Which are the *best* NRF24L01+ modules?
    @nftrix said:
    Just wanted to confirm that the findings here did not make the NRF's on the store "not recommended" or anything.
    Most definitely not. They're more than recommended from most of us i think, from a quick look at the forum topics anyway.
    The speeds settings (250k, 1M, 2M) are not the same as the power settings (Low, Med, High, Max).
  • @NeverDie
    I just compiled and uploaded your code to two uno's and all I am getting is
    OTA datarate set to 1Mbps. Transmit Power set to Maximum.
    rf_setup = 111
    Sending...
    how long does it take to get any output on the serial monitor?
    @parachutesj
    I was using 3.3v pro mini's, not uno's. Maybe you have a level shift problem.
  • @NeverDie
    ok, thank you. using Nano's work. getting 13% loss is not too bad
    @GertSanders
    In your experience, which of the SMD modules have you found work the best?
    @GertSanders
    Are you happy with their performance? I imagine the answer is yes, but I thought I'd ask just to be sure.
    I am, there is one on my front door, which needs to cross two floors to get to the gateway in the attic. Bleeps every time. Range (as far as I can see) is close to the classic small version.
    Good enough for me.
    @GertSanders
    Thanks! I just now ordered some of the same SMD modules using the link you provided. The last time I looked into this (at the start of this thread), it seemed as though just about everyone was using a different mix of modules and platforms. and that made an apples-to-apples performance comparison quite difficult. However, this time around, I'll be running the same modules as you on the same hardware platform as you (well, nearly so, assuming I build it to spec), and so if it works well for you it presumably should work the same for me too.
  • Good morning together, iam very new in mysensors forum, so this is my first post, and i have a question: a want to buy these NRF's can somebody tell me if they are okay?
    https://www.amazon.de/Kuman-nRF24L01-Wireless-Transceiver-Compatible/dp/B01BVAAASY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1464158231&sr=8-1-fkmr0&keywords=nordic+nrf24l01+10pcs
    Thank you!
    @HarrySteff There is no way (that I know of) to determine in advance if the modules work according to specification. Even different lots from the same supplier can vary in performance. I have a 5 out of 6 succes rate with different suppliers.
  • Thank you @AWI i will Order them to Test...
  • I have had an excellent experience with the SMD version. I cannot say if there are different versions of it, but all transceivers I purchased from different suppliers work flawlessly.
    @alexsh1 Do you have any links for the SMD versions that you can recommend, i'm wanting to try these now. Thanks.
  • @Samuel235 these were the ones I ordered last time. Tested all of them and very much pleased
    Look what I found on AliExpress
    http://s.aliexpress.com/ZfArmaqe
  • @alexsh1
    At which settings do you use them?
    I have those http://www.aliexpress.com/item/10PCS-LOT-NRF24L01-wireless-data-transmission-module-2-4G-the-NRF24L01-upgrade-version/1593276910.html
    And not so happy as they seem to loose connection from time to time over distance of 4-5m
    I set them at 250 and have good power & caps attached
    At least the chip seems to be original but not soldered very well
  • @parachutesj I'll be honest with you - so far I had more luck with the SMD version which works 20m+ across a few walls than with a regular transceivers. Sometimes one needs to invite a shaman to make sure that nrf24l01+ works.
    I have 250kb rate on all nodes + caps. All works fine. With some regular nrf24l01+ I had issues with some batches and claimed money back successfully after ditching the whole batch. Luckily, this bad batch has not been working at all rather than working intermittently.
    Just a suggestion - did you change any settings on your gateway nrf24l01+? I'm using the amplified version by the way feeding it through AMS1117 LDO
  • @alexsh1 said:
    I switched to ampliefied nrf24 with antenna from the link in the shop but this seemed to make it even worse. It was powered externally and tried to shield it with no real luck. I ordered some shielded ones from ICstation which are still in customs process and hope to get them by the weekend. I also ordered a bunch of others and I will try which are the best for my operations.
    Just today I hade the closest node getting stuck. I wasn't able to send any from controller to the node. After triggering a signal from the node (it is a rollershutter) it came back to live and was able to send via controller again. Quite annoying...
