  3. Vera
  4. Vera Lite U17 - Serial Can't Detect Device
cant detectserial gatewayvera liteu17
13 Posts 7 Posters 12.6k Views 2 Watching
    Try setting ComFailure to 0 and save device/reload.
    greglG B 2 Replies Last reply
    • G
      G
      gbfromhb
      @Hek - That did it. It is now working, thanks.
        greglG
        greglG
        gregl
        @hek Do you know why this fixes it?
        Does vera not retry if ComFailure >0 ??
        On my UI7 test box and test g/w, if I turn off the g/w for whatever reason I find I need to restart luup on Vera to get it to re-establish connection to the g/w.
        So I wonder if it does retry after a period ( which ive never been patient enough for )
          I have no idea why it works. As you say.. it probably doesn't retry if this number is larger than 0. I had the same problem with my Alarm system.
          • CaptainZapC
            CaptainZapC
            CaptainZap
            To fix that error someone, needs to update the plugin and include this line:
            luup.set_failure(false)
            This way the can't detect message won't be displayed anymore.
              Hmm.. the UI7 branch already have this in place:
              https://github.com/mysensors/Vera/blob/UI7/L_Arduino.lua#L572
              • TmasterT
                TmasterT
                Tmaster
                wrote on last edited by Tmaster
                i had the same issue and it was the serial chip was not apropriate and won't comunicate. ch340,fake ftdi... that kinds won't comunicate propely and cause problems. after change to a FTDI chip all works good
                i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                • G
                  G
                  gbfromhb
                  Thank you @Tmaster. I put this project away a while ago, and just recently realized after some unrelated reading what the issue must be with this adventure. I'm pretty sure this is what is going on and just have not had the time to get back to it.
                    B
                    B
                    bgriffith87
                    @hek Thank you so much! That solved the problem for me!!! :)
                    • I
                      I
                      itbeyond
                      @hek This fix worked for me today using Plugin 1.5 Version 2.1.1 on UI7 1.7.2607
