  3. Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +)
atmega328parduino pro miniraspberry serial gatewayhome assistantnrf24l01
21 Posts 4 Posters 7.9k Views 2 Watching
  • A
    A
    alop
    wrote on last edited by alop
    I have difficulties about following setup:
    I have a controller home assisitant.
    It runs on raspbery pi 3.
    On the same I have a serial gateway MySensors (just attached NRF24L01 (without plus!) on it.
    I have an (atmega328p) like arduino pro mini as node with a motion sensor attached.
    I'm trying to "connect" the node to the gateway but without success.
    Btw I have tested other different gettingstarted scripts with this radios and they are working fine.
    Here is the output of the gateway:
    pi@RP3HA:~/MySensors $ sudo ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.0-beta
    mysgw: MCO:BGN:INIT GW,CP=RNNG----,VER=2.2.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    Here is the serial output of the node:
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:FPAR
    1611 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    3619 !TSM:FPAR:NO REPLY
    3621 TSM:FPAR
    5221 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    7229 !TSM:FPAR:NO REPLY
    7231 TSM:FPAR
    On Raspberry only change that I have done is in MyConfig.h
    #define MY_RF24_DATARATE				RF24_2MBPS
    Here is the code on the node:
     * Version 1.0 - Henrik Ekblad
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    // Enable debug prints
    #include <MyConfig.h>
    #define MY_RF24_CE_PIN 6
    #define MY_RF24_CS_PIN 10
    //unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    #define CHILD_ID 11   // Id of the sensor child
    // Initialize motion message
      Serial.begin(115200);
      Serial.println(F("Setup"));
      sendSketchInfo("Motion Sensor", "1.0");
      present(CHILD_ID, S_MOTION);
      Serial.println(F("Presentation"));
      Serial.println(F("loop"));
      // Read digital motion value
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
      Serial.println(tripped);
      send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
    //  sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
    I want to see some serial print, but there is nothing comming ever with this code.
    On getting started, I receive the serial print.
    • A alop
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      13 TSM:FPAR
      3621 TSM:FPAR
      7231 TSM:FPAR
      @alop all MySensors defines need to be before including MySensors.h.
      Move them and upload the sketch again should be all you need.
      • A
        A
        alop
        Unfortunatelly not.
        Same result
        3 TSM:INIT
        4 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        13 TSF:SID:OK,ID=1
        14 TSM:FPAR
        1613 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        3621 !TSM:FPAR:NO REPLY
        3623 TSM:FPAR
        5223 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        7230 !TSM:FPAR:NO REPLY
        7232 TSM:FPAR
        8832 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        10839 !TSM:FPAR:NO REPLY
        And here is the code:
        • A alop
          Unfortunatelly not.
          Same result
          3 TSM:INIT
          4 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          13 TSF:SID:OK,ID=1
          14 TSM:FPAR
          3623 TSM:FPAR
          7232 TSM:FPAR
          @alop said in Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +):
          !TSM:FPAR:NO REPLY
          This means "no potential parents replied to find parent request" so pretty much the node and the gw doesnt talk to each other. Why? Well, it looks like the radios is initialized if im right but either its a range issue (to long between, or sometimes even to close so they over-shout eachother) and it could be a power issue. The most important thing is that you have capacitors on the radio.
          How do you power the radios?
          A 1 Reply Last reply
          • sundberg84S sundberg84
            !TSM:FPAR:NO REPLY
            A
            A
            alop
            @sundberg84
            I dont have capacitors on radios.
            The distance between radios is 20-30 cm.
            Raspberry radio is powered from raspberry.
            On Arduino i have additional power supply 5v for the motion sensor.
            Arduino is powered through USB.
            Am I assuming right, that on raspberry when there is no configure parameter for something, I just change it in MyConfig.h and "make" again?
            I had the same hardware setup tested with gettingstarted and the communication was established.
            • A alop
              @sundberg84
              @alop you'll have a hard time getting help from anyone until you have capacitors on the radios. Power issues are the top 1, 2, 3, 4 and 5 issues if you look at the problems people are having. Yes, sometimes it works with a very simple example. No that does not mean that your power is stable enough.
              https://www.mysensors.org/build/raspberry#advanced shows how to set defines if you don't want to modify MyConfig.h, but modifying MyConfig.h also works. I prefer the -D variant because then I can easily switch MySensors versions in git without having to re-apply the changes.
                A
                A
                alop
                @mfalkvidd OK. I just bought some 4.7 capacitors :)
                I'll make the setup with them.