    Maybe I need to try some different caps and voltage regulators, actually got "good" ones from my local electronics shop.
    Do the amplified modules simply always function at full amplification, or is there a code change that's needed to adjust the Tx power? Towards the start of this thread I tried some amplified modules from ICStation, but I was hugely disappointed with them. In fact, I don't think I saw any improvement at all, which greatly contradicted the experience that some others appeared to be getting. At least at that time, though, there was no real guidance on how to use them effectively, and so maybe I wasn't driving them right. Maybe there's more information now.
  • @parachutesj What settings do you have on your gateway please?
  • @NeverDie In MyConfig.h there are settings:
    The second one is for the amplified version (RF24_PA_MAX can used)
    Please check out this:
    https://forum.mysensors.org/topic/653/nrf24l01-pa
  • @alexsh1 I have this
    #define RF24_PA_LEVEL_GW RF24_PA_MAX
    on the GW
    Maybe I need to try RF24_PA_HIGH if it changes anything. However still waiting for the "good" radios to arrive
  • @parachutesj First things first:
    1. Good transceiver
    2. decent 3.3V feed
    3. settings MAX or HIGH etc
  • All of my ~20 NRF24's from 5 different dealers are consuming 15mA when the node is in sleep mode. Is this really a radio problem, or a software problem?
    By pulling out the radio, current drops below 1mA.
    • 2.0.0beta binarySwitchSleep sketch
    • My-Slim-2AA-Battery-Node
    • bootloader from My-Slim-2AA-Battery-Node OpenHardware source
    • BOD disabled by fuses, 1MHz internal
    • current messuered with Fluke multimeter
    @rollercontainer
    Have you tried to measure the power consumption whithout radio, and just putting the atmega328 in deep sleep (sleep(0)) ?
    Normally you should then see something less then 10 micro amperes.
    If the node still consumes around 1mA in this situation, then I would advise to look at the soldering and the other components.
    With BOD disabled, an atmega328p in deep sleep consumes around 1 micro Ampere,.
    Did you use the atmea328P version or the standard atmega328 (without the P) ?
  • @GertSanders I wrote "below 1mA" because I couln't recal the exact value, just for pointing to the relation between radio consumption and idle without radio.
    I've got 328P from Reichelt.de and messured again withoput mysensors.h and with SLEEP_MODE_PWR_DOWN. The multimeter reads 0,09mA at 60.00mA range set. Looks valid to me.
    @rollercontainer
    If you are using the internal pull up resistors on the switch input pins, then indeed you will get something like 30-60mA.
    That is why we use external pull up resistors for switches when we want to go for lowest possible power consumption.
    The internal pul up resistors have a value around 30K-45K (there is some variation). The pull up resistors I use are 1MOhm, this cuts the current consumption by two factors.
    @rollercontainer : you cannot get a proper measurement using only just a multimeter. Fluke or no Fluke, it just isn't going to happen. Lookup "burden voltage." Enough said, as this has been covered in-depth all over the place.
  • You both missed the point. My problem isnt the idle consumption yet. My problem is, that all the radios consume too much. Is there a way to get it down, or do I have to dump them all?
    @rollercontainer are you using the Arduino SLEEP_MODE_PWR_DOWN ? If so, the radio will still be active because the Arduino library isn't aware of the radio. Use the MySensors gw.sleep instead.
  • Holidays are over, back to work ^^
    To clarify it again:
    First I tried with complete 2AA slim node, several radios, sensor and the default binarySwitchSleep 2.0.0beta sketch. (15mA)
    For the second run: NO radio, sensor or MySensors.h were used. Therefore I wrote a minimal sketch with SLEEP_MODE_PWR_DOWN to ensure that the AVR is going to sleep mode. (< 0,1 mA)
    This leads me to the conclusion, that every of my ~20 radios is faulty. Are there any ways to prove this?
    @rollercontainer
    Sure. Buy a "known good" radio for comparison.
