CNC PCB milling
    How many microsteps are being used, anyway? I'm not sure where that's defined. Apparently these drivers support up 1/16 steps, but it might be that larger steps are actually being used (?). If so, then maybe going to smaller steps would help?
    I notice one of the Pololu boards has the potential for doing 1/32 steps: https://www.pololu.com/product/2133
    and might even be drop-in compatible.
    How many microsteps are being used, anyway? I'm not sure where that's defined. Apparently these drivers support up 1/16 steps, but it might be that fewer are actually being used (?). If so, then maybe going to smaller steps would help?
    this cnc controller board is directly pulls the drivers' MS1,2,3 pins to high, which means that it is "hardcoded" to 1/16 microstep. you really don't need smoother steps than this.
    @andrew Great that you're back. Did you alter your max speed and max acceleration values at all from the defaults? You didn't list them in your earlier list of magic numbers.
  • @neverdie I still use my default settings (see below). I re-applied these settings after I flashed the board to grbl 1.1f.
    $0=10 (step pulse, usec)
    $1=25 (step idle delay, msec)
    $6=0 (probe pin invert, bool)
    $12=0.002 (arc tolerance, mm)
    $13=0 (report inches, bool)
    $20=0 (soft limits, bool)
    $21=0 (hard limits, bool)
    $22=0 (homing cycle, bool)
    $100=800.000 (x, step/mm)
    $101=800.000 (y, step/mm)
    $102=800.000 (z, step/mm)
    Looks like the only difference is that your default max rates for x and y were 800, whereas mine were 5000, and your max rate for z was 500, whereas my default was 800 before I cut it by 50% to 400.
    In the interest of minimizing differences, I'll adopt your defaults instead.
    did you manage to create double sided PCB jobs in the meantime based on my suggestion and on flatcam's documentation? it is not a hardcore process, let me know if you stuck at a given step.
    Not sure what kind of pins to use for the alignment.
    Even after all this tweaking, the z-axis was off by 0.048mm after the latest set of probing.
    What do you mean by "off"? Afaik grbl doesn't have a M48 equivalent command for probe/machine repeatability... So it can't probe the same place automatically. You have to write your own code for that, based on G32.2 command, take a few measurements and see the difference.
    If you mean across the whole board, depending on the size of the measured area that's not bad at all.
  • @neverdie could you please explain how did you find/measure this? also please let me know the details of the executed job, including the G code generation properties/settings (e.g. feed rate, depth, multiple passes etc.) used in flatcam.
    1. Decided upon an origen. Used Chilipeppr to "run test probe" to find the zero z-height. Zeroed x,y,z at that location.
    2. Did an autolevel, at 1mm spacing, over a 20x10mm area.
    3. Following this, returned to x=0, y=0. Ran another test probe. Ideally it would have come back as z=0. Instead, it came back as z=-0.048.
    So, if at that point I were to actually run g-code with a cutting depth of z=-0.05, it would barely scratch the surface. Somehow during the 1mm autolevel probing, z became uncalibrated. If I were to re-zero z based on the second test probe, it would cut, but the cutting depth wouldn't be uniform.
    Anyhow, my new rule is that if I come across a situation like the above, I throw out the auto-leveling and start over rather than executing the g-code. Often, the next autoleveling will have less discrepancy by step 3.
  • @neverdie
    Maybe run step 1
    Then run some g-code but above the job.(for a few mins).
    Then run step 3.
    This could be an autolevel problem.
    Maybe run step 1
    Then run step 3.
    How might that help?
  • @neverdie
    What if you have broken .048 off the end of the tool during autolevel?
    So run some g-code above the job then re-probe so you know you have not twatted the tool.☺
    Good point. I'll have a closer look for that the next time it happens.
    Also, I'll try repeating the test using a dull bit (which presumably won't break) and see whether it still happens or not.
  • @NeverDie grbl 1.1 probing command is G38.2 Z-10 F25 where Z tells it how low should go before erroring if it doesn't touch and F is the speed.
    You should try manually issuig G38, then G92 Z0 to set new Z0 position and then finally G0 Z10 F100 to lift the probe, rinse and repeat without the G92, how repeatable is the reading, does it stay at 10.00?
