💬 MDMSNode "Lighting"
Can you please give a reference for the MDMS series devices? I'm not aware of it neither was able to find any reference in the forum. But I'm curious.
Will it be possible to buy this pre-assembled?
@Daniel-Oliveira Hi,
I can explain a little about this series.
MDMSGate is my first device which I has developed and tested already and I will be ready to sale it in late September.
https://www.openhardware.io/view/118/MDMSGATE
The next device is MDMSNode "Lighting", it is currently under development. I am expecting arrivial of printed circuit boards for testing.
After receiving the pcbs, I will solder and test MDMSNode "Lighting".
Then I am going to develop several devices (powered by lithium battery) for measurement of temperature, pressure, humidity, etc. These devices will be called MDMSensor "Temperature", MDMSensor "Pressure" or MDMSensor "Humidity".
@Cliff-Karlsson
Yes it is possible. I sell all of the devices that I have developed and tested.
Hi everyone!
I want to tell something about my project. Before I ordered a printed circuit board, I had made some improvements:- added LED for power supply indicating;
- used two free pins of the microcontroller for connecting to SMD pads;
- added two technological zones;
- fixed errors in silkscreen layer.
I have ordered 30 pcbs and, in my opinion, they will arrive in two weeks...
Is it possible to dim the light with this device? (and also LED lights)
@rubenverhoef Unfortunately, it isn't possible. I got the task to control the lighting on the basis of fluorescent and LED lamps, where dimming is not provided. But if it becomes necessary, in the new version MDMSNode "Lighting" I might add it.
Nice project. I like high density placement
But how this device will be cooled?
Bt137s dissipates a lot of power (see picture)
So it will dissipate 1W at 0.8A current. But Bt137s has 75K/W thermal resistance from junction to ambient (without heatsink).
This means a junction temperature will be ~100 celsius degrees if it lies on the table with connected less than 200W device. If we puts it inside a closed box...These is very rough estimation, but it pause for thought I think
PS
15mm height... You are cunning, at least 20mm :trollface:
@Koresh Thank you for your detailed question and interest in my project. I will try to explain.
Firstly, as I wrote earlier, I design the device to control the LED and fluorescent lamps. The max power, which I hope to use, not more than 35-40 watts. Following this, the current through the triac should not exceed 0.2-0.3 A. So, the power dissipated in the triac will not exceed 0.5W.
Secondly, I created the special area on the pcb (as you can see in the picture, the polygons on the top and bottom sides + vias),
which provides heat distribution and dissipation.
Thirdly, the fuse have to provides safety. Value of fuse, if somebody wants, can be set 0.2A. Also, close to the triac I put a thermistor.
As soon as I get the pcbs and soldered, I’m going to test it carefully and I’ll share with the results.
And as about the size, you are right, it will be, at least, 20 mm.
I have already received the pcbs. I am sharing a few photos. Please, pay attention to the edge connector for programming, it looks good and technologically)). In the near future, I am going to solder device and start it testing!
First device is assembled and is under testing now... But i haven't diceded yet, which type of radios i wanna to use...
@kalina
Can we buy it preassembled soon?
@Cliff-Karlsson Yes, i have made 10 pcs. But if necessary i can solder more. Price for model with RFM69 is 23$ and with NRF24L01 is 20$...
Ok, great. Are there any progress on the MDMSensor "Multisensor" and gateway?
@Cliff-Karlsson Yes, gateway is ready, but MDMSensor "Multisensor" is still in progress...
Hello
Why do you use a triac instead a relay for command the light ? What is the point ?
Hi @tonnerre33. MOC3043 triac includes the function of Zero Voltage Crossing, this mean that triac can trigger only when AC voltage close to 0 V. SSR doesn't use this feature. If you use just one device with ordinary relay or SSR, it is not appreciably, but if the number of switching devices increases and they all switch on at the moment of maximum value AC voltage, this will produce a lot of impulse spikes of voltage, which is not desirable. Ordinary relay also makes a not comfortable sound...