    Are the radios in the store here known as good and working now? I know we had issues with a bad seller previously, has this been sorted now?
    @NeverDie are you sure the node enters deep sleep? The current you measure is typical for a non sleeping radio. Main problems I have with the bad radio's is that these stay awake until they "found a parent". Where do you live? If you drop me a message I can send a tested one.
    I don't recall. It's been a while since I ran the tests. Presently I'm using RFM69's, which draw about 100na when sleeping, but at some point this summer I hope to revisit using NRF24L01's. I've already received the SMD modules that Gert Sanders is using, and I'll be giving them a try on the boards he designed, so the odds are favorable that I'll be getting the same or similar results. I received the boards from the fab, so after I receive the remaining parts I'll do the assembly.
    Earlier in this thread it was advised to order direct from Itead, on the grounds that they were manufacturing them. So, going directly to a reputable source might increase your confidence of getting what's advertised. Frankly, these things are cheap enough that I'd suggest going to several different such sources and then vet what you get using an oscilloscope. I did that earlier in this thread, and you can compare your results with the screenshots I posted to ID your chip. Of course, that by itself doesn't guarantee that the antenna was properly matched, which is why I think comparing the ranges of different modules from different sources is probably still a good idea. Even if the components are right, the dielectric of the PCB could throw off the match, and you won't know that just by looking at it.
    Unfortunately i don't have an oscilloscope at the moment. So i have to just test them in the circuit as intended to be used.
  • @NeverDie I already bought these ~20 radios from 5 different dealers...
    @AWI I am not sure, therefore I am asking here. But what more can I do? I am using a default sketch with only this modification:
    #define MY_NODE_ID 70
    #define MY_PARENT_NODE_ID 0
    #define MY_REPEATER_FEATURE false
    The node is useable, so it sends reed contact changes to the mqttClientGateway which sends it to my raspi. Is the static method preventing the node from deep sleep?
    I live in northern germany. Thx for the offer. But I dont really believe, that all radios are faulty by now.
    @rollercontainer
    I still suspect either a configuration or a measurement error. I suggest you photograph in detail everything you're doing and post it. If you're overlooking something, maybe somebody will spot it. Otherwise, there's just not much to go on.
  • I setup a new Arduino IDE 1.6.9 portable with MySensors 1.5 and flashed a standard 8MHz bootloader with BOD off.
    Idle current is nearly unmessureable by my MM, showing only 0,01 mA at 60,00 mA range.
    Next step is to get a 1MHz bootloader to work with low current.
    Thx for your words, guys.
  • flashed the 1MHz Optiboot again, compiled the sketch and loaded it up. Idle current is staying under 0,01mA. So, looks like the 2.0.0beta libs are "guilty".
  • @rollercontainer Interesting...with 2.0b I have 6uA consumption in a sleep mode on Pro Mini + nrf24l01+
    hi.
    there is no interest to use 1mhz during sleep mode because in this mode clock is stopped. No matter the freq, if you have no problem in your circuit and software is well configured and bod disabled, just the atmel in standalone is consuming 140nA in deep sleep.
    1mhz can be helpful during active mode but it reacts slower, wake up slower, and can cause trouble for communication like serial... and sometimes it can be less effective vs keeping internal rc.
    But 1mhz is useful, used in certain ways of course, i use it too 😉
  • it is working with lower voltages at 1mhz, thats the reason I use it on a 2 AA node.
    But @scalz is saying that only in sleep mode the frequency does not matter, it has no effect on the power consumption. However, it will effect your power consumption while the MCU is awake, but there're discussions regarding the length of time its awake some times means that it uses less power if using a higher frequency due to it performing its tasks quicker and then returning to sleep.
    So, I guess the question is whether waking up at 8mhz on 1.8v will be a problem or not. It's out of spec according to the datasheet. I'd certainly much prefer to wake-up the atmega328p at 8mhz than 4mhz or 1mhz, because then the wake-up time can be very, very short (<4us). No other setting that I know of comes anywhere close to 4us.