    Then do the air job, or some simple moving (G0 X5 Y5 Z5, G0 X0 Y0 Z10 a few times )and retest manually with G38
    LE. The probing command is G38.2, I've edited the post to correct it.
    if your probe speed is too fast, then it could push the pcb at the given points and also it could damage your tip's end, as it was mentioned by @rmtucker, which could cause this issue as well.
    I missed this reply from you.
    so, you have to define the alignment holes, typically outside of the actual pcb area, in the "frame".
    you have to define two of them, the rest will be calculated automatically.
    the steps are exactly the same as that you can see on http://flatcam.org/manual/procedures.html#side-pcb
    see the pic below. note, that you don't have to write the coordinates to the input boxes manually, once you click on the design area the corresponding coordinates will be copied to the clipboard, so you can use ctrl-v to fill out the settings.
    • click on the picture to define the axis (X in this example)
    • copy the corresponding coordinates to the point/box input filed
    • click on the design area to define the exact location of the first alignment hole (left side of the actual pcb)
    • copy the corresponding coordinates to the alignment holes input filed
    • click on the design area to define the exact location of the first alignment hole (right side of the actual pcb)
    • copy the corresponding coordinates to the alignment holes input filed. the two set of coordinates have to be separated by coma.
    • configure the alignment holes' drill size
    • click on the create align drill button and you're done. back on the project tab you can find a new drill job which you have to further process to create the belonging G code from it.
    @andrew Are you using male header pins for your alignment? How deep are you drilling the holes them?
  • @neverdie yes, I use male pins, with 0.7mm drill (so it is tight for the pin), 5mm depth. but this is really up to you, choose anything which you have easy access to.
    @andrew
    With single sided PCB, I soldered the ground wire (for probing) to the copper cladding, just as the Chilipeppr author did. How are you handling it for two sided? If I do it that way for two sided, the solder bump may prevent the board laying flat on the wasteboard.
  • @neverdie I use a wood screw in the sacrificial board holding a piece of metal as a "clamp" I slide it over the board (1mm overlap) and clip one alligator clip to the screw, the other to the bit. After probing I slide it out of the way. The metal piece is about 10cm long and it's left in place for the life of the wood board.
    @andrew
    I use some flat metal weight connected to the given wire, placed on top of the pcb.
    hackaday just released a relevant post:
    https://hackaday.com/2018/01/04/guide-why-etch-when-you-can-mill/
    Interesting that the engraving bits he liked the best were the 30 degree 0.1mm bits. So far, that's been my preference as well.
    @neverdie Possibly too late, but it still might contain some handy tips: https://hackaday.com/2018/01/04/guide-why-etch-when-you-can-mill
    @yveaux said in CNC PCB milling:
    It nicely sums up the biggest challenge of all:
    The biggest challenge in this DIY process is getting a correct and consistent cutting depth. These V-bits yield a wider cut the deeper you go, effectively robbing you of precious engraving resolution. If you do not tune in just the right depth, some traces will come out too thin and frail.
    The results I'm getting seem random. Sometimes it's great. Sometimes it's totally unusable (obliterated traces). Some of the time it's usable, but only just barely.
    So, I'm trying to think of a better approach that might deal with that. Maybe one way might be to start every etching session by running @executivul 's calibration traces. If it's cutting too deep, adjust, and then run again. When it's finally cutting right, then cut the desired PCB traces.
    I don't know what the answer is, but that's where it currently stands with me.
    The alternative is to just make a number of boards. Then cherry pick the good ones and dispose of the rest.
    I think I've found at least one reason for the trouble I've been having: sometimes the double sided scotch tape hasn't been holding the board completely flat against the waste board. Instead, during the milling process, which has a lot of vibration, it can pop up in the area being milled. When that happens, it's effectively the same as having the milling go much deeper, and so traces can be obliterated. Hence, I may try the Shurtape GG-200 that was recommended in the Hackaday article.
    It may be that the copper clad boards I'm using just aren't flat enough in the first place. Add to that a waste board that may not be perfectly flat either, and it's not a good formula for keeping everything perfectly flat, which is evidently what it needs to be. The tape itself can't compensate for too large a mismatch.