@kalina thx for your answer
Hi, I want to share good news in the my project. Lighting has become more safer.
Instead the enclosure, I use a heat shrink tubing 3M MDT-A-32/7.5.
Here's result.
Your system works with phase and neutral wires? Will you make it compatible without neutral as well? In my house installation no neutral behind the wall switch only phase. And o the lamp side only neutral and the return wire from the wall switch.
Yes.
Actually, no. Why do you plan put this into the wall switch area? As for me, i am going to put "Lighting" near the lamp. Wall switch must be as a push button (normally closed). When you press button circuit opens (on short time) and Atmega328 resets and toggles lamp state. It means that "Lighting" always is conneted to the AC line. You can also change lamp state directly from your controller at any time. See picture below.
I didn't know this method
Do we have a limite time for circuit open ?
How do you do this in the sketch ?
Where can we find the sketch ?
What are the consequences for the components life ?With this use, the reboot time will impact the response time bewtween the command and the lamp power , isn't it ?
Yes, of course. In my opinion, this time we can determine in practice, i don't know how can it be calculated. I haven't done it yet, I will try to do it on weekend.
With this use, the reboot time will impact the response time bewtween the command and the lamp power , isn't it ?I have no answers on this questions, it is certainly disadvantages of this method, but i wont use wall switch very often, i prefer to operate via controller. No need reboot uC in this case.
@kalina : your solution is quite interesting when push button are installed. Yes, i would like to put the system in the wall switch. For the moment, i connect the switch of the house on the arduino. The system is powered by phase and neutral in the garage as behind the switch i had the neutral wire. However, in the house no neutral like on your picture. So, im checking about using leakage current which should be enough to power on the system.... Not sure.
@jeremushka said:
So, im checking about using leakage current which should be enough to power on the >system.... Not sure.
I would be interested to hear about your results
How about dimming? Due to lack of "zero crossing detection" it could be a problem!
@bilbolodz see earlier posts in this thread. The node does not support dimming, but it does support zero crossing.
@Kalina, does your project still alive? do you still have some samples for sales ?
@jeremushka This project has some shortcomings. For this reason I have released a new, more advanced version - MDMSNode "Lighting" Rev 1.1. If you are interested, I have more than 10 pcs in stock.
@kalina would you mind adding a link to the new version in the description of the old one?
@mfalkvidd Easy)) Already done.
@ Kalina: Thanks
Which kind of shortcomings did you get? load switch issue ? safety issue ?
@jeremushka Please look at the description MDMSNode "Lighting" Rev 1.1, everything is indicated there...
This post is deleted!
Hi @aramko-aramko.
Unfortunately, this model is already sold. You can look at the upgraded version of this device - MDMSNode "Lighting" Rev 1.1.
💬 SMDnRF24_adapter
OpenHardware.io • 12 Dec 2016, 06:14 • openhardware.io 2 Oct 2017, 08:09 -
💬 Capacitive Soil Moisture Sensor
OpenHardware.io • 14 Mar 2021, 23:14 • openhardware.io 14 Jan 2022, 15:42 -
💬 Arduino Pro Mini IO Shield
OpenHardware.io • 13 Dec 2017, 05:59 • openhardware.io 13 Dec 2017, 09:53 -
💬 MSMDLed
OpenHardware.io • 27 Dec 2018, 11:02 • openhardware.io 27 Dec 2018, 11:02 -
Mys Interposer NRF/Arduino Pro Mini
OpenHardware.io • 23 Mar 2016, 20:45 • openhardware.io 25 May 2017, 15:59 -
MQTT controller - ping but Connection timeout on MQTT clients
Controllers • 18 Jan 2015, 17:31 • cayco 15 Apr 2015, 19:12 -
💬 Jukebox design journal
OpenHardware.io • 24 Apr 2017, 11:17 • openhardware.io 23 Jul 2017, 21:02