  • @rollercontainer I have 8Mhz working below 1.8V. The problem is that below 1.9V, it is unstable as the radio may be working intermittently. I think @GertSanders reported his node running down to 1.6V at 8Mhz. In any case, I do not think one has to run 1Mhz as power saving compare to 8Mhz is not massive and clock is not working - the latter is by far important for my needs.
  • @rollercontainer
    I have found that the NRF24L01+ PA LNA radios I have, have 100% packet loss and will not sleep if driven with voltages over 3.0v I have dropped the supply to 2.7v and now have minimal packet loss and the radios will sleep at all power level settings.
    Current draw is 4.7uA including 328P + RTC when asleep as measured with a uCurrent Gold.
    @doug That is an interesting observation. Was there a specific reason to test this? Have you tried other voltages also?
  • @AWI
    I was building a boost converter with one of these Texas TPS61097A-33DBVT the NRF I was using on battery didn't work with the boost CCT. I tried with 4-5 of these modules all from the same supplier and none of them worked. My scope showed they were transmitting and the uGold was showing sleep mode was not happening. When connected to an adjustable converter I notice that if I wound down the voltage under 3.0v they would spark into life. Its the same with all the NRF PA LNA modules I tried.
  • I bought my first NRF24L01+ modules from cg market and I created some simple nodes (temp/hum and binary switch) using 3V coin battery, and they are up since last January. Than, I'm wondering why 😒, I bought other modules from another seller and I got a lot of problem: the binary switch (same of the other one in software and hardware) fails many times in sending communications to the gateway and after just 1 month I had to replace the battery; another node cannot even communicate at all if I move it in another room different from the gateway (of course I tried different values of decoupling-capacitors) 😞
    I have to get new modules 😢
    @doug said:
    @rollercontainer
    Would you please post a photo of what the module looks like? It might offer up some clues.
    Here is a photo of the module
  • @doug I do have the same ones bought at alice from the shop link. I also have issues and basically not functioning. I will try your "fix" and see how it goes. Did you do some shielding?
    Cheers,
    SJ
  • @doug I did some quick tests and I can confim that the modules work better with less voltage. I made best experience with 2.5-2.6V. However they are still much much worse than all others I have and not worth the hassle IMHO.
    Which other ones do you have that perform better? It would be very useful to know.
    Cheers,
    SJ
    FWIW, I use these exact ones and I get very good range with them, without additional shielding.
    Al
  • @NeverDie
    I have the shielded ones from IC-Station:
    http://www.icstation.com/22dbm-100mw-nrf24l01ppalna-wireless-transmission-module-p-4677.html
    Back to the ones discussed here:
    When doing the basic test from earlier in this thread I am getting massive packet loss even if the modules are very close together. Ok, maybe it needs to be shielded, power too high etc and tried having them separated with no luck, still massive packet losses. Of course this is no scientific research.
    Without tweaking, modifications, special antenna orientation the shielded IC-Station ones just worked for me. I am not saying the others don't work, they just perform not in my setup very well.
    Also as a comparison, I have some cheep modules from Aliexpress they outperform the ampliefied ones (at least within the house):
    Those modules look very poor build to be honest but seem to be ok. They came in one single back, some pins bent but nothing which couldn't be fixed. Minor packet losses and antenna orientation seems to be key.
    In comparison, I also bought some more expensive ones, which claim to be original:
    http://www.aliexpress.com/item/Free-shipping-Original-Genuine-NRF24L01-Wireless-Module-2-4G-wireless-communication-module-2-54mm-Interface-2/1781618813.html
    Those came in a nice protected box and look very well made.
    They work, I even think better than the others - but I already blew two of them. Not sure what went wrong 😞
    Just received some SMD ones which haven't been tested yet.
  • Does anyone know if the NRF24L01 and the +PA+LNA modules can be mixed and matched? Will the regular modules and the longer range versions talk to each other? I would like to use one of the long range modules on my gateway in the house and on some sensors around my yard that are a fair distance from my house. But then to save some money I was wondering if I could use the regular modules around the rest of my house. My concern is if I use regular modules on the sensors in my house if they will still be able to communicate with the longer range version module I have on my gateway?