    So, I'd like to try the earlier idea of milling the waste board flat. Just not sure how to do that.
    I would't be surprised if single sided copper clad boards are inherently prone to warping. If you think about it, the copper can expand/contract with temperature, and if it's on only one side....Unless the substrate has the same coefficient of thermal expansion, the result will inevitably be warping. The same would be true if the substrate is affected by humidity.
    The Hackaday article does mention that it's not necessarily easy to find good copper clad boards. He hints that it has been an ongoing issue over time. He gives a reference for an ebay board vendor in England that he currently likes, but unfortunately that doesn't help me much.
    What blank copper clad boards have folks here found that they like?
  • @neverdie Perhaps surface cleanliness is the problem rather than the tape, just a possibility... When you are dealing with such fine tolerances, any residue will allow the board to twist or warp...
    Not sure to what extent the milling itself would encourage deformation of the substrate, but irrespective, it would again depend on adhesion on the bottom face to resist it...
    You raise a good point. I suppose ideally the waste board would be covered in melamine or similar so that it can be cleaned of any bond breakers.
  • @neverdie Not sure whether you mean a slab of melamine or a laminated board...
    I'm sure I saw a video clip where a perspex or similar baseplate was mounted on the bedplate to provide a perfectly flat surface. The user released the adhesive tape using wd40 or similar, then cleaned the area afterward with alcohol.
    If I remember correctly, the perspex had locating dowels for the PCB, and always locked into specific location on the frame. If I find the video again will link it...
    Just laminated. Here, I've already made the switch:
  • I've seen people engrave round objects based only on autoleveling, gcode was generated for a flat surface. So autolevel should take care of the board not being perfectly flat. Only issue is to chose a grid step small enough so the matrix can follow the hills and valleys (3-5mm).
    On the other hand autolevel can not compensate for the board moving. Probing force is much lower than milling force. So when milling pcb prefers to move down and you get a shallow engrave where it was probed higher due to being lose.
    Lost steps should add, so a constantly deeper and deeper or shallower and shallower engrave would make me think of lost steps.
    I would try changing the probing speed to 10-15 and z max feedrate to 50, z max accel to 10. Add some grease to z axis components (engine/transmission oil or very light grease), a few drops goes a long way.
    Also make sure you do the z zeroing at 0,0 and don't reprobe at another point after the grid probing.
    LE. Rail bowing under gantry weight is another problem, it would appear as a convex (inverted soup bowl) surface, since in the middle of the rail the gantry goes lower so the surface appears to be higher.
    A dial gauge with a magnetic arm can be had cheaply these days and is a miracle for testing backlash and baseboard flatness. Fix the mag base to the spindle and start moving it back and forth
    Even removing the moving bed and testing against the y rails might yeld some surprise.
    LE2: baseboard/sacrificial layer flatening works only for plastic and mdf, normal wood or big piece wood conglomerate leaves a much worse surface than the original board.
    @NeverDie hope I gave you some ideas to play with, by the way I asked you earlier to do some tests for z axis repeatability, did you manage to do them?
    LE3. God damn it! Now I must haz this https://m.ebay.co.uk/itm/EU-UK-3-Set-2N-m-Nema23-76mm-Hybrid-Closed-Loop-Servo-Motor-3A-HSS57-Driver-CNC/152848151184?_mwBanner=1 and all my problems should be gone!
  • @neverdie As good as any I guess if it's new board...
    Curiously watched some videos, one using a smaller machine where the board was only locked from horizontal movement with pins (no tape under at all), another where MDF had been rebated to lock in a specific board size and taped down.
    In the first case he only set the z-axis in the centre of the board (and a neat way of doing it too by loosening the chuck and dropping the bit then retightening once close to the stop), no surface mapping nothing. The pins were to allow double sided cutting...
    Tried the new laminated wasteboard, and so far so good:
    I got the above result by a method you guys are probably going to hate, but it worked. Namely, I ""sneaked up on" the correct z-depth rather than committing to a single pass at, say, z=-0.05. So, to get the above I first did a pass with z=-0.02. That did manage to cut through in some areas, but not others. So, I increased the cut to z=-0.04 and did a second pass. The result is what you see above. No need to go further to z=-0.05.
