  3. DevDuino v2.2 with EEPROM
devduinorf24nrf24l01+
10 Posts 4 Posters 5.1k Views 2 Watching
  • icebobI Offline
    icebobI Offline
    icebob
    Are there anybody, who could use the RF on this board with mySensors?
    http://www.seeedstudio.com/wiki/DevDuino_Sensor_Node_V2.2_(ATmega_328)
    I ordered one from this board and yesterday received. Firstly I couldn't upload sketch, but I found out the RX and TX pin label swapped on the board. After it, I could upload a sketch from here:
    https://codebender.cc/sketch:54782?referrer=gregl
    But the CE and CS pins moved to 7 and 6 (I changed it in the sketch) . But after boot, I got radio fail error on serial port.
    D 1 Reply Last reply
    • icebobI icebob
      Dwalt
      @icebob Where did you change the CE and CS pin designations?
      • icebobI Offline
        icebobI Offline
        icebob
        @Dwalt I'm using v1.5 so I added CE, CS define lines below MySensors.h include line
        • icebobI Offline
          icebobI Offline
          icebob
          Ok, now it's working. I changed CE and CS in MyConfig.h. I thought I can redefine the values in the sketch file too.
          • H Offline
            H Offline
            Nope #defines doesn't get propagated from the sketch in 1.5.
            But you will be able to do it from codebender once we release the 1.6 version of the library [but we had to do some haxxor thing to get that working].
            • icebobI Offline
              icebobI Offline
              icebob
              @hek Thanks. I'm waiting for 1.6.
              • O Offline
                O Offline
                Oleg Greengo
                wrote on last edited by Oleg Greengo
                Try it this way
                #include <MyTransportNRF24.h>
                #include <Vcc.h>
                const float VccMin = 2.00.6; // Minimum expected Vcc level, in Volts. Example for 2xAA Alkaline.
                const float VccMax = 2.0
                1.5; // Maximum expected Vcc level, in Volts. Example for 2xAA Alkaline.
                const float VccCorrection = 3.07/3.04; // Measured Vcc by multimeter divided by reported Vcc
                Vcc vcc(VccCorrection);
                int TEMP_SENSE_PIN = A3; // select the input pin for the battery sense point
                float TEMP_SENSE_OFFSET = -0.01;
                #define CHILD_ID_TEMP 0
                //MySensor gw (8,7);
                MyTransportNRF24 transport(7, 6);
                MySensor gw(transport);
                • icebobI Offline
                  icebobI Offline
                  icebob
                  @Oleg-Greengo thank you! It's working!
                  I modified the code and it's working on DevDuino v2.2
                  https://codebender.cc/sketch:203114
                  • icebobI Offline
                    icebobI Offline
                    icebob
                    The power comsumption is 30uA in sleep (not connected additional sensor just the MCP9700).
                    • O Offline
                      O Offline
                      Oleg Greengo
                      Here is the code works with devDuino v2.2
                      It shows how all of the sensors on board (via com port)
                      and also makes it possible to (expect) to download the firmware over the air. (for example through MYSController)
                      This sketch is for a devDuino SN v2.2 with the support OTA http://www.seeedstudio.com/wiki/DevDuino_Sensor_Node_V2.2_(ATmega_328)
                      and MySensors 1.5
                      For testing all the equipment, press the button D4 when a voltage is applied.
                      This sketch is a modification of code written
                      Version 1.3 - Thomas Bowman Mørch
                      for sensor Sensebender Micro
                      http://www.mysensors.org/hardware/micro
                       modified
                       18 December 2015
                       by greengo
                      #include "utility/SPIFlash.h"
                      #include <EEPROM.h>
                      #include <sha204_lib_return_codes.h>
                      #include <sha204_library.h>
                      // Define a static node address, remove if you want auto address assignment
                      //#define NODE_ADDRESS   2
                      #define RELEASE "0.01"
                      #define TEST_PIN          4 // Button D4
                      #define TEMP_SENSE_PIN   A3 // Input pin for the Temp sensor MCP9700
                      #define LED_PIN           9  // LED
                      #define ATSHA204_PIN     A2 // ATSHA204A
                      const int sha204Pin = ATSHA204_PIN;
                      SPIFlash flash(8, 0x1F65);
                      // the setup function runs once when you press reset or power the board
                        // initialize digital pin 9 as an output.
                        pinMode(LED_PIN, OUTPUT);
                        Serial.print(F("devDuino V2.2"));
                        Serial.println(RELEASE);
                        Serial.flush();
                       // First check if we should boot into test mode
                        pinMode(TEST_PIN,INPUT);
                        digitalWrite(TEST_PIN, HIGH); // Enable pullup
                        if (!digitalRead(TEST_PIN)) testMode();
                        // Make sure that ATSHA204 is not floating
                        pinMode(ATSHA204_PIN, INPUT);
                        digitalWrite(ATSHA204_PIN, HIGH);
                        digitalWrite(LED_PIN, HIGH);
                      #ifdef NODE_ADDRESS
                        gw.begin(NULL, NODE_ADDRESS, false);
                        gw.begin(NULL,AUTO,false);
                        digitalWrite(LED_PIN, LOW);
                        Serial.flush();
                        gw.sendSketchInfo("devDuino SN V2.2", RELEASE);
                      // the loop function runs over and over again forever
                       * Verify all peripherals, and signal via the LED if any problems.
                      void testMode()
                        uint8_t ret_code;
                        byte tests = 0;
                        digitalWrite(LED_PIN, HIGH); // Turn on LED.
                        Serial.println(F(" - TestMode"));
                        Serial.println(F("Testing peripherals!"));
                        Serial.flush();
                        Serial.print(F("-> MCP9700 : "));
                        Serial.flush();
                        if (analogRead (TEMP_SENSE_PIN),HIGH )
                          Serial.println(F("ok!"));
                          tests ++;
                          Serial.println(F("failed!"));
                        Serial.flush();
                        Serial.print(F("-> Flash : "));
                        Serial.flush();
                        if (flash.initialize())
                          tests ++;
                        Serial.flush();
                        Serial.print(F("-> SHA204 : "));
                        Serial.flush();
                        if (ret_code != SHA204_SUCCESS)
                          Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
                        Serial.flush();
                        if (ret_code == SHA204_SUCCESS)
                          ret_code = sha204.getSerialNumber(rx_buffer);
                            Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
                            Serial.print(F("Ok (serial : "));
                            for (int i=0; i<9; i++)
                              if (rx_buffer[i] < 0x10)
                              Serial.print(rx_buffer[i], HEX);
                            Serial.println(")");
                            tests ++;
                        Serial.flush();
                        Serial.println(F("Test finished"));
                        if (tests == 3)
                          Serial.println(F("Selftest ok!"));
                          while (1) // Blink OK pattern!
                            delay(200);
                            delay(200);
                          Serial.println(F("----> Selftest failed!"));
                          while (1) // Blink FAILED pattern! Rappidly blinking..
                      12.1k