  • @loralg I successfully use a nRF24L01+PA+LNA on the gateway and regular nRF24L01+ on the sensors.
    There is a lot of information and hints available in the forum regarding the nRF24L01+PA+LNA . See e.g. here:
    https://forum.mysensors.org/topic/3719/nrf24l01-vs-nrf24l01-pa-lna/2
    In my case, however, the nRF24L01+PA+LNA works fine without any fix or special attention.
    What is the best way to measure the performance of one module at a given distance? I mean, how can I measure the number of packets lost?
    Does anybody already created a "performace test sketch" to perofrm a better test?
    I posted a sketch earlier in this thread.
    How did you decrease the voltage on nrf24l01+ PA? I have a voltage regulator providing 3.3V.
  • I have also found that the higher the voltage the more capacitance you need. Guess that makes sense. Still can't get them to work reliably at 3.3v though.
    I am realising the important thing is a good power supply you need to choose the right regulator to ensure the voltage doesn't tank too far when the current spikes (~180mA). caps help to some degree and I have found ceramic are better than the aluminium ones.
    I am now using a single cell lipo and 2 regulators one at 3.3 and one at 2.7 for the radio. Also easier to get a low IQ with 2 regulators rather than one big one.
    I am still learning and need to start doing some playing with a greater range of modules. Especially as your experience of these is that they are pretty poor.
  • @alexsh1
    I'm wondering the same as @alexsh1 . How can I get 2.5-2.6V? There is an easy/cheap way to do it?
    @afeno The cheap way is a diode in the vcc line. The voltage drop over a normal silicon diode (i.e. 1N4001) is around 0.7V. This has proven to be a working solution.
  • @alexsh1
    as it was just a test, I used a table power supply to have the exact voltages.
    I'm creating a "ping" sketch to measure the % of packet lost using the tmrh20 library. I will post it once it is finished but it is just a modification of the "GettingStarted" sketch.
    It is very simple:
    • Node 1 send a value to node 2.
    • Node 2 receive the message and send it back to node 1.
    • Node 1 receive the message.
    I'm measuring the number of packets lost and the turnaround time.
    But doing some tests, I realised about something very strange that I don't understand...
    Based on the sketch described above, both the node 1 and 2 are sending and receiving the same amount of data.
    They both use the same commands to send and receive.
    I have two hardware sensors/devices (let's call it A and B ) based on arduinos nano.
    When I use A as Node 1 it gets 0.2% of packets lost. (B is used as Node 2)
    When I use B as Node 1 it gets 15% of packets lost!! (A is used as Node 2)
    Remember: Both nodes are sending and receiving the same amount of data.
    I understand that the current, radio, noise, etc. might have an impact on the performance and range but why it is working fine on one way? And not in the other way? This is making me crazy. Both sensors are sending and receiving the same data. If one of them is not sending (or receiving) well, the performance still should be the same independent on who is acting as node 1 or 2.
    What I am missing?
    Thank you!
    @afeno
    Interesting asymmetry.
    This sounds basically the same as the sketch I posted earlier. Perhaps post a photo of the two nodes? Maybe something will jump out.
    If you really want to solve it, try also
    testing the packet loss on the individual links instead of only roundtrip. I suspect it will reveal something.
  • Sorry for my ignorance... But how can I measure the packets lost on individual links?
    Do you mean to check the packets lost in a 1-way trip? Only from node1 to node2?
    I thought it might be best to contribute to this thread rather then making a new one. I have some NRF24L01+ for like 2-3 years. Some of them are the normal ones and a few LNA+PA.
    The following explanation requires some "advanced" knowledge about the RF24 library and the test-sketch I added. Please forgive me as I was not able to write a more simple sketch and explanation.
    From day one I had problems using the modules at 250kbps with autoack. The Reception (RPD) was very poor and I had very high packet loss.
    For a few days now I have been tinkering with mysensors and just recently noticed .. wait what???
    250kbps + autoack is default.
