  3. 💬 Wirsbo/uponor thermostat
temperaturefloor heatinguponorthermostatmysensorswirsbo
8 Posts 6 Posters 7.0k Views 7 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/302/Wirsbouponor-thermostat
    • korttomaK
      korttomaK
      korttoma
      Hi @Denke ,
      Would you mind giving more details about witch Uponor thermostat this is an what central unit is required for this setup? You do use the original central unit and just replaced the thermostats right?
      I have a Uponor C-33 and a C-35 to control my underfloor heating from Uponor T-37 thermostats. These thermostats only use 2 wires from the controller from where it gets power and somehow controls if the valve should be on or off.
      Could you share the schematics for your device?
      Do you think your design could be used in my system as well?
      Regards,
      Tomas
      • Tomas
      • D
        D
        Denke
        Hi Tomas
        I have only replaced the thermostats not anything else in the system.
        This thermostat is a replacement of my Cosy thermostat (art no 804661), but i think it should work also for the following article numbers (80466, 80465, 804651 and 80464). This thermostat only works as a on/off for the valve, I did not spend any time on the night temp function. I have connected the thermostat to a transformer unit (art no 80460) which in principle only converts 220 v to 24 V which is then connected to the thermostat. When the thermostat turns on it passes on the ~24 V signal to the valve.
        I will upload a schematic to the project
        RaspberryPi-Openhab
        • dexterbotD
          dexterbotD
          dexterbot
          Hello Denke,
          Can you share Openhab integration codes for this thermostat ?
          Thank you
          D 1 Reply Last reply
          • dexterbotD dexterbot
            Hello Denke,
            Thank you
            D
            D
            Denke
            HI @dexterbot
            Here is the code for the openhab
            Items
            /* Thermostats /
            Hall */
            Number Hallway_Temperature "Temperature [%.1f]" <temperature> (Temperature, C_Hallway, gMS) { channel="mysensors:hvacThermostat:gateway:Hallway_Temperature:temp" }
            Number Hallway_SetPoint "HVAC/Heater set point " <temperature> (gMS) { channel="mysensors:hvacThermostat:gateway:Hallway_SetPoint:hvac-setPoint-heat" }
            String Hallway_FlowState "Mode of heater [%s]" <heating> (gMS) { channel="mysensors:hvacThermostat:gateway:Hallway_FlowState:hvac-flow-state" }
            Number Hallway_KnobTempVar1 "Knob temperature [%.1f]" <temperature> (gMS) { channel="mysensors:hvacThermostat:gateway:Hallway_KnobTempVar1:var1" }
            String Hallway_FlowMode "Running mode" <heating> (gMS) { channel="mysensors:hvacThermostat:gateway:Hallway_FlowMode:hvac-flow-mode" }
            Number Hallway_HystLowVar3 "hyst low [%.1f]" <temperature> (gMS) { channel="mysensors:hvacThermostat:gateway:Hallway_HystLowVar3:var3" }
            Number Hallway_HystHighVar4 "hyst high [%.1f]" <temperature> (gMS) { channel="mysensors:hvacThermostat:gateway:Hallway_HystHighVar4:var4" }
            Number Hallway_UpdateTimeVar5 "update time (s) [%d s]" <clock> (gMS) { channel="mysensors:hvacThermostat:gateway:Hallway_UpdateTimeVar5:var5" }
            Things
            Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyUSB0", sendDelay=200, baudRate=115200, skipStartupCheck=true ] {
            /** define things connected to that bridge here */
            hvacThermostat Hallway_Temperature [nodeId="59", childId="0"]
            hvacThermostat Hallway_SetPoint [nodeId="59", childId="0"]
            hvacThermostat Hallway_FlowState [nodeId="59", childId="0"]
            hvacThermostat Hallway_KnobTempVar1 [nodeId="59", childId="0"]
            hvacThermostat Hallway_FlowMode [nodeId="59", childId="0"]
            hvacThermostat Hallway_HystLowVar3 [nodeId="59", childId="0"]
            hvacThermostat Hallway_HystHighVar4 [nodeId="59", childId="0"]
            hvacThermostat Hallway_UpdateTimeVar5 [nodeId="59", childId="0"]
            sitemap
            Group label="Thermostats" icon="heating"{
            Frame label="Hall"{
            Text item=Hallway_Temperature
            Text item=Hallway_FlowState label="State [%s]"
            Setpoint item=Hallway_SetPoint label="Set point [%.1f]" icon="temperature" minValue="0.0" maxValue="32.0" step="0.1"
            Text item=Hallway_KnobTempVar1 label="Knob temperature" //Knob temperature
            Text item=Hallway_FlowMode //Running mode
            Setpoint item=Hallway_HystLowVar3 label="Hysteresis L [%.1f]" minValue="0.0" maxValue="5.0" step="0.1"
            Setpoint item=Hallway_HystHighVar4 label="Hysteresis H [%.1f]" minValue="0.0" maxValue="5.0" step="0.1"
            Setpoint item=Hallway_UpdateTimeVar5 label="Update time (s) [%d]" minValue="1" maxValue="4096" step="1"
            RaspberryPi-Openhab
            • H
              H
              hepal
              Hi Denke
              On which hardware does your openhab run on, and how does it communicate whith the thermostates.
              I my self has openhab running on a Rapberry Pi 3, and can't figure out which additional hardware I need to add to my Raspberry, to make it communicate with the thermostates
              Regards
              Henrik
              • H hepal
                Hi Denke
                Regards
                Henrik
                D
                D
                Denke
                @hepal
                Hi The thermostats use mysensors serial gateway to communicate with the openhab that runs on a raspberry Pi 2. I run openhab 2.0 but in the beginning i was running 1.7.x
                RaspberryPi-Openhab
                • R
                  R
                  roberts1
                  I am non technical but I have 8 wirsbo stats in my house. One of them is faulty and the unit is now obsolete. Is it possible to purchase one of these pcbs and use it to replace the one in the faulty stat ?
                  Richard
