  3. Sensebender with LED pulse count from openenergymonitor.org
sensebenderled pulse count
14 Posts 3 Posters 7.7k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    I am trying to use the LED to count pulse on my electricity meter from openenergymonitor.org :
    http://openenergymonitor.org/emon/buildingblocks/opticalpulsesensor
    Unfortunately, it does not work straight out of box - I think I need pull-down resistors . Any suggestions please?
    • SparkmanS
      SparkmanS
      Sparkman
      wrote on last edited by Sparkman
      How do you have it hooked up and post your sketch that you are using to test it.
      Cheers
      Al
      • alexsh1A
        alexsh1A
        alexsh1
        Thanks for your reply.
        I took the sketch here:
        http://www.mysensors.org/build/pulse_power
         * Version 1.0 - Henrik EKblad
         * This sketch provides an example how to implement a distance sensor using HC-SR04
         * Use this sensor to measure KWH and Watt of your house meeter
         * You need to set the correct pulsefactor of your meeter (blinks per KWH).
         * The sensor starts by fetching current KWH value from gateway.
         * Reports both KWH and Watt back to gateway.
         * Unfortunately millis() won't increment when the Arduino is in
         * sleepmode. So we cannot make this sensor sleep if we also want
         * to calculate/report watt-number.
         * http://www.mysensors.org/build/pulse_power
        #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
        #define PULSE_FACTOR 1000       // Nummber of blinks per KWH of your meeter
        #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
        #define MAX_WATT 10000          // Max watt value to report. This filetrs outliers.
        #define CHILD_ID 4              // Id of the sensor child
        unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
        double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
        boolean pcReceived = false;
        volatile unsigned long watt = 0;
        unsigned long oldWatt = 0;
        double oldKwh;
        unsigned long lastSend;
        MyMessage wattMsg(CHILD_ID,V_WATT);
        MyMessage kwhMsg(CHILD_ID,V_KWH);
          gw.begin(incomingMessage);
          gw.sendSketchInfo("Energy Meter", "1.0");
          gw.present(CHILD_ID, S_POWER);
          gw.request(CHILD_ID, V_VAR1);
          attachInterrupt(INTERRUPT, onPulse, RISING);
          lastSend=millis();
          gw.process();
          unsigned long now = millis();
          bool sendTime = now - lastSend > SEND_FREQUENCY;
          if (pcReceived && (SLEEP_MODE || sendTime)) {
            // New watt value has been calculated
            if (!SLEEP_MODE && watt != oldWatt) {
              // Check that we dont get unresonable large watt value.
              // could hapen when long wraps or false interrupt triggered
              if (watt<((unsigned long)MAX_WATT)) {
                gw.send(wattMsg.set(watt));  // Send watt value to gw
              Serial.print("Watt:");
              Serial.println(watt);
              oldWatt = watt;
            // Pulse cout has changed
            if (pulseCount != oldPulseCount) {
              gw.send(pcMsg.set(pulseCount));  // Send pulse count value to gw
              double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
              oldPulseCount = pulseCount;
              if (kwh != oldKwh) {
                gw.send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                oldKwh = kwh;
            lastSend = now;
          } else if (sendTime && !pcReceived) {
            // No count received. Try requesting it again
            lastSend=now;
          if (SLEEP_MODE) {
            gw.sleep(SEND_FREQUENCY);
          if (message.type==V_VAR1) {
            Serial.println(pulseCount);
            pcReceived = true;
        void onPulse()
          if (!SLEEP_MODE) {
            unsigned long interval = newBlink-lastBlink;
            if (interval<10000L) { // Sometimes we get interrupt on RISING
              return;
            watt = (3600000000.0 /interval) / ppwh;
            lastBlink = newBlink;
          pulseCount++;
        The LED has the following diagram:
        LED (RJ45) Sensebender
        Pin 2 = VCC -> VCC
        Pin 5 = GND -> GND
        Pin 6 = IRQ1​ -> D3
        SparkmanS 1 Reply Last reply
        • alexsh1A alexsh1
          double oldKwh;
            lastSend=millis();
            gw.process();
                oldWatt = watt;
                  oldKwh = kwh;
              lastSend = now;
              lastSend=now;
            if (SLEEP_MODE) {
              pcReceived = true;
          void onPulse()
            if (!SLEEP_MODE) {
                return;
            pulseCount++;
          Pin 2 = VCC -> VCC
          Pin 5 = GND -> GND
          Pin 6 = IRQ1​ -> D3
          SparkmanS
          SparkmanS
          Sparkman
          @alexsh1 I would measure the output of the sensor to ensure it goes high when it detects a pulse and put some println's in the code to see if the interrupt gets triggered at all.
          Cheers
          Al
          • alexsh1A
            alexsh1A
            alexsh1
            Thanks.
            The pulse sensor has got a separate green LED to indicate when a pulse is received - it is not blinking in my case. PrintIn does not show much unfortunately though the sensor is powered up with 3.3V. I need to figure out the pull-up/down resistor value.
            • alexsh1A alexsh1
              Thanks.
              SparkmanS
              SparkmanS
              Sparkman
              @alexsh1 Not sure if you need an extra resistor. I would expect there is some internal circuitry in the sensor already. Have you looked at the schematics of the emonPi, etc. on the OpenEnergyMonitor website to see if they have any additional components on their input for the sensor? I would expect the led to flash if you have Vcc and Gnd connected so perhaps something else is wrong. Are you powering with 3.3v or 5v?
              Cheers
              Al
              • alexsh1A
                alexsh1A
                alexsh1
                @Sparkman Yes, I did look at the openenergymonitor wiki - does not say much.
                However, managed to find on the their web-site the following:
                LED Pulse counting
                No pull down resistor is required as the pulse / light sensor output is logic level 0 when the pulse is low. However, if you build a pulse counting module with pull down resistors of ~10k it still works with the light sensor, more info to come on this.
                As this is sensebender (powered by two AA batteries), voltage is around 3.1V currently. Are you thinking this is an issue? Will check all the connections to make sure I do not have a bad connection or something.
                • alexsh1A alexsh1
                  LED Pulse counting
                  SparkmanS
                  SparkmanS
                  Sparkman
                  @alexsh1 The 3.1v might be a problem. I would power from 3.3v and see if the green led starts blinking. Doesn't sound like you need any pullup/down resistors.
                  Cheers
                  Al
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    @Sparkman Tried 3.3V and still does not work
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      @Sparkman I narrowed down the problem. The sketch and the sensor do not work with the sensebender. I used Arduino Nano instead and it worked though the gateway stopped receiving the signal after 10-20 mins, but that is a different problem. Now I think there is an issue with interruption with the sensebender.
                      Did anyone compiled energy pulse sensor on the sensebender please?
                      • alexsh1A alexsh1
                        SparkmanS
                        SparkmanS
                        Sparkman
                        @alexsh1 Good to hear you are making progress. With the nano, was it powered by 3.3v or 5v? From what I understand, the interrupt pins on the Nano and SenseBender should work the same, but maybe @tbowmo can confirm.
                        Cheers
                        Al
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          it was powered with 5V, but works fine with 3V.
                          I have to figure out if the interrupt pins are the same as nano
                          I have it fully up and running under the nano
                          • alexsh1A
                            alexsh1A
                            alexsh1
                            The interrupt pins are the same as Nano - I have to understand what was wrong in the first place.
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @Sparkman
                              You are right. The pin names on the sensebender, corresponds to the pin names on the arduinos, so the interrupt on D3 is the same as on the arduino.
