💬 MyPulse Sensor
Nice work! Can you please upload the STL file as well?
just received and assembled this tiny pcb
So i've updated projects files (git and here) with some pics, and stl. STL are wip but as you can see it perfectly fits.
The electronics work perfect in the TH version but it seems like the enclosure is too small for it to fit.
I needed to carve a bit both on the bottom and lid to be able to mount them together
oki.
i'll improve this when i'll get a bit more time, that's quick to do. I've assembled smd version only so far.
thx for feedback
Hi. Thank you for sharing your board. It seems awesome. I got a question. When I read the BOM, I think I should use 100 ohm, 330 ohm and 1500 ohm resistor. When I look at the schematic picture it says 100k 330k. What resistor should I use?
@scalz
I guess you have the answer to that question?
How long a cable can one have between the uC and a sensor?
Hardware • 14 Dec 2014, 16:53 • Zeph 16 Dec 2014, 02:33 -
Figaro TGS5042 Carbon Monoxide Sensor & Op Amp
Hardware • 30 Apr 2016, 11:01 • Samuel235 12 Sept 2017, 15:55 -
Garage door status sensors ideas
General Discussion • 3 Jan 2018, 03:18 • McQueen 8 Jan 2018, 17:18 -
💬 Multi-purpose sensor
OpenHardware.io • 6 Feb 2018, 20:06 • openhardware.io 3 Mar 2018, 17:03 -
💬 Arduino Pro Mini Shield for RFM69(H)W
OpenHardware.io • 2 Nov 2016, 18:10 • openhardware.io 24 Mar 2018, 11:45 -
Perimeter wire with sensors for robotic mower
Hardware • 22 Sept 2014, 19:40 • grint 23 Sept 2014, 19:35 -
Temperature Sensor Configuration
General Discussion • 22 Jan 2015, 00:08 • rdevine 22 Jan 2015, 15:30
