  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.4k Views 18 Watching
    Samuel235
    I get why you done it, but i don't understand why. You don't need to 'know' mysensors.... There is a getting started page, i suggest you take a few hours and read through everything. I'm not helping with an issue that is completely not related to mysensors while on the mysensors forum. Just simply for future readers of this thread that come here to solve their issue, if this thread is bloated out with over 10/20 replies that is not related to the question at hand its much harder for them to find their resolution here. I suggest contacting the author of the code himself as i'm pretty sure that your issue is not the bootloader.
    MySensors 2.1.1
    mar.conteM 1 Reply Last reply
    • S Samuel235
      mar.conteM
      mar.conteM
      mar.conte
      @Samuel235
      Thanks anyway, this section introduced me to some very interesting bootloader, at least with these bootloader I can get a few microamperes for my projects, I will take note of your good day and thank you tips
      M.C.
      • siodS
        siodS
        siod
        Hi guys,
        I am getting an errror when trying to burn the bootloader, any idea what´s wrong? Im using Arduino IDE 1.6.10 and these settings:
        0_1495966865551_upload-48973443-91a2-4504-a73b-96557383d6bf
        and that´s the error:
        avrdude: Version 6.3, compiled on Jun 22 2016 at 16:05:21
                 System wide configuration file is "T:\Programme\Arduino 1.6.10\hardware\tools\avr/etc/avrdude.conf"
                 Using Port                    : COM10
                 Programmer Type : STK500
                 Hardware Version: 2
                 Firmware Version: 1.18
                 Topcard         : Unknown
                 Vtarget         : 0.0 V
                 Varef           : 0.0 V
                 Oscillator      : Off
                 SCK period      : 0.1 us
        Reading | ################################################## | 100% 0.06s
        avrdude: erasing chip
        Writing | ################################################## | 100% 0.03s
        avrdude: verifying ...
        Writing |  ***failed;
        ################################################## | 100% 0.16s
        Fehler beim Brennen des Bootloaders.
        avrdude: verification error, first mismatch at byte 0x0000
                 0xfe != 0x06
        avrdude done.  Thank you.
        still learning...
        alexsh1A 1 Reply Last reply
        • siodS siod
          Hi guys,
                   Using Port                    : COM10
                   Hardware Version: 2
                   Topcard         : Unknown
                   Vtarget         : 0.0 V
                   Varef           : 0.0 V
                   Oscillator      : Off
                   SCK period      : 0.1 us
                   0xfe != 0x06
          alexsh1A
          alexsh1A
          alexsh1
          #158
          @siod what board are you using? Windows or Mac?
          I would suggest update Arduino IDE - you are running an old version
          Many people experience similar issues when using a wrong version of IDE:
          https://forum.arduino.cc/index.php?topic=431294.0
          • GertSandersG
            GertSandersG
            GertSanders
            I have been using version 1.8.x (at 1.8.2 now) for quite a while now, so no experience with 1.6.10
            Best is indeed to update the IDE, as this will also bring new versions of GCC (the compiler) and I thought also of AVRDUDE (transfertool). Not sure about that last bit though.
            Gert
            • siodS
              siodS
              siod
              Hi guys,
              thx for your quick reply. I could upload the bootloader using ver 1.6.5 of the Arduino IDE. After that I realized ther is already a 1.8.2 version released which is closing the gaps between arduino.cc and arduino.org.
              I havent tested this version now, but I guess it was just an IDE error, so everything´s fine now...
              still learning...
                martim
                I have copy the file over the existing files and then I get this error with burning:
                java.io.IOException: Cannot run program "{runtime.tools.avrdude.path}/bin/avrdude": CreateProcess error=2, The system cannot find the file specified
                I am using Arduino IDE 1.8.2
                • A
                  aclertant
                  I'm probably a rare case but I successfully burn the bootloader (atmel 328p stand alone with slimeNode board) using atmel studio7 with an AVRMK2ISP, flash the mySensors code using arduino IDE and the "nodeManager" libraries succesfully too and everythings appear properly in my HomeAssistant, very nice, I've just give a paypal tips ;o)
                  But I have no idea why I use this bootloader ??? If I used a nano, I wont change the bootloader ? Is there something better ? It could look stupid but their is no real explain about WHY I must change my bootloader on this page...
                  • R
                    R
                    Rolo6442u
                    wrote on last edited by Rolo6442u
                    #163
                    Found these bootloaders and using the 1MHz for some low power experiments. I did get this error message when burning the bootloader (using USBASP programmer) :
                    "avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
                    This behaviour is deprecated and will result in an error in future version
                    You probably want to use 0xfd instead of 0x05 (double check with your datasheet first)."
                    The bootloader woas succesfully burned so the message was informational. I did look into this and made the following changes in boards.txt :
                    I changed all the lines containing "......bootloader.extended_fuses="
                    There are multiples sections in the file that have these lines.
                    old value -> new value
                    0x04 0xFC
                    0x05 0xFD
                    0x06 0xFE
                    0x07 0xFF
                    I used this site link text
                    for calculating the new values for the extended fuse.
                    Now the error message is gone. Maybe this is of any help when using these bootloaders.
                    • GertSandersG GertSanders
                      @carlierd
                      I can probably package this in a directory structure you could add to the Hardware folder in the Arduino files, but I do not have the time for it right now. I know that has been done for the original Optiboot 6.2 files already (including a pinout file for the various processor variants):
                      https://github.com/Optiboot/optiboot
                      For the moment I have added my boards.txt file as I use it in my Arduino IDE (common), it shows some fuse settings, but you are right: a document describing the fuse settings to use, and their effect on a bootloader would be a nice reference for many people.
                      aramko aramko
                      Banned
                      #164
