor page, same with ESPEasy and 2 decimal configuration on ESP.
    do you know how i can changed domoticz to force him to present 2 decimals?
    Mysensors 2.3.1/2.3.2
    Domoticz 4.10717
    raspberry pi
    Thank you
    Jakub
  • Domoticz globally or only with MySensors ?
    My Domoticz is the same version like yours.
    Temperatures from ESPeasy are with two decimals on Temperature sensors page, but on devices page only one decimal.
    Exactly the opposite like you wrote.
  • @kimot
    Hi
    Thank you for feedback.
    I have this issue only with mysensors. it's exactly like you wrote. Hardware tab, present 2 decimals ( for mysensors and espeasy). Device tab, present 1 decimal ( for all sensors), Temperature tab shows 2 decimal for esp easy and JSON updates but 1 decimal for mysensor. Not sure why.
    Temporary I managed to workaround by using script taking data from Hardware page - child and sending JSON update all started by crone updating dummy sensor.
    like this:
    TEMP=`curl -s "http://X.X.X.X:XX/json.htm?type=command&param=mysensorsgetchilds&idx=40&nodeid=0"| awk 'NR>1{print $5}'| sed 's/"//g;s/^.//;s/)//g; s/,//g;/^$/d;s/]//g;' | sed -n '3,2p'`
    IDX=255
    curl -s "http://X.X.X.X:XX/json.htm?type=command&param=udevice&idx=$IDX&nvalue=0&svalue=$TEMP"
    but for sure this can be workaround by dzVents and JSON handling results but i'm not skilled enough for that 🙂
    Thank you
    Jakub
  • The note before the example sketch states that you should use the "modified" library from MySensors examples.
    But as of today, with MySensors 2.3.2 and Arduino 1.8.15 I used the standard DallasTemperature library (provided by the Arduino's Libraries manger) with no problems at all.
    Using the "standard" Arduino libraries is a grate advantage, so I the custom library is no more used, it could be useful to update the guidelines in the page.
    Stefano
  • 584
  • 110
