  3. RFM69 sleep mode
RFM69 sleep mode
25 Posts 9 Posters 17.9k Views 7 Watching
  • FrancoisF
    FrancoisF
    Francois
    Hi how do I put the RFM69 in sleep mode? I currently getting 4mA current draw for BinarySwitchSleepSensor. On the NRF24 for the same sketch, I get 3uA.
      If you use the MySensors sleep function it calls
      https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/utility/RFM69.cpp#L152
      I hope the RF69 library sleep function works...
      What is the expected consumption?
      • FrancoisF
        FrancoisF
        Francois
        @hek as per this Web site I should get about 16uA http://forum.anarduino.com/posts/list/39.page
          Cant help you much right now as I don't have my RF69 setup up and running.
          Maybe Felix over at lowpowerlab can give you some hints (we use his code for the driver).
          • FrancoisF
            FrancoisF
            Francois
            @hek to get down to 3uA I have to use the following line.
            LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
            How do I do this in the current library. If I use the LowPower library I get an error when compile
              Tried gw.sleep(8000); ?
              • FrancoisF
                FrancoisF
                Francois
                @hek with sleep(8000) I still get 3.75mA.
                  Strange that you get different values depending on radio. That points to problem with radio sleep and not the Arduino itself.
                  So if create a RF69 sketch that just sleeps in loop. What happens if you disconnect radio (after init)? Do you you get ~3.75uA?
                  • FrancoisF
                    FrancoisF
                    Francois
                    @hek sorry how will I disconnect the radio?
                      Ahh.. good question if (you're running Moteino with them soldered on).
                      • FrancoisF
                        FrancoisF
                        Francois
                        @hek yes the radio is solder on
                          wrote on last edited by hek
                          I can't find myself doing anything different from the LowPower library in in MyAtMega328.cpp - sleep(). Need someone else's eyes on it.
                          • FrancoisF
                            FrancoisF
                            Francois
                            @hek I see that you have powerDown in the MyHwATMega328.cpp how do I use that function?
                            void powerDown(period_t period) {
                            	ADCSRA &= ~(1 << ADEN);
                            	if (period != SLEEP_FOREVER)
                            		wdt_enable(period);
                            		WDTCSR |= (1 << WDIE);
                            	#if defined __AVR_ATmega328P__
                            		do {
                            			set_sleep_mode(SLEEP_MODE_PWR_DOWN);
                            			cli();
                            			sleep_enable();
                            			sleep_bod_disable();
                            			sei();
                            			sleep_cpu();
                            			sleep_disable();
                            			sei();
                            		} while (0);
                            	#else
                            		do {
                            			cli();
                            			sleep_enable();
                            			sei();
                            			sleep_cpu();
                            			sleep_disable();
                            			sei();
                            		} while (0);
                            	ADCSRA |= (1 << ADEN);
                              You use it by calling gw.sleep() which initiates powerDown.
                              https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MySensor.cpp#L820
                              • FrancoisF
                                FrancoisF
                                Francois
                                @hek Hi I got a new shipment of Arduino mini pro and after I did the low power hack on this Arduino I now are getting 30uA current usage. Thank again for all you support and for this great MySensor community that you started :). Now I can go full steam ahead in building more sensor for my house.
                                NeverDieN 1 Reply Last reply
                                • FrancoisF Francois
                                  NeverDieN
                                  NeverDieN
                                  So, just to be clear, is this an accurate summary: the full package (Arduino mni pro plus radio) sleeps at 30uA if using the RFW69 but sleeps at 3uA if using the NRF24L01+?
                                  Also, does it make any difference whether it's RFM69W, RFM69CW, or RFM69HW? Do they all draw the same amount of current while sleeping?
                                  P 1 Reply Last reply
                                  • NeverDieN NeverDie
                                    P
                                    P
                                    peres
                                    @NeverDie
                                    Hi, I know this is an old thread, but it is stil a valid subject to me.
                                    I have had success with arduino pro mini v2 and RFM69W in sleep, but not the high power version RFM69HW.
                                    Arduino+RFM69W sleeps at 5.2micro Amp.
                                    Arduino+RFM69HW sleeps at 420micro Amp.
                                    I have written about it in arduino forum.
                                    I would be glad if someone has a solution for this.
                                    M 1 Reply Last reply
                                    • P peres
                                      @NeverDie
                                      manutremo
                                      wrote on last edited by manutremo
                                      Hi @peres,
                                      My RFM69HW current during sleep is less than 1 uA aprox, which is consistent with what is shown in the datasheet. Interestingly, this is the result when powering the device with a battery; when powering the device from the PC USB serial, it's around 6 uA - still close enough as it's measured with a "normal" multimeter.
                                      I'Which version of mysensors are you using? I've moved to 2.2.0-beta (due to me needing other functionalities not availabel in 2.1.1, namely ATC which btw works fabulously) and found that support for nrf69 is - although not yet 100% completed - significantly improved. Maybe worth a try to see if that fixes your sleep consumption?
                                      Remember adding
                                      #define MY_RFM69_NEW_DRIVER
                                      to enable the new driver.
                                      Let us know how it goes :)
                                      • N
                                        N
                                        napo7
                                        I have the same question, but a little bit different ;)
                                        I use a RFM69 with the Mysensors 2.2.0 beta.
                                        I don't sleep my node with the provided function, since I don't want to sleep for some time, but until a Pin Change Interrupt is triggered (via pin A0 or A1). So, I can't use the sleep() function.
                                        I do put my node to sleep with avr core functions (setting registers, calling power_all_disable() and sleep_cpu()...) but I suppose the radio is never put on sleep !
                                        Is there a function I can call to sleep the radio, and if yes, is there another function I should call before sending, to awake the radio ?
                                        Thanks !
                                        • scalzS
                                          scalzS
                                          wrote on last edited by scalz
                                          @napo7
                                          Here the list of the core functions (radio independant):
                                          https://ci.mysensors.org/job/Verifiers/job/MySensors/branch/development/Doxygen_HTML/group__MyTransportgrp.html#gab39d3b81f005e00117269d79c7b2ee4c
                                          should be transportDisable/transportReInitialise
                                          Else the radio specific functions (a layer above driver) are in the MyTransportRFM69.cpp