    As mysensors is not ideal for testing modules I used another well known library:
    http://tmrh20.github.io/RF24/
    To get access to a very important register to debug autoack issues I modified "RF24.h" to get the low level functions public:
    **public:**
       * @name Low-level internal interface.
       *  Protected methods that address the chip directly.  Regular users cannot
       *  ever call these.  They are documented for completeness and for developers who
       *  may want to extend this class.
    After that I hooked up an single WS2812B-LED to pin 4 and tinkerd together a little test-sketch:
    0_1469476423782_getting_started_250kbps_minimum2.zip
    Note: You have to write the values 0 and 1 to EEPROM.Address 0 ONCE. 0 is the static pong back node and 1 is the mobile node with the WS2812B LED. This allows moving freely and check reception in your home.
    After writing the values to the eeprom you can comment out the code and don't have to worry when uploading the sketch to the "pongback"-node or the mobile "ping" node.
    //EEPROM.write(0,0); // 0 = PongBack
    If you don't want to use the WS2812B you have to remove some code but that should not be too hard.
    The important parts come now:
    settings[autoack] = 0;
    settings[retry] = 15;
    settings[delay_rf] = 15;
    Disabling autoack I could get an improved reading of RDP and very little PacketLoss. I now can cover distanced much larger like through 2-3 walls more then before.
    My modules are all powered from 3,3V dedicated LDO or 3V (2x AA) Battery and run @ 8MHz
    Long story short:
    If you have reception problems even after checking your Supply and even after trying the "ugly fix" and still got nowhere .. i suggest your try disabling auto ack. Although this it not intiutive on mysensors and would leave you vulnerable to packetloss I suggest you to test it out with this library (http://tmrh20.github.io/RF24/) and my example sketch.
    Sorry for not presenting a whole solution but I thought it might be worth to point people having reception problems into one possible "direction".
    PS: Autoack works fine on my modules if I switch to 1MBPS so this might be viable too.
    At current date, is there anybody that can suggest a place to buy good NRF24 modules? I live in Italy so probably US shops would be a little expensive on shipping cost.
  • @gohan
    I would not like to make a suggestion and rather reply my opinion on it:
    The worst experience I made was with the probably original ones (greenish on reference design). Not that the reception was bad but 4-5 already broke during testing and had to be exchanged.
    Therefore I buy the cheapest ones from GC supermarket or other big ALI-shops.
    However if you want a amplified version, I would spent the extra dollar and get a premium one. I posted it here somewhere and really made good experiences with it.
    @parachutesj
    I read your earlier post but after 7 months I was trying to get an update, you know things can change quickly 🙂
  • Just to add my 2cent .. I mainly use the LNA+PA ones (cheap from ebay) and complained some time for their "bad" performance.
    Just recently I noticed they are quite nice but .. RF24_PA_MIN is your friend! I got nearly zero packet-loss ~20m (one wall between) with RF24_PA_MIN. This might just be a subjective opinion but as they only cost 2-3$ a piece they are a good option (at least for me).
    Getting "genuin" chips for a reasonable price is very difficulty in germany.
    @cimba007
    I think I read somewhere in a different thread on this forum that the PA+LNA ones work better if powered from a lower voltage.
  • I ordered modules from ITEAD. They seem to have real nordic chips populated. Each module comes in paper box and ESD bag. The modules look like the cheap ebay stuff, but with 0402 components.
    With these modules I got rid of my issue with repeated messages.
    (https://forum.mysensors.org/topic/5588/multiple-messages-with-same-content-received)
    @karlheinz2000
    did you check the chip print if it is genuine or fake? There are some guides if you search. Those modules are quite cheap and that makes me wonder.
  • I checked the print and it is different to the cheap ones. But, I got genuine NRF24 chips (just the ICs) from mouser and this print is similar to the cheap ones!!??
    Edit:
    The print quality of cheap modules is not as good as genuine one and more space between dot and first line.
    Genuine parts differ in little dot or square.