                @mfalkvidd said in Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +):
                Just to clerify, if I change MyConfig.h on raspberry it is not enough just to save the file and "build" the gateway with other parameters?
                Maybe this is why I dont receive any signal.
                • A alop
                  @alop geat.
                  Until you have the capacitors in place, see if sundberg's advice on moving the nodes apart helps, about 2-3 meters. The signal can become too strong.
                    @alop geat.
                    A
                    A
                    alop
                    @mfalkvidd
                    Just in general: What is the procedure if I change the MyConfig.h on raspberry?
                    • A alop
                      @mfalkvidd
                      @alop edit it with your favorite editor?
                        A
                        A
                        alop
                        @mfalkvidd Ok, so far :)
                        But do I need to "compile", "build", "make" something so that changes in MyConfig.h will be taken?
                        • A alop
                          @alop ok :)
                          I think make is sufficient (and make install if you want the new binary installed).
                          make is smart enough to recompile everything that has been modified.
                            @alop ok :)
                            A
                            A
                            alop
                            @mfalkvidd
                            Unfortunatelly no change after adding capacitor :(
                            Now I have bought NRF24L01 WITH Plus and I'm trying with them.
                            I have reinstalled from skratch everything.
                            Gateway and sensor are now ca. 3-4 meters appart.
                            Sketch on atmega328p (light sensor)
                             * Version 1.0 - Henrik EKblad
                             * Example sketch showing how to measue light level using a LM393 photo-resistor
                             * http://www.mysensors.org/build/light
                            #define CHILD_ID_LIGHT 15
                            #define LIGHT_SENSOR_ANALOG_PIN 0
                            int lastLightLevel;
                                sendSketchInfo("Light Sensor", "1.0");
                                int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                                Serial.println(lightLevel);
                                    send(msg.set(lightLevel));
                                    lastLightLevel = lightLevel;
                                sleep(SLEEP_TIME);
                            On raspberry
                            ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                            Serial on the sensor
                            114445 !TSM:FPAR:NO REPLY
                            114447 TSM:FPAR
                            114449 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            116457 !TSM:FPAR:FAIL
                            116459 TSM:FAIL:CNT=7
                            116461 TSM:FAIL:DIS
                            116463 TSF:TDI:TSL
                            176465 TSM:FAIL:RE-INIT
                            176467 TSM:INIT
                            176475 TSM:INIT:TSP OK
                            176477 TSM:FPAR
                            176479 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            178487 !TSM:FPAR:NO REPLY
                            178489 TSM:FPAR
                            178491 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            180499 !TSM:FPAR:NO REPLY
                            180501 TSM:FPAR
                            180503 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            182511 !TSM:FPAR:NO REPLY
                            182513 TSM:FPAR
                            182515 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            on raspberry
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: MCO:BGN:STP
                            And on my home automation (home assistant)
                            2017-07-22 13:00:19 ERROR (Thread-13) [mysensors.gateway_serial] Unable to connect to /dev/ttyUSB020
                            Update:
                            After 15-20 minutes running the gateway I received following lines:
                            mysgw: TSF:SAN:OK
                            mysgw: TSM:READY:NWD REQ
                            mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                            • A
                              A
                              alop
                              It's a workaroud, but not "nice".
                              Since I have no problem on creating gateway on another arduino pro mini, I just connected per USB the arduino to RP3 and everything is working fine.
                              So sensors can be read by a controller (home assistant).
                              Big downside is, that for pro mini I have to use usb to ttl convertor in between.
                              Maybe the code for raspberry is with bugs, since to be able to see my rf radio on raspberry I had to install the "development" branch.
                                the development branch works well, why don't you use it on the RPI?
                                  A
                                  A
                                  alop
                                  @gohan As described above, there was no connection between serial gateway on RPi und sensor nodes.
                                  Above is the whole setup described. Wiring is taken from the mysensors web site.
                                    I am referring to create an ethernet gw running on the RPI instead of a serial gw.
                                      A
                                      A
                                      alop
                                      @gohan I do not have ethernet hardware. I just wanted to connect radio directly to RPI
                                        Just follow the guide of raspberry gateway and choose to configure it as ethernet, it makes it easier to setup con controller.
                                          A
                                          A
                                          alop
                                          @gohan said in Raspberry Gateway + Arduino pro mini (atmega328p) NRF24L01 (without plus +):
                                          choose to configure it as ethernet, .
                                          But if I understand right, I need ethernet gateway hardware, or am I missing something?
