  3. Repeater node logic
Repeater node logic
repeater
2 Posts 2 Posters 1.2k Views 3 Watching
  • A Offline
    A Offline
    Alexander Ivanov
    I'm using MySensors under Vera UI7 in the environment where radio power is not enough. Repeater feature logic is not very clear for me and I have some questions:
    • can a node work via many repeaters? I mean, if a node is really far from gateway, can it get data from the gateway via many repeaters, for example: Gateway->Repeater1->Repeater2->Repeater3->Target Node ?
    • can a node can be included via repeaters? I mean, does inclusion mode work if the node not connected directly to gateway, but via repeater(s)?
    • do repeaters load network and/or gateway? Will tens of repeaters affect network performance and is it worth to make each node a repeater by defaul?
    Thanks!
    • hekH Offline
      hekH Offline
      Yes, you can have messages passing multiple repeaters.
      Yes, nodes can be included via repeaters.
      No, you should probably not make every node a repeater, enable it for woken nodes at strategic locations.