    ITEAD
    IC from Mouser
    Cheap Ali/ebay
    @karlheinz2000
    The first 2 definitely look similar, but the top left logo doesn't look genuine to me. But actually I don't care much about being genuine or not, the import thing is how they perform in terms of reliability and range
  • @NeverDie: In addition to using RF24_PA_MIN I power most of my nodes from 2x AA Alkaline Batteries .. so they have 2.2V - 3,0V VCC. This might contribute to my pretty good reception.
    Earlier nodes used 3,3V LDO in connection with lithium-ion batteries. So I can't say what really improved my reception the most ... lowering the voltage or putting the RF24_PA_MIN.
  • @gohan @karlheinz2000
    just for comparison, my "geniune" has also the same logo and the cheap one looks much "better" but one can see the bad production quality
    top one is GC supermarket, bottom genuine
    Anyone know what the optimal voltage range is for running the PA_LNA versions? It would be good to know for future reference.
    @gohan said:
    @karlheinz2000
    Agreed. And it's not just the chip that will determine that, but rather the entire ball of wax.
    @karlheinz2000 @parachutesj @gohan It appeared to be pointless to compare markings of nRF24L01+ IC's to determine if they are genuine or not.
    Nordic is fabless and uses different fabs to produce their IC's. Each fab will have a different way of marking the chips.
    I had a discussion with a Nordic representative in the past and even he could only say for sure if an IC was genuine or not by putting the part in X-Ray.
    He had 3 different modules analyzed which I mailed to Nordic (China versions); all 3 appeared to be fakes...
    The blob ones however are fake for sure.
    @Yveaux
    So basically we are stuck at trying modules from a supplier and share on the forum if they work or not, right?
    Since its impossible to determine if a radio is genuine, fake or even working (power consumtion in sleep mode for example) is there a good sketch and/or PCB to test the radio module?
    Another user wrote me a few days ago that there are modules that work best with 4.7uF cap while others need higher capacity, so that makes it also more difficult to make a test rig. In addition I don't remember if there is a way to get signal quality from NRF24 (but I don't think there is) to help the tests
    @sundberg84 not that I'm aware of. I tried to differentiate them based on power usage, but didn't get far.
    @gohan said in Which are the *best* NRF24L01+ modules?:
    @Yveaux
    WRONG. If you read this thread (search for "nailed it"), and if you have an oscilliscope, I show what seems like a 100% reliable way to differentiate between genuine and fake chips.
    In this particular instance, if you're unsure which cap value to pick, pick the one with the biggest value. Overkill is better than underkill.
    He claimed to have run some tests and it came out that bigger isn't necessarily better.
    And I don't have an oscilloscope to test chips
    When I tested the iTead modules (see earlier posts in this thread), they proved out to be genuine. Since you're unequipped to make a determination yourself, then if you're just wanting a simple answer, I suggest you try those.
    I'll keep in mind for next purchase, tnx
  • @NeverDie Hi there! So as a summary were you able to get a few trusted suppliers (sellers) to buy these modules from to get genuine ones?
    Is this one a good one to buy from.
    Aliexpres item
    @VItaria-VM did you try them?
    @NeverDie said in Which are the *best* NRF24L01+ modules?:
    It turns out my scope can do better than I thought. Here's the blob module again, but this time at 5mv/div.
    So, I may be able to use an even smaller resistor, because now I can go down to 1mv/div, whereas before it seemed it wouldn't let me go lower than 10mv/div. Hopefully that will help improve my measurement accuracy.
    Haha it seems back then you got cheated by the infamous zoom function of the Rigol oscilloscopes 😄
    @Nca78 said in Which are the *best* NRF24L01+ modules?:
    Haven't heard about that one. What makes it infamous?
    Real resolution is 10mV/div, and from there it's only zooming from the 10mV/div data to reach the 1mV/div. They are "hiding" this, pretending to have better resolution instead of telling you it's zooming like other brands do.
  • Beginner here and I am gathering a list of parts to buy, the NRF24L01+ module is one of those. While browsing for buying advise I came across this, old but relevant, threads. Is there a list of verified vendors? As a beginner I want to minimise my variables early on so hope some one can help me. Couldn't find another thread that covers this question.
  • 87
  • 7