    Also, I did the probing (at 4mm) with a blunt used etching bit. Afterward, I switched to a new Model 20 bit, did a test probe to zero it, and then initiated the first pass.
    So far this new approach seems to be working. Here I probed every 1mm using a blunt bit before switching to a model 10 to do the cutting at depth z=-0.03 (which was the third pass):
    The first two passes were at z=-0.01 and z=-0.02 respectively.
    Not as yet. The new "sneak up" method has been working (now 3 times out of 3), so I'm going to stick with that for now.
    I've noticed that there also exist the same sort of "servo stepper", but with all the electronics built into the stepper motor housing. That might be preferable, if only because it avoids the proliferation of wires that need to be managed. In any case, I don't see how these devices can be bad, and there's at least a chance they may do some good. If you decide to go for it, please do let us know what kind of improvement, if any, that you notice.
    I'm now 4 for 4 with the sneak up method. Each time it worked, so I feel comfortable I can rely on it. I now start with a cutting depth of z=-0.03, and then, as needed, I "sneak up" on the final cutting depth from there. That yields the minimum cutting depth, which in turn avoids trace obliteration.
    I'm just glad it works. 🙂
    I suspect using a roller, such as the following, might help in flattening the pcb down against the waste board:
    https://www.amazon.com/POWERTEC-71010-Handle-J-Roller-Rubber/dp/B00NFAOCVU/ref=sr_1_1?ie=UTF8&qid=1515463577&sr=8-1&keywords=laminate+roller
  • @neverdie You will get nowhere near the same downward pressure... just using your hands or tapping it down with a rubber mallet is more effective imho....
    Argh, the CNC totally died again. Except this time it isn't a bad power supply. Rather, the woodpecker board is non-responsive. Looks as though I'll have to order a replacement woodpecker board. 😞
  • @neverdie I believe the boards with a removable Arduino Nano are better, if the uC fries you can replace it without replacing the whole board.
  • @executivul similar to the RAMPS boards for 3D printers. It's all modular so if your uC or a stepper driver dies, you can just replace that one part.
    I agree that seems like a far better design, for exactly that reason. I'm hoping this isn't something that happens regularly. If the replacement dies too, then I'll make the switch.
  • @neverdie or you could just mill your own board since now you have the tools 👌
    Not if it's broke he doesn't.
  • That's the original designer of that shield :
  • @neverdie interesting.
  • @neverdie don't stick to you missing dragon programmer. use an arduino as an isp programmer instead. also, if you burn the bootloader, next time you can use the usb connector for update.
    BODLEVEL = 2V7
    RSTDISBL = [ ]
    DWEN = [ ]
    SPIEN = [X]
    WDTON = [ ]
    EESAVE = [ ]
    BOOTSZ = 1024W_3C00
    BOOTRST = [X]
    CKDIV8 = [ ]
    CKOUT = [ ]
    EXTENDED = 0x05 (valid)
    HIGH = 0xDA (valid)
    LOW = 0xFF (valid)
    Grbl 1.1f ['$' for help]
    Because of the upgraded firmware, I'm actually better off now than I was before. 🙂
    $0=10
    $1=25
    $2=0
    $3=5
    $4=0
    $5=0
    $6=0
    $10=3
    $11=0.010
    $12=0.002
    $13=0
    $20=0
    $21=0
    $22=0
    $23=0
    $24=25.000
    $25=500.000
    $26=250
    $27=1.000
    $30=1000
    $31=0
    $32=0
    $100=800.000
    $101=800.000
    $102=800.000
    $110=800.000
    $111=800.000
    $112=500.000
    $120=10.000
    $121=10.000
    $122=10.000
    $130=200.000
    $131=200.000
    $132=200.000
  • @neverdie
    I found out what they mean:
    $31=0.	Min spindle speed, RPM
    $32=0	Laser mode, boolean
    yes
  • @neverdie sorry, I'm abroad, with very limited availability, so cannot answer too quickly.
