💬 MyGateway
@Gerator - Nice project! How did you solve dual SPI channels for ethernet and RFM radio?
Ethernet gateway using Arduino UNO with Ethernet shield stacked JP1 should be 1-2 and JP2 2-3.
RFM69 and Ethernet shield share SPI bus, each one with its own CS line. Ethernet shield uses pin 10 so JP1 should use pin 6 for the radio. Issues sharing SPI bus seems to be due to bad SEN line handling as described here. The official Arduino ethernet shield suffered from this, but most commonly used clones work ok. Shields including 74LVC14 as in the pic should work ok.
This project is very cool!
I received my pcbs to try it this morning , i'll tell you if i can make it work
Works perfectly ! So many thanks to @Gerator
@hlehoux glad to hear that!!
1 out of 6
Gateway to support dual radio
General Discussion • 22 Mar 2021, 23:37 • Westie 30 Mar 2021, 17:21 -
💬 USB RF Gateway
OpenHardware.io • 6 Sept 2019, 11:44 • openhardware.io 6 Feb 2020, 11:36 -
💬 NModule PIR sensor shield
OpenHardware.io • 29 May 2017, 18:57 • openhardware.io 15 Jun 2017, 10:27 -
Network Gateway with Sensors/Actuators
My Project • 20 Jan 2015, 14:31 • lunarok 20 Jan 2015, 14:31 -
Newbie question about how the mysensors gateway connects to controller
General Discussion • 23 Mar 2020, 15:05 • Thomas433 24 Mar 2020, 22:12 -
💬 ESP8266 Gateway
OpenHardware.io • 18 Feb 2018, 21:52 • openhardware.io 21 Mar 2018, 06:31 -
💬 MySensors compact (junction box) relay
OpenHardware.io • 3 Feb 2020, 19:01 • openhardware.io 3 Feb 2020, 19:01 -
💬 Arduino Serial Gateway for RFM69HW
OpenHardware.io • 24 Jan 2017, 12:49 • openhardware.io 8 Jun 2017, 10:06