    Thanks! You nailed it. It turns out the solder connection on the atmega328p pin corresponding to D5 just wasn't good enough. I resoldered it, and now the X-axis works in both directions. 🙂
    @andrew
    Cutting depth: 0.03
    Feedrate:80mm
    Do you have a photo of that?
    @andrew
  • @neverdie
    • flipping the pcb
    • moving and not stable pcb
    maybe my pins also have different factors, but indeed, the given holes are pretty tight. this helps to prevent unnecessary pcb movements, which is very important if you work with 6mil traces/isolation, as a small unwanted movement could result in wasted pcb. if you work with bigger traces/clearings then it is not as important.
    I would recommend to stick to one size which is good for your selected pins and which does not let the pcb to move.
    Here's the final product:
    Three of the vias are located under an SMD module, so I'll just have to try to minimize any solder bumps over them.
    Unfortunately, even a tiny solder bump prevents the module from being soldered. I would have to redesign this so that the vias are not under the module.
  • @NeverDie Just have to say, I have been following this thread for a while now and you have come a long way with this. Great job.
    Another good thing for people to know is that you can leave a single-sided blank PCB installed in the CNC and then, as the need arises, cut out additional modules from it:
    For instance, this morning I cut this module carrier out of the above, already used, copper clad PCB:
    So, for simple small things, it's a handy arrangement, and the incremental cost is negligible.
  • @neverdie Perhaps a clearer explanation ?
    One problem I've run into though is that the foil traces can sometimes lift up in the course of ordinary soldering. For instance, the traces connecting the second to the right pin on the Fanstel module seems to have utterly disappeared, leaving that pin unconnected:
    Maybe it's the quality of the blank PCB? I just don't know.
  • @neverdie It looks like you could potentially make those traces just a touch wider looking at the receiving end of the module. Woulld that be an option?
    Maybe: I'll try a 10 degree bit and tighter autoleveling to see if that gives wider traces.
  • @neverdie i say that because in your previous pic of the board it looked like that trace was a bit narrow. Because of that it probably couldn't take the heat.
    It's funny, because I redid the soldering using an altogether new board, and it failed in exactly the same place:
    This time, though, you can actually see the copper trace has curled up away from the board.
  • @neverdie It is quite odd that that one did it and some of the others didn't on that side of the board. Looking at your previous image, the pads and traces on the side marked in green look noticeably larger than the ones marked in red. Look at the ones marked with the blue arrow. It looks like those should, or at least could be the same size. Your thru hole pads on the left for the breakout headers also look smaller than the ones on the right. Shouldn't the two sides be a mirror image of each other?
    @dbemowsk It's because the left side of the board is higher than the righthand side, and apparently the autoleveling isn't working all that precisely.
  • @neverdie I can see that the left side looks like it cut deeper, which would cause that. I still think it is the thin traces though. Can you do any manual leveling of the bed? If so, I would attempt that. My Anet A8 3D printer, though not a CNC, is all manual leveling and I do have to check it from time to time.
    I suppose I could shim under the sacrifice board with slips of paper to get the right height.
    I would have thought that the autoleveling would have accurately compensated though. Not sure why it isn't, especially if I'm autoleveling at 2mm spacing. Maybe this is an area where a future version of the GRBL driver will get it right.
  • @neverdie cnc milling auto leveling is not like 3d printing bed leveling.
    In 3d printing the firmware probes the bed, stores the values and automagically compensates at every move.
    In cnc milling the host control software asks the grbl to move and probe each point, then it modifies the gcode accordingly and sends that gcode to the controller which in turn just moves in the xyz coordinate system.
    Now, are you sure your gcode is updated to reflect the leveling?
    Normal flatcam gcode has a few Z-0.1 moves, the rest are only G1X...Y... (without Z) and autoleveled gcode has almost every move with z, like G1X...Y...Z.... Chilipeppr also adds some comments at the end of the lines like "new Z" or "Z mod".
    If you run the autoleveling probing but do not hit "send autoleveled gcode to workspace" in CP or "apply height map" in OpenCNCPilot the probing is useless.
